"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors >
Old 04-06-2010, 09:30 AM
  #976
Senna Racing's Avatar
Hi jilles
I was woundering if you have heard anything about the
opening event at the new RCA track in Bangkok
I spoke with some of the guys at titc whom told me it should
be in July
Have you heard anything
Thanks Wayne
Senna Racing is offline
Old 04-06-2010, 07:31 PM
  #977
JGH
Steve,
I might be at the track this weekend. See you then!
Sean,
This depends on shock and spring length. Normally the rear has little room for the spring but front the spring is pretty tight.
tb214,
It's pretty cool challenge to switch from wheel to stick, but I'm sure within a few month you will be same speed.
Cookie,
Thanks for the info! I missed you at TITC? Everything allright?
As the worlds is already in 3 month I will do some testing here in Bangkok for this month and will also test different chassis, for sure I will test the smokem as well. Let you know later how things are going!
Manu,
Everything fine! Hope you too?!
For wet condition I normally change the ride height of the car to 6 or 7mm, depends on how much water there is. Therefor you need to adjust the droop as well. Droop should be around 3mm. If the car is good balanced in the dry condition it should work fine in the wet.
Wayne,
Do you mean the new RCS? I live very close to that area but till now I not see much going on there. I heard they have had some trouble with getting an approval from the government to start building on the property.
Jilles
JGH is offline
Old 04-06-2010, 08:17 PM
  #978
thanks Jilles
ya thats what i ment,
Ahwell not looking to good for a opening event in july. guess i will be spending two weeks of shopping and temples then
Anyway thanks again for your help at titc hope to see you there again next year
Old 04-07-2010, 06:13 AM
  #979
Cookie's Avatar
Hi Jilles,
That will be great to hear how you go with it.
Was in critical project phase at work this year in Feb and saving some mun! so didn't go for titc this time but will plan to make it next year! :-)
Cheers
Cookie is offline
Old 04-07-2010, 08:20 AM
  #980
dameetz's Avatar
Jilles, can you post a basic set up for 416x for indoor carpet race? I ll be joining next month FEMCA race. The track looks technical and can you also advice what motor turns do you usually use for this type of track size (straights is approximately 60-70ft.... HERE's the pic of the upcoming FEMCA race.
dameetz is offline
Old 04-07-2010, 05:35 PM
  #981
robk's Avatar
Trader Rating: 22 (100%+)
Jilles,
I'm new to the 416 cars (bought a 416we recently) and all the carpet setups seem very similar. I seem to be experiencing a bit of an on power push. I started with the "Viktor Wilk" setup that everyone recommends. The car pushes mid corner in the sweeper, and does not seem to get through switch backs as fast as other cars.
Things that helped me:
More weight on rear end
Laying front shock down
Standing rear shock up
Raising rear link
Stuff I tried, but I'm not sure if it helped:
Adding toe at the rear hub (1*), but same overall toe (3*)
Shortening rear link
Lengthening wheelbase
Car is on Jacos
Any ideas? Thanks for your time.
robk is offline
Old 04-08-2010, 07:24 AM
  #982
CLK@racing's Avatar
Hi Jilles,
Some question regarding your TITC setup.
I am comparing it to your basic rubber outdoor setup. Hope you can enlighten us on the reason for the change for the following;
Ride height - You ran at 4, 4.5 vs the usual 5, 5.5.
Sus mount spacer - you went up 0.5mm all round
Camber - 0.5deg more than usual
Front sus blocks - 1D and 1B? What is the the advantage running the front front (1D) block wider than the front rear (1B)?
Downstop - the arms were higher by 0.5mm, from the usual 6, 5. Is this due to you running the ride height at 4, 4.5?
If you ran ride height at 4, 4.5 but remain the downstop at 6, 5. What will be the disadvantage?
Thank you.
CLK
CLK@racing is offline
Old 04-08-2010, 10:49 PM
  #983
JGH
Wayne,
I think they can't finish the track that fast, but sure the TITC will be at another venue then RCAddict next year, hopefully back to RCS!
Cookie,
Hope to see you next year then!
Dameetz,
Attached my set-up of the LRP Masters two weeks ago. This set-up should work pretty good at the FEMCA race. I really hoped the race was in April as then I might should have come, but since it is in may i'm heading home for a couple of month to do the big races in Europe.
Robk,
Check my set-up from LRP masters. I don't know what thinks are different on Viktor's set-up as normally we all run pretty much same. To get rid of on power push I suggest not to use anti-dive, or lay in the rear shock one step.
CLK,
RCAddict track was pretty flat, so you could run lower ride height, this helps against traction roll, especially in the evening. As the grip was really high I went to 1mm rollcenter shim. This maked the car a lot smoother to drive and took out little traction so it had better cornerspeed.
Due the highspeed section and the MuchMore tyres I felt more traction in the corner with little more camber.
Front susp blocks 1D/1B you create little armsweep, this basicly gives more steering in the big sweeper and is less aggressive going in the corner.
If you keep the downstop at 6/5mm with the lower ride height, you will have more uptravel. This makes the car roll more as it can transfer more weight.
Therfore I added little more droop to have the same uptravel when I use 5/5.5mm ride height.
Jilles
Attached Thumbnails "Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors-scan0001.jpg
JGH is offline
Old 04-08-2010, 10:52 PM
  #984
dameetz's Avatar
Thanks for the set up Jilles. Those springs are Tamiya's right?
dameetz is offline
Old 04-08-2010, 11:04 PM
  #985
kschu's Avatar
Trader Rating: 16 (100%+)
jilles, what is the different using 2 oring and 1 oring in the shock ??
thanks
kschu is offline
Old 04-08-2010, 11:17 PM
  #986
JGH
Dameetz,
Yes, Tamiya blue and white. These springs are always best springs for carpet.
Kschu,
I like the two o-rings as it feels little more like a damper. One o-ring feels too soft and leak little bit. 2 o-ring feels like 5W harder shockoil. But it's little more solid feeling. I actually think it has more traction.
Jilles
JGH is offline
Old 04-08-2010, 11:28 PM
  #987
colt1402's Avatar
Trader Rating: 90 (100%+)
Hi Jilles, i saw your youtube video online on the ball diff build. You did some paper standing on the diff plate. May i know the "standed" face the ball or the alu diff cup? Thank you if you could enlighten me on this!
colt1402 is offline
Old 04-08-2010, 11:32 PM
  #988
robk's Avatar
thanks
robk is offline
Old 04-08-2010, 11:48 PM
  #989
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by JGH View Post
CLK,
Jilles
Hi Jilles,
Quick question, would it not give the same results if you run a little toe out instead of using front susp blocks 1D/1B?
If not what would be the difference?
Arahawak is offline
Old 04-09-2010, 02:21 AM
  #990
CraigM's Avatar
Trader Rating: 34 (100%+)
I'm sure it's been mentioned elsewhere but where does the 2nd o-ring go? Do you use it instead of the plastic spacer?
Originally Posted by Arahawak View Post
Hi Jilles,
Sweep changes castor and wheelbase so only affects the car in the corner, more toe changes the car everywhere
CraigM is offline
