"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors >
Old 12-22-2009, 10:37 PM
  #811
Toh WL's Avatar
jonest,
Great to hear that as the latest design remain backwards compatibility with the former models.
dodo,
Thanks for the feedback, at least for sure the screw orientations are different.
Contrary to that Jills did mentioned "To upgrade your "old" 416 to the X you need the rear bulkhead, rear belt and topdeck. You can't use the new front bulkhead on the old chassis."
Anyone can assist to provide the Tamiya P/N all neccessary parts to make the conversion possible. This will eventually reduce the same question from others. With the p/n ppl can look up themselves... Thx in adv.
Toh WL is offline
Old 12-22-2009, 10:55 PM
  #812
Arahawak's Avatar
Trader Rating: 32 (100%+)
My question would be why go backwards??
is it because of lack of parts?? or?? just for the sake of trying different setups??
Arahawak is offline
Old 12-22-2009, 10:58 PM
  #813
Toh WL's Avatar
Just try diff setup for my end.. To others their requirements are different.
Toh WL is offline
Old 12-22-2009, 11:41 PM
  #814
caltek1's Avatar
Trader Rating: 37 (100%+)
Hello JGH,
Just a question regarding your tight ball diff in your MO5M. Which ball diff did you use? The new MO5 ball diff or the old TAO3 ball diff?
Sounds like the new Ride mini tyres might be pretty good. Are they as hard wearing as the Ride 3035's?
Enjoy Singapore.
Thank you.
Regards,
Calvin.
caltek1 is offline
Old 12-26-2009, 07:56 AM
  #815
Hi, Jilles
Would you please share the setting of Ride tyre in RCA? Thank you in advance.
srw_g is offline
Old 12-28-2009, 04:38 AM
  #816
nutsisneat's Avatar
Hello Jilles
I'm building my 416X now, the car went together very well.
2 questions:
- Are you using the original diff screw or something else?
I found the screw a bit short, high risk of stripping.
- More important for me:
I have issues with my Lipos (LRP 5300 and Boomerang, EP 5200)
The (- Minus) socket is exactly below the topdeck. I don't want to Dremel, it would weaken the top deck too much. I'm also scared about dremeling the Lipo-Pack. I'm sure you have tested with Lipo's, any ideas?
Thanks in advance!
nutsisneat is offline
Old 12-28-2009, 05:44 AM
  #817
Stein Tumert's Avatar
Originally Posted by nutsisneat View Post
Hello Jilles
2 questions:
Thanks in advance!
Go to RedRC and look at pics of the 416s from the ETS races (race 1 and 2 in 2009-2910 series). You can see how they have soldered together battery connector and plugs that fits under the upper deck.
http://ets.redrc.net/gallery/
Stein Tumert is offline
Old 12-29-2009, 02:58 PM
  #818
Senna Racing's Avatar
Hi jilles
I have been using my 416we with your euro setup and adjusting
droop to suit different track and it has been quick
how will my new 416x differ or should I build it the same way
Have you got any setup tips for it with the chassis
Thanks in advance
Wayne
Senna Racing is offline
Old 12-30-2009, 06:15 PM
  #819
JGH
Orzal24,
The differents in Stock and Modified is not much, the cornerspeed is about the same. In mod you have little more torque so normally little more toe-in is required.
Calvin,
The last race I tried cleaning cum( this what you use to clean gascar ) in my geardiff. You actually make almost a spool as the diff doesn't work anymore.
This gives really good on power response(no diff slip anymore) but little lack steering out of corner. Before I use old M03 balldiff. Will try M05 balldiff later as soon as I get one. The Ride tyres for the TITC are very low wearing and good traction, not as good as Sweep tyres but for all drivers same. The TITC controlled tyre is also bigger then the previous Ride tyre (3035)
srw_g,
Setting for Ride Tyre is not much different as with other tyres at RCA.
One thing I noticed at the Futaba Cup was that old tyres worked better then new tyres. Beginning of Februari is a TITC warm-up race(Ride Cup) so good time to prepare.
Nutsisneat,
I'm sure that the diff is the same as the previous models so no changes there. I quess you need to tight the diff little more then.
I use Orion Lipo's with the wire/plug coming out of the side, so no problems with plugs. Maybe check some pics from Marc/Viktor's car at recent races as they use SMC packs with plugs.
Wayne,
No need to change setting for your new ride. You might need to play little with your balance weight if more weight is reguired.
All Happy New Year!!
Jilles
JGH is offline
Old 12-30-2009, 07:15 PM
  #820
caltek1's Avatar
Thanks JGH,
I don't think I have ever heard of cleaning Gum (cum ), however I will stick to the anti-wear grease. Thank you for your information regarding the tightness of the ball diff and the ride tyre. Does the tyre have a round or square edge.
Do you know what type of insert they will be using in the handout tyre for mini?
Thanks again and have an awesome New Year.
Regards,
Calvin.
caltek1 is offline
Old 12-30-2009, 10:27 PM
  #821
jonest's Avatar
Hi Jilles,
In some races, organiser implement that max heigh of the rear wing not more than 115mm (which is the min height of the car roof) instead of IFMAR's not exceeding the height of the car roof (115mm - 175mm).
I just wonder how they measure it in Thailand / TITC?
jonest is offline
Old 12-30-2009, 11:58 PM
  #822
kschu's Avatar
Trader Rating: 16 (100%+)
Originally Posted by jonest View Post
Hi Jilles,
they have gauge to measure your wing........
kschu is offline
Old 12-31-2009, 07:31 AM
  #823
jonest's Avatar
I meant the height. If they measure the height by using the MuchMore TC gauge means less than 115mm.
jonest is offline
Old 01-01-2010, 03:09 AM
  #824
Hi, Jilles.
Happy new year to you and everybody.
Question, you run a rc motorbike at heemstede, wich one?
Best regards
Ed IJzerman
eded1 is offline
Old 01-03-2010, 05:01 AM
  #825
Hello Jilles
If running on asphalt and traction is low, should I lay down or stand up the shocks more? What other setup can help?
Thanks.
yokfans is offline
