Old 08-30-2009, 01:44 AM   #556
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Thanks for all your help. I wanted to know when you were building your shocks are these the O RINGS you used?
MK-R01 Oil Mixed silicone O-rings 30deg. for shocks -Sky Blue
Thanks David
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 08-30-2009, 11:32 PM   #557
JGH
Sudhar93,
Not sure how long I will stay, 6 month to start with.
I hope to do some race in Malaysia soon.
gimpex,
When I go travel with airplane I always put my car and radio in my handluggage. All other stuff I put in normal luggage with clotch between the equipment so it doesn't got damaged.
Ramyuras,
Check set-up sheet.
MatsNorway
You better can check the speedpassion website about performance etc.
b-man777,
I prefer the Nosram over the Speed Passion speedo. Speed Passion speedo needs some more testing. Marc and Viktor using the Speedo and they perform very well with it.
kschu,
I'm sure the speedo that Marc and Viktor are using is a regular speedo that anyone can buy. Same with the SP motors.
dameetz
At the Worlds we used 6 cell 4.0T motor Gearing was 8.6 105/25
I used Tamiya spurgear with Xenon pinion. Marc used with fan, Viktor and me without fan, just personal feeling. And yes, you need to shim with or without fan differently.
Tom,
Thanks for your feedback. The reason I ran Nosram at the euros I have a deal with Nosram and my personal feeling is better with the Nosram speedo.
Cannon,
I will test some F104 and Mini so I will find good set-up for TITC! See you there!
Senna racing,
Life is good here, don't know many shops around Bangkok yet.
Marcel,
I'm still waiting for my F104, I will let you know when I have tested it.
Jonest,
I think Tamiya has a couple of types, I think yours is for drive-shaft and suspension ball.
David,
To be honest I still not have tested Lipo in my 416. I think till now any Lipo fits the 416. I never have any problem with steering slop. Pros and Cons, I think the 416 proved already to be the best TC on the market. I think that is the right O-ring.
Green Speed,
With the " simple" camber gauge you actually have the most realistic camber, with Hudy system there is always play between it.
I never use tweak board, I go with my own tweak theory.
Jilles
JGH is offline   Reply With Quote
Old 08-30-2009, 11:46 PM   #558
IQ0
IQ0's Avatar
Originally Posted by JGH View Post
Green Speed,
Hi Jilles,
when you said you use your own tweak theory, may you share with us how it works?
IQ0 is offline   Reply With Quote
Old 08-30-2009, 11:59 PM   #559
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by IQ0 View Post
Hi Jilles,
I believe he has in the Red RC videos.
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 08-31-2009, 12:15 AM   #560
Jilles what about the bulkhead clamp do you shim one side or both sides left and right 0.1 mm and do you shim the rear and front?
thanks David
Old 08-31-2009, 03:24 AM   #561
sudhar93's Avatar
Send a message via MSN to sudhar93
Jilles,
Thanks for your answers.I just have one more thing.Is there any way to avoid my F/R 1C Suspension block getting bent?
Tamiya-LRP - Team Powers - RIDE -Sorex -Protoform - Sweep -Futaba - GQ
-------------Car Needs Minor Tuning, Driver Needs Major Tuning -------------
sudhar93 is offline   Reply With Quote
Old 08-31-2009, 03:55 AM   #562
IQ0
IQ0's Avatar
...thought there is an extra "theory" besides the given theory in the video...
Old 08-31-2009, 09:11 AM   #563
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by sudhar93 View Post
Jilles,
Switch to the TA05 Ver-2 "Split" blocks for that spot. 4 screws so you can rest assured it won't bend...
http://cgi.ebay.com/Tamiya-TA05-ver-...d=p3286.c0.m14
94eg! is offline   Reply With Quote
Old 08-31-2009, 09:32 AM   #564
dameetz's Avatar
Yep I just bought that...though I ve never bend mt F/R block before...anyhow just one q, is there any 0.5 or 1mm shims for that?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-31-2009, 11:58 AM   #565
sim600's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to sim600
Jilles,
Just noticed from watching the fifth RedRC video that you were using FM (that long TX antenna). Any reason you didn't switch to 2.4Ghz?
sim600 is offline   Reply With Quote
Old 08-31-2009, 12:25 PM   #566
cyanyde's Avatar
He's saving up for a good 2.4..
cyanyde is offline   Reply With Quote
Old 08-31-2009, 01:05 PM   #567
Originally Posted by sim600 View Post
Jilles,
I heard that FM still has better response than 2.4.
redbones is offline   Reply With Quote
Old 08-31-2009, 04:41 PM   #568
veecee's Avatar
No shims at the moment, I believe.
Old 08-31-2009, 04:57 PM   #569
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
Just wanted to post saying that i really enjoyed the videos on RED. Been doing this for over 20yrs, and to see a pro sit down and go over the finer points with his car is fantastic. Can only it hope it reaches some of our younger racers who could see this work is what makes the difference along w/practice. I don't have a tamiya touring car, but even i picked up at least 1 thing out of each video. Really like that diff ring block. One of those 'why didnt i think of that' moments.
Way i see it, you sat down and gave us a bunch of your time to help us. The least i could do is voice my appreciation for it and perhaps give you a small piece of advice from something i do.
Before you start taping, have your cameraman (or yourself) roll tape of the room no movement no talking etc for at least 1min, perhaps 2 to get a nice block of what we call 'room tone'. take this audio track (trash the video) and when you transfer/edit/mix your piece and lay it down underneath your main audio tracks for the entire video. This way your video sounds continuous and you have no jagged breaks/stops in your piece or your voice. Its a simple yet mandatory procedure in the film/video world, but it will help any video turn out even better.
Thanks again, all the best.
RW
UltegraSTI is offline   Reply With Quote
Old 08-31-2009, 08:57 PM   #570
JGH
IQ0,
In the videos you see exactly how I tweak my car before I run on the track.
David,
I use 0.1mm shim under all bulkhead clamps.
Sudhar93,
As 94eg suggested, use TA-05 blocks, we also have used them at the last euros and these are more consistant and they don't bend when you have hard crash.
Dameetz,
You can use regular shims under those blocks.
Sim600,
I'm still not 100% sure about 2.4GHz
Ultegrasti,
Thanks for your comment and also your suggestion.
This was the first test to make a video like this together with Eoghain from Redrc. For sure we can improve many things but we had to start somewhere. I'm sure the next videos will be better again.
Jilles
