Old 06-11-2010, 01:34 PM   #1141
JGH
- jonest,
Thanks! Warm-up was pretty good.
This week we will go again for final tests in Germany.
- Francisco,
Most of the time the lightweight works better then regular weight.
However I agree that the wing is too soft, therefor I run a regular weight wing most of the time.
-M3dreamin2008,
I can imagine that on a bumpy parking lot you also crash sometimes.
When you crash most of the time the spoolcup is damaged.
I don't have a solution for this.
-jontang001
I don't know exactly the set-up, but I didn't run any bladder in the shock.
Maybe I write it wrong on the set-up sheet.
99% of the time I run my shocks without rebound, therefor ofcourse without any shims,foams or o-rings on top of the bladder.
I ran 700 because this thick oil works better on a hot surface. It has better balance and it doesn't overheat the tyres. In the evening I could run softer like 550.
Jilles
JGH is offline   Reply With Quote
Old 06-11-2010, 02:34 PM   #1142
Hi Jilles,
how is going out there?
I get this chance to ask you some information about the good way to set-up my 416WE.
I'm little puzzled because everyone give me a suggestion (lucky but not the good way to follow), someone suggested me to remove a shim, add a screw on the top deck or add other shims under the brace link, remove, add...wow this is causing a big caos in my mind
....but I wish to find a way to follow in order to properly set-up my Tamiya.
Please, could you let me know a way to do? Or let me (us) know your way to start to set-up the car.
Any suggestions are appreciate. Thanks a lot....
Marco (lynx75)
lynx75 is offline   Reply With Quote
Old 06-11-2010, 06:37 PM   #1143
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
The XXXMain setup book or Xray setup book are awesome guides for setup. I think studying those and testing will yield the best results.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 06-11-2010, 07:55 PM   #1144
haywood's Avatar
Trader Rating: 49 (100%+)
Default 416x
Hi Jilles, do you know anyone that is running this chassis with foam tires and if so where could I find a setup? Thanks
haywood is offline   Reply With Quote
Old 06-11-2010, 10:05 PM   #1145
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I don't know how good it is but there is one listed under the carpet setup section here:
http://www.petitrc.com/reglages/tami...miyaTRF416.htm
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 06-12-2010, 02:01 AM   #1146
CraigM's Avatar
Trader Rating: 34 (100%+)
Jilles posted a foam setup earlier in this thread
http://www.rctech.net/forum/5628014-post41.html
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-12-2010, 04:24 PM   #1147
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
How many teeth are on the diff pullies for the rear diff.
Thanks George
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 06-13-2010, 08:15 AM   #1148
jonest's Avatar
Thanks George
front and rear same, 37.
jonest is offline   Reply With Quote
Old 06-13-2010, 11:48 PM   #1149
KWT-NITRO's Avatar
Hey Jilles,
no problem, you will get to see him in few weeks for the worlds, just send him my greetings
i have a question about the much more shock o-rings, they have them in 30-40-50 degrees!!! is that the hardness of the o-ring and if so, what do you recommend for the Tamyia 84008 shocks??
cheers and good luck
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 06-13-2010, 11:58 PM   #1150
corallyman's Avatar
Trader Rating: 99 (100%+)
Hello Jilles,
I am sure you answered this before but what brand of shock oil are you using? Is it Much More oil?
Thanks,
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 06-14-2010, 12:04 AM   #1151
jonest's Avatar
Originally Posted by corallyman View Post
Hello Jilles,
Thanks,
Steve
Definitely Much More. Tamiya has announced new line of shock oil under the VG brand. I wonder is it the = Much More.
Old 06-14-2010, 12:15 AM   #1152
corallyman's Avatar
Thanks Jonest.
Old 06-14-2010, 04:52 AM   #1153
CraigM's Avatar
The double o-ring in the shocks are awesome! I'm using the muchmore blue orings, I think Jilles said he uses the tamiya ones now
Old 06-14-2010, 08:03 AM   #1154
jonest's Avatar
double o-ring in the shock? Which part? Could they fit?
Old 06-14-2010, 08:52 AM   #1155
STLNLST's Avatar
Trader Rating: 21 (100%+)
JGH- What springs do you usually use on asphalt? Do you stick with all Tamiya springs or are there some times where other manufacture springs work a little better?
STLNLST is offline   Reply With Quote
