Old 09-15-2009, 01:09 AM   #616
if i change the steering spacer from 5mm to 4m what affect on the car does this have ???
this is one of the tuning ptions i have never changed or tried ??
sidecarphil1 is offline   Reply With Quote
Old 09-15-2009, 05:27 PM   #617
Hi Jilles
with the upcoming release of the new 416X do you know if our previous 416's can be upgraded to the 'X' spec like the first 416 was easily upgraded to the WE edition
what effect does laying all the shocks down 1 hole on the shocks mounts have to the handling please??
many thanks for taking the time to answer all these questions
mark
mark williams is offline   Reply With Quote
Old 09-22-2009, 09:42 AM   #618
Send a message via AIM to munrath
Jilles,
Do you know if the Tamiya one-piece thrust bearing will work on the Xray 008/009?
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 09-23-2009, 03:11 AM   #619
sudhar93's Avatar
Send a message via MSN to sudhar93
Hi Jilles,
Just have one question.Just like the difference between tamiya and HPI Springs,is the muchmore shock oil's different from Tamiya's?
Tamiya-LRP - Team Powers - RIDE -Sorex -Protoform - Sweep -Futaba - GQ
-------------Car Needs Minor Tuning, Driver Needs Major Tuning -------------
sudhar93 is offline   Reply With Quote
Old 09-30-2009, 12:50 PM   #620
I'm not so sure but Jilles won't use Tamiya TRF anymore, he will be moved to Team Orion.
Here below the information link:
http://www.redrc.net/2009/09/jilles-...at-team-orion/
Jilles many thanks for your suggestions, set-ups, and all that you having done during these years .
Regards.
lynx75 is offline   Reply With Quote
Old 09-30-2009, 01:20 PM   #621
Danny-b23's Avatar
Why would Jilles stop using Tamiya cars just because he switched to Orion motors?
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 09-30-2009, 01:37 PM   #622
TryHard's Avatar
hmmm....
Kyosho do own Orion
However... that article also mentions that Jilles will be using Shepard cars in on-road gas (not Kyosho's) and a Tamiya in 1/8th Off-road... so I would assume he's still running a Tamiya in 1:10th TC. Note there is no mention about him using Orion electric kit... just the GP engines...
Hopefully Jilles can pop on here and confirm/deny... the above is mostly speculation after all
Ed
| THard.co.uk | Xray | MuchMore |
Old 09-30-2009, 01:46 PM   #623
Send a message via MSN to Bigger Brother
Originally Posted by TryHard View Post
hmmm....
Kyosho do own Orion
Ed
He did mention a while back when talking about testing LiPo he was using Orion batteries. No-body seemed to pick up on it then It sounds from the RedRC article that now he's an actual employee of Orion, rather than just a driver
Either way, good luck Jilles, hope to hear more reports on how your testing is going and thanks for all your help! Hopefully it will continue for a long while!
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 09-30-2009, 02:16 PM   #624
Stephtruc's Avatar
Hi Jilles,
Searching for your last year set up for ETS first round at Kastellaun...
Do you still have it ?
Many thx.
Steph
Stephtruc is offline   Reply With Quote
Old 09-30-2009, 04:02 PM   #625
RedRC's Avatar
hmmm....
Kyosho do own Orion
Ed
Jilles will of course remain with Tamiya for both Electric Touring car, and now also for 1/8th off road, and has signed a deal recently for Shepherd for 1/8th and 1/10th gas on road.
Eoghain
RedRC is offline   Reply With Quote
Old 09-30-2009, 08:50 PM   #626
JGH
Hello all,
Just to let you know,
I will stay with Tamiya running their electric and buggy 1/8.
For Nitro I use Shepherd V10 and V8.
The deal I made with Orion is separate from which car I use.
Look at Andy Moore, Teemu Leino, Atsushi Hara just to name a few, do they run Kyosho?
Oke, keep this topic running!
Jilles
JGH is offline   Reply With Quote
Old 10-01-2009, 05:49 AM   #627
Hi Jilles
How do you fit your LiPo batteries in the TRF416 WE? I use Orion lipos and it is a flat pack, how do you keep it in its place? Just with the battery strapping tape?
Lilhill is offline   Reply With Quote
Old 10-01-2009, 07:56 AM   #628
artwork's Avatar
Trader Rating: 62 (100%+)
Originally Posted by JGH View Post
Hello all,
Jilles
Will you be switching the electronics for all of your electric stuff over to Orion as well? Motors and Speed controls?
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 10-01-2009, 02:27 PM   #629
smyka's Avatar
Send a message via AIM to smyka
JILLES good luck with the orion deal things are looking good with them again see you in febuary i hope
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 10-04-2009, 06:29 PM   #630
Hi Jilles,
I have a few questions regarding tire inserts selection. I understand this is a complex topic, but I hope you can help
1) Would you use harder tire insert for warmer or cooler track temperature? And please explain the reasons.
2) Basically, can you please share how you select the firmness of tire inserts? Please elaborate as much as possible, I am pretty sure your insights could benefic most racers.
3) Do you use firmer or softer insert when the track is cool and also high grip?
4) From your experience, does harder insert provides higher or lower level of traction? How about corner speed?
Thanks very much
billythekid is offline   Reply With Quote
