Old 12-14-2009, 03:50 AM   #766
Toh WL's Avatar
Thanks JGH for the feedback. I was thinking TRF drivers are promoting Speed Passion. Surely they knew the pro con real well too.
Toh WL is offline   Reply With Quote
Old 12-14-2009, 05:53 AM   #767
Toh WL's Avatar
JGH, I was thinking if Tamiya produces ALUMINIUM front knuckle for TAM51332. The ball connector which connects the knuckle does goes loose as time goes by due to mechanical steering movements.
I have to check the ball connector on TAM51332 time after time. At most time it get loose I just have to tighten a bit else replace the front knuckle. If not ball connector drops off along with shims & flanged tube. This is somehow quite annoying.
Is there any workaround on this...
Old 12-14-2009, 06:32 AM   #768
PizzaDude's Avatar
Threadlock (Tamiya) or Loctit might help.
PizzaDude is offline   Reply With Quote
Old 12-14-2009, 07:57 AM   #769
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by JGH View Post
kschu,
The fastest body is the LTC. When the traction is good enough this body is the fastest.
will the aggressiveness steering of this body making the tyres very fast overheating at rcaddict as the temp at BKK is quite high...?
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-14-2009, 09:29 AM   #770
Toh WL's Avatar
Thnaks man..
Old 12-14-2009, 08:24 PM   #771
Super Moderator
Grizzbob's Avatar
thanks
Don't mean to step in on Jilles, but I don't think that'll be a problem, the LTC-R does have slightly more aggressive steering, but I don't think it's enough to overheat anything(plus, it is also good for rear grip, it's still pretty well balanced, so I think you'll be ok, even in high temps). At least that's my take on it(& it's what I'm using right now & will take to the Novak Race next month)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 12-15-2009, 12:16 AM   #772
kschu's Avatar
thanks for d input.....
Old 12-15-2009, 08:44 AM   #773
Hi, Jilles
Would you please share the experience of Ride tyre process mode in RCA? For example, which tire tweak to use, how long to wait the tire tweak on tyres, the tire warm time and so on. I want to learn how to tune the Ride tyre on the right way.
Thank you very much
srw_g is offline   Reply With Quote
Old 12-16-2009, 10:16 PM   #774
JGH
Toh WL,
TRF drivers promote Tamiya but motors and batteries are free of choice.
I noticed the same that the steering linkage sometimes can get loose. When you use Titanium screws it works better then the standard steel screws. Loctite works always!
Kschu,
The LTC-R does heat up the tyre slightly more. But overall the LTC-R is still the faster body compare to Speed6.
srw_g,
Yesterday I ran the Ride tyre for the first time at RCA. I used Tyre Tweak for about 10min, works pretty well. No tyre warmer!
Jilles
JGH is offline   Reply With Quote
Old 12-17-2009, 06:11 AM   #775
kschu's Avatar
Toh WL,
Kschu,
srw_g,
Jilles
thanks
can share setting for RCA track ?
Old 12-17-2009, 06:37 AM   #776
JGH
Kschu,
Track condition change too much during the day. Heavier shock oil works good, like 700W, HB blue in day time, silver or even gold in front in nighttime is fast. Till now it's hard to say as I use only one set of tyres the last two days so maybe with new tyres my car will be different again.
Are you attending the Futuba Cup this weekend?
Keep you posted.
Jilles
Old 12-17-2009, 07:14 AM   #777
Senna Racing's Avatar
Jilles
thanks for sharing that you do on this tread
I have a few ? Regarding setup for titc
with average temps around the 29 / 30 mark
and temps in if feb set for 25 do you still use 700
weight oil or do you adjust spring rate
Do you know what motor will be used for 11.5 and if it is the
ride tyre that will be used
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 12-17-2009, 07:14 AM   #778
asw7576's Avatar
JGH,
Thank you for signing my trophy ..... ( Jakarta ). It's great honour to have your signature on my trophy. I'm glad to have that.... You are kind world champ driver
Old 12-17-2009, 10:51 AM   #779
Toh WL,
Kschu,
srw_g,
Jilles
Thank you very much
Old 12-17-2009, 11:04 AM   #780
kschu's Avatar
Kschu,
Keep you posted.
Jilles
thanks for the tips. i don't attend the Futaba cup but im confirmed joining the titc2010....hope to meet u in person...
