Old 11-21-2009, 10:14 AM   #721
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Originally Posted by Apex View Post
Jilles,
Any chance you know when the 416X(ray Killer) is being released?
Thanks!!
Dec 10 is the official release date.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 11-21-2009, 03:38 PM   #722
Stein Tumert's Avatar
Originally Posted by dodgeguy View Post
Your links do not work
Well, just edit them a bit and you will get it.
http://www.planet-rc.ch
http://www.racingfactory.fi/
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 11-22-2009, 04:19 AM   #723
Trader Rating: 45 (100%+)
Thanks for replies on the 416 release date!
Apex is offline   Reply With Quote
Old 11-22-2009, 04:03 PM   #724
jonny123's Avatar
Jilles, or anyone on here. Do you know when the new Orion voted motors will be released? (the ones shown at the euros) vortex 2010 I think it's called.
Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 11-22-2009, 05:51 PM   #725
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Jonny
vortex 2009 motor right ??
if yes, it's already selling online...checkout the online store...
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-22-2009, 08:51 PM   #726
JGH
Kraig,
Thanks for helping me out!
kschu, Senna Racing
I haven't tested that much at the RC Addict track. Also for the TITC they will have a new control tyre, I think it is Much More. Will keep you posted.
Drag-On,
See you soon!
Apex,
I haven't heard the release date of the 416X but I quess very soon.
Juki,
In most conditions the spool works better then a diff. Actually I only ran a front diff when I use foam tyres on carpet as with a spool I have too much steering. Go with the spool this weekend! See you friday!
Jonny123,
I will check with Orion but I quess it's already in the shops!
Jilles
JGH is offline   Reply With Quote
Old 11-23-2009, 06:12 AM   #727
Senna Racing's Avatar
thanks jilles
we have used 32 absolutes over here which are very fast of the mark.
but im sure it is new range if you guys havent used them much
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 11-23-2009, 11:16 AM   #728
jonest's Avatar
Jonny
tot I saw those at Hong Kong.
try http://www.rcmodel.com.hk/
jonest is offline   Reply With Quote
Old 11-23-2009, 11:41 AM   #729
jonny123's Avatar
kool yeh, ive just seen them on that website. That is the one i mean. I just need to find a shop in the uk that sells them. But those motors arent even on the orion website yet? so why have rc model got them?
Old 11-23-2009, 02:16 PM   #730
F-1
Hi Jilles!
What is the operation temperature for new orion motors?
F-1 is offline   Reply With Quote
Old 11-25-2009, 01:35 AM   #731
crabboy's Avatar
Trader Rating: 58 (98%+)
Hi Jilles
I have just raced at the Australian Nationals where the track temps were 60Deg C, all the Tamiya drivers suffered from the tyres overheating quite badly,
We ran on Sorex 36 tyres,med C inserts and Sorex rims, most were using no traction compound with some using tyre tweak with the same results.
Most were using your basic rubber ashphalt setup, can you please post what setup you would use in the hot conditions, the track was medium to high grip.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 11-25-2009, 03:14 AM   #732
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by crabboy View Post
Hi Jilles
Rhys
What springs were you guys using?
Most of the 416s I saw around the tables were were running HPI springs which cooked the tyres on the TOP when I tried them. I saw an immediate improvement when I switched to the TOP springs of the same weight. Go figure.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-25-2009, 04:27 AM   #733
crabboy's Avatar
We were using 50wt oil and HPI silver springs, between the Tamiya group we tried a lot of different set ups, some were slightly better than others but no real good ones.
Rhys
Rhys Marshall.
Old 11-25-2009, 07:53 AM   #734
JGH
Jonny123,
You are right that the motors aren't on the website yet. Some shops have them already in stock.
F-1,
Best temperature is around 75 degree celsius.
Crabboy,
You should have tried the worlds set-up from last year in Bangkok.
Also track temp of over 60 degree. All guys ran 700 or even 800Wt shockoil.
The HPI springs are still the best for asphalt. More things to avoid tyre overheating.
- raise front camber link from 5 to 6mm
- wider front, from c-c to d-d
- LTR body is not so suitable for extreme heat,
I prefer regular Mazda Speed 6.
Hope this helps as normally the Tamiya is the last car who has problems with overheating tyres!
Jilles
Old 11-25-2009, 07:58 AM   #735
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Could one type of spring be linear and the other progressive as it is compressed?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
