Old 11-25-2009, 10:17 AM   #736
Default long camber links
Hi Jilles,
What is the different handling of a long front camber link compared to a short front camber link.Also what is the difference between using 2 hole shock piston and 3 hole shock piston in front/
thank you
grouchy is offline   Reply With Quote
Old 11-28-2009, 04:59 PM   #737
crabboy's Avatar
Trader Rating: 58 (98%+)
Hi Jilles,
Thanks for the reply, its great that a team driver can take the time to answer questions, one of the main reasons i bought the 416WE.
I spoke with a few of the other drivers from this event (Aust titles) and a couple did try your TITC Worlds set up, but most agreed that running heavier shock oils made the car worse, some have told me they ran only 2 deg rear toe and 2mm of shims under the arms (roll centre change), can you please share your experiance with these changes on a hot track, thanks for your time.
Regards
Rhys
Originally Posted by JGH View Post
Crabboy,
You should have tried the worlds set-up from last year in Bangkok.
Also track temp of over 60 degree. All guys ran 700 or even 800Wt shockoil.
The HPI springs are still the best for asphalt. More things to avoid tyre overheating.
- raise front camber link from 5 to 6mm
- wider front, from c-c to d-d
- LTR body is not so suitable for extreme heat,
I prefer regular Mazda Speed 6.
Hope this helps as normally the Tamiya is the last car who has problems with overheating tyres!
Jilles
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 11-29-2009, 01:59 AM   #738
Superkarter's Avatar
I ended up running 40 weight oil with zero rebound and soft sway bars all round at the Aust Titles. Car was very well behaved and only over heated the tyres in one heat (Shortened the rear sway bar link)
I found that u needed to soften the car up to make it bite on that surface.
Regards
Tim
Superkarter is offline   Reply With Quote
Old 11-29-2009, 02:30 AM   #739
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Jilles,
The Australian titles track was not covered in traction compound like the 2008 worlds track was, and Sweep 40's were used. Would that make a difference?
dontfeelcold is offline   Reply With Quote
Old 11-29-2009, 07:15 AM   #740
DRAG_ON's Avatar
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 11-29-2009, 08:07 PM   #741
t4m1y4niac's Avatar
very nice weekend with Jilles in Sunter International Speedway, Indonesia.
Jilles was fast and consistent.
Jilles going home to Thailand today.
thanks Jilles for coming to Indonesia...
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 11-29-2009, 09:45 PM   #742
JGH
T4m1y4niac,
It was nice to meet you in Indonesia.
The race was really cool and I enjoyed it a lot! Especially after the race when we all race together!
Jilles
JGH is offline   Reply With Quote
Old 11-29-2009, 10:57 PM   #743
juki's Avatar
T4m1y4niac,
Jilles
Ps:
After the race,jilles borrowed a TC5 from one of the driver and took an extra race with others.and still he beats them...hehehe.it was a great all around race.
juki is offline   Reply With Quote
Old 11-30-2009, 01:54 AM   #744
Piyo Piyo's Avatar
T4m1y4niac,
Jilles
Hi Jilles,
On behalf of Indonesian racers, I thank you for your participation to our 2009 Year-End Race.
Many drivers learned a lot from you and we have a great time during the race with you. Please stop-by again if you have time. .
And thanks for repairing my ESC! .
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 12-01-2009, 04:48 AM   #745
Trader Rating: 45 (100%+)
Default Additional parts\hop-ups for 416X
Hi Jilles - What additional parts\optional parts do you recommend for the 416X for modified rubber tire carpet racing? Thanks in advance.
Apex is offline   Reply With Quote
Old 12-02-2009, 05:04 AM   #746
jonny123's Avatar
Default Orion Vortex Pro Race 2009
Hi jilles, Ive managed to order one of the new orion motors from a uk model shop. They look pretty kool. Could you tell me what you know about the motor. Ie rotors, timing, gearing etc. I'm getting a 5.5t to run with lipo on my pearl/gm esc.
Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 12-02-2009, 07:33 AM   #747
Toh WL's Avatar
Hi Jill,
Need your advice base upon experiences on stock motor 11.5 T.
Of all the brands below how they fare against each other for example
1. Speedpassion
2. Team Power
3. Orca
4. Team Orion.
To what I was told Team Power stock motor has more torque? What about the others. I do believe they have some plus points too.
Thanks,
Toh WL is offline   Reply With Quote
Old 12-02-2009, 11:08 AM   #748
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
Hi everyone.
What does installing o-rings on the shock shaft like on this picture of Victor Wilcks' car do?
h ttp://ets.redrc.net/wp-content/gallery/ets-0910-round-2-budapest-hungary/sat-wilcktrf416x-4.jpg
(remove the space in URL)
Acid_CZ is offline   Reply With Quote
Old 12-02-2009, 11:48 AM   #749
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
I think it's for stoping traction roll
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 12-02-2009, 01:38 PM   #750
94eg!'s Avatar
Trader Rating: 17 (100%+)
I thought it was used to set rebound. They keep you pushing the shock shaft up all the way while screwing on the lid...
94eg! is offline   Reply With Quote
