Old 02-09-2010, 05:09 AM   #871
OK thanks guys , guess i need some short(EVO) arms then,
Thanks Skittee and Craig.
karlfawcett is offline   Reply With Quote
Old 02-09-2010, 05:29 AM   #872
Senna Racing's Avatar
Originally Posted by STEVIEF1 View Post
Hi, looking for a set-up for Rubber (sorex 28) on Carpet for a newly built 416X. I race on quite a small tight and twisty indoor track.
Do you have a set up sheet completed that fits this criteria that you could post up?
Your advice would be much appreciated.............
Go back one page I'm sure the snowbirds setup will suit
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 02-09-2010, 05:45 AM   #873
Toh WL's Avatar
jills, congrat 2u on your RCA win.
some minor suggestion, it be cool if u post your winning pic as your avatar. what do u think?
Toh WL is offline   Reply With Quote
Old 02-09-2010, 06:37 AM   #874
CLK@racing's Avatar
Default Tire treatment for RCA
Any advice on the Sweep tires to be used for the TITC at RC Addict?
What traction compound to apply? Do you tweaked the tires?
Do you prep your tires differently when the track is at its hottest?
Thank you.
CLK@racing is offline   Reply With Quote
Old 02-10-2010, 10:04 PM   #875
jonest's Avatar
Jilles,
What profile on the ESC are you using for your low turn motors with Lipo batteries?
Thanks.
jonest is offline   Reply With Quote
Old 02-11-2010, 06:19 AM   #876
Toh WL's Avatar
Originally Posted by jonest View Post
Jilles,
Thanks.
jonest, u want to win over jilles..
Old 02-11-2010, 06:48 AM   #877
Trader Rating: 45 (100%+)
Jilles in your Sbirds setup you used 2 o-rings on the shocks. What does this mean exactly?
Apex is offline   Reply With Quote
Old 02-11-2010, 09:48 AM   #878
Jilles saw you on rctvlive.com
nice job on the win at the Birds. You looked dialed.
Ginsu is offline   Reply With Quote
Old 02-11-2010, 02:45 PM   #879
dsyed1's Avatar
sorry for the silly question... but can some one please explain the difference between Tamiya short springs and regular touring car springs? I searched this thread and couple others with no luck
thanks
dsyed1 is offline   Reply With Quote
Old 02-11-2010, 10:30 PM   #880
JGH
Vitomon,
If you look at previous set-up sheets of most of the TRF drivers you will see anti-dive is used most of the time. It gives more aggressive steering into the corner.
Mark,
I use a Nosram Pearl speedo for Modified. Most of the time I use a 4.5T motor outdoors and 5.5T indoors
416X has more rear traction then 416We.
Orzel24,
What you mean by steering brace?
6-6 downstop gave little more reaction in slow chicane.
Karl,
The Evo arm are the short arm,now they come standard in the 416X, 416/416WE had longer arms.
Dameetz,
My set-up for Mod at RC Addict is almost identical to the Worlds 2008 set-up.
I use LTC-R body instead of Speed6.
Jonest,
Thanks Ride Cup was really cool. Great battle between Surikarn, Hara and me. Pretty cool to race against these World Champs!
scarecrow,
Thanks, you are welcome. Snowbirds was great and I really enjoyed it.
The Oval was awesome, especially the 600 laps enduro was really cool and intense. Hope to see you all next year!!
[email protected],
Check: www.rcblood.com
The control tyre for Modified will be Much More and not Sweep.
Sweep and Much More are two complete different tyres.
I prepare them with FX2, this additive works best.
Jonest,
My latest set-up for Mod/Lipo at RC Addict is as follow:
- Motor Orion 4.5T 2mm timing standard rotor
- ESC Nosram Pearl 1,2,1,1
- Gear 105/28 = 7.7
Apex,
Two o-ring gives little more dampening, little more traction.
Dsyed1,
Don't know about short/long Tamiya springs. Maybe it has something to do with Mini spring/TC spring?
See you all soon at TITC!!
Jilles
JGH is offline   Reply With Quote
Old 02-11-2010, 10:39 PM   #881
Hi jilles
looking forward to getting to the track next week
Was woundering if you will be using the x or the we for titc
and if you can share any setup tips at this point
Thanks wayne
P.s looking forward to meeting you
Old 02-11-2010, 10:47 PM   #882
caltek1's Avatar
Trader Rating: 36 (100%+)
JGH,
Did you lighten or remove any parts from your MO5 for the Ride Cup race? I see in the pictures, lots of highly modified mini chassis's. Do you have a good starting point for the mini springs?
Thank you,
Regards,
calvin.
caltek1 is offline   Reply With Quote
Old 02-12-2010, 12:24 AM   #883
Originally Posted by JGH View Post
Vitomon,
Mark,
Orzel24,
Karl,
Dameetz,
Jonest,
scarecrow,
[email protected],
Jonest,
- Gear 105/28 = 7.7
Apex,
Dsyed1,
Jilles
So instead of using 1 you use 2 o-rings and nothing else changes in the shock, right?
Old 02-12-2010, 07:35 AM   #884
I mean this:
and when two separate screws?
orzel24 is offline   Reply With Quote
Old 02-12-2010, 09:49 AM   #885
94eg!'s Avatar
Trader Rating: 17 (100%+)
How do you fit two o-rings inside the lower seal cartidge?
94eg! is offline   Reply With Quote
