Old 08-19-2009, 01:04 AM   #526
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default How weight placement affects steering
JGH
when you are adding weights to your car (assuming L to R is equal).. where do you place your weights (front of the car or rear?)..and how does that affect steering?
thanks!
- Chris
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-19-2009, 01:25 AM   #527
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by Hebiki View Post
JGH
thanks!
- Chris
if left n right is balance.. then u should add weight in d middle....
just my 2 cent
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-19-2009, 03:17 AM   #528
veecee's Avatar
Trader Rating: 34 (100%+)
just my 2 cent
I think the question is more about how FR:RR weight distribution affects handling...
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 08-25-2009, 04:55 AM   #529
JGH
Hello,
Sorry for late reply, will try to keep up again on the forum.
Veecee,
We started to test without the steering brace for the euros.
I think it gives more steering going into corner but less stable in the corner.
Later in the race at the euros I tried the brace again and it felt better for me. More smooth feeling, less flex of the chassis.
Team Elli,
I know a few years ago Paul Lemieux won Cleveland with a standard 2.5mm Xray chassis. So 2.5mm chassis might work for foam tyres. I think some pages back you find a basic set-up for foam tyres.
Oli,
Thailand is good so far, got little sick due some food poison but further all it's nice. I have the privalige to practise with Atsushi and also play little with mini class and F-1.
The reason I ran 0.5mm higher(lower rollcenter) was better cornerspeed, keeps the car more flat in the corner and because of highspeed sweeper.
Roborat,
When is a race overthere?
Jonest,
We definitaly working on better performance, but it's not so bad!
We all use diff cover of tape, i think it's best solution. If you don't crash to hard, the spool outdrives are fine!
Chris,
More weight in front of car means little less steering. More weight in the rear more steering.
Till next time,
Jilles
JGH is offline   Reply With Quote
Old 08-25-2009, 07:53 AM   #530
sudhar93's Avatar
Send a message via MSN to sudhar93
Jilles,how long would you be at Thai?If you have time and youre free drop by to visit malaysia ya!
Tamiya-LRP - Team Powers - RIDE -Sorex -Protoform - Sweep -Futaba - GQ
-------------Car Needs Minor Tuning, Driver Needs Major Tuning -------------
sudhar93 is offline   Reply With Quote
Old 08-25-2009, 10:46 AM   #531
Default Travel and transport
Hi Jilles,
Not sure if this was asked before.
If you transport your gear (car/spares/tools) inter continental , how do you do that? What do you carry your gear in , what do you take etc
Or is it all provided by sponsors at track ?
gimpex is offline   Reply With Quote
Old 08-25-2009, 10:50 AM   #532
IQ0
IQ0's Avatar
Hi Jilles..you've got PM
IQ0 is offline   Reply With Quote
Old 08-25-2009, 11:14 AM   #533
Anyone can answer this ? where is the #1to4 hole on the short arm?
does it start from the closest hole to the wheel?
Ramyuras is offline   Reply With Quote
Old 08-25-2009, 11:25 AM   #534
Default Powerfull you say?
hi Jilles Groskamp
Could i get to know these things about the speedpassion competition 2.0 motor?
and the most powerfull speedpassion 10,5T motor?
power output (7,2V or 6.0V): Watts
efficiency:
Kv
weight: gram
star or delta wiring.
MatsNorway is offline   Reply With Quote
Old 08-25-2009, 12:30 PM   #535
b-man777's Avatar
Default speedpassion esc
Hey Jilles: I know your running a nosram,but why are there so many drivers running speedpassion motors,but not their esc? Thanks for the info and good luck to the team at the '09iic race.
b-man777 is offline   Reply With Quote
Old 08-25-2009, 06:52 PM   #536
kschu's Avatar
i saw marc n viktor r running sp esc during the euro....but im sure tat is the TEAM esc which we cant get it....
Old 08-25-2009, 11:24 PM   #537
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
jilles: we have an HPI Challenge Series coming up in September then after that we are hoping to push through with our annual Manila Touring Car Championships sometime late November or early December. But we still need to finalize the MTCC details. Will just let you know if anything comes up that might be interesting for you.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 08-26-2009, 10:03 AM   #538
dameetz's Avatar
Jilles, which SP motor turn do you normally use with 6 cells sub C or 2 cells lipo batteries? With or without the internal fan? If you take off the fan do you need to shim the rotor the same thickness as the fan? What FDR do you use with that set up? Can you give details like Spur and pinion T? And what brand of those gears are you using?
Thanks.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-26-2009, 11:02 AM   #539
Hebiki's Avatar
JGH
thanks!
- Chris
Originally Posted by JGH View Post
Chris,
Till next time,
Jilles
thanks Jilles. quoted this for easier reference for other people. Good luck at your next race.
- Chris
Hebiki Design Works
Old 08-26-2009, 11:52 PM   #540
Tbone13's Avatar
Hy,
I think's thats weong because Marc, Jilles and Yannic used a normal SP GT2.0 in Blue like everyone can buy. the nly thing they play around was with the capacitator because the original one is a little bit large.
I also run the GT2.0 and tried the first time at the Euros. I think it's a great ESC with an excellent feedback.
Why other people like Jilles run an Nosram or a LRP or a GM to not forget them I think its something like they have a sponsoring with that brand.
@Jilles if I'm wrong please correct me
have fun in Thailand ..
regards Tom
Tbone13 is offline   Reply With Quote
