Old 08-14-2009, 05:36 AM   #511
JGH
I arrived last weekend in Bangkok.
JGH is offline   Reply With Quote
Old 08-14-2009, 06:00 AM   #512
Jilles you have PM.
Ramyuras is offline   Reply With Quote
Old 08-14-2009, 06:06 AM   #513
veecee's Avatar
Trader Rating: 34 (100%+)
Hi Jilles. Does removing the steering brace give more flex and so more steering - entry, mid corner or exit?
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 08-14-2009, 11:54 AM   #514
Hi there!!
I was just wondering if the 416WE chassi kit is suitable for foam tire racing? if not, is there any options out there so it could be suitable for it? any advise is helpful since i really want this kit, but rubber tire modified/Stock is not so popular here, and 10.5 foam spec W/lipo class is the most popular class here.
Ohh i forgot to say our track is about medium grip i would say.
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 08-15-2009, 03:11 PM   #515
Send a message via MSN to Bigger Brother
Hi Jilles. I hope you are enjoying Thailand!
Hopefully a quick question - I see many of your setups now use an extra 0.5mm under the front blocks - ie running 0.5mm on the front front block and 1mm on the front rear, rather than 0 and 0.5. Can you explain what this does to the car, and would this now be your 'standard' starting point? (If not, what would make you switch to it?)
Thanks in advance!
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 08-17-2009, 09:53 PM   #516
jonest's Avatar
Thread Bump.
jonest is offline   Reply With Quote
Old 08-18-2009, 02:22 AM   #517
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Jilles: time to come over to Manila! remember during the worlds we talked about this with scotty and the rest of the Philippine contingent. haha ... anyway, good to know you're in the Asia Region. Bangkok is always great fun! Good luck racing!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 08-18-2009, 06:10 AM   #518
Bigger [email protected] good question i want ask the same
orzel24 is offline   Reply With Quote
Old 08-18-2009, 10:52 AM   #519
94eg!'s Avatar
Trader Rating: 17 (100%+)
Thanks in advance!
Oli
This raises the front roll center while maintaining the same amount of anti-dive. I think it's done to increase front roll stiffness. As for how that makes the car drive, I have no idea...
94eg! is offline   Reply With Quote
Old 08-18-2009, 11:07 AM   #520
jonest's Avatar
We tried this setting during our last weekend meet and the car handles far more better. The only thing we haven't try was raise the rear roll centre by another 0.5mm (1mm in total on both rear toe blocks). We'll certainly try it this weekend.
Jilles, we're certainly having fun with the car with your invaluable tips and tricks however we hope to see some minor hop ups which will make the car edge further perhaps? eg:-
1) Ball diff pulley cover - to reduce dust / dirt (thou we use stickers for time being)
2) More durable / easier to replace spool cup
Maybe you could feedback to Japan if ur agreeable to the above suggs.
Dank u
Old 08-18-2009, 12:55 PM   #521
94eg!'s Avatar
Jilles,
I'm not sure, but I think I remember reading in one of your posts you run the TRF fluorine sealed bearings. If so, how do you go about cleaning the grime off the outside?
I used a small soft makeup brush to dust them off and it seemed to push a lot of grit inside past the seal. At least that was the case for the large 1510 diff bearings...
Old 08-18-2009, 03:14 PM   #522
HI_808's Avatar
Oli
What kind of difference is there between using 0.5 mm under the blocks and using hole #1 for the inner camber links? I know that they both raise the roll center, but is it just a matter of how much?
HI_808 is offline   Reply With Quote
Old 08-18-2009, 03:36 PM   #523
94eg!'s Avatar
Messing with the lower control arm mounts has a much more drastic effect on roll center than the upper camber link. Here's a pic I made to demonstrate. Both the upper & lower link are moved the same amount, but look at the difference in RC change between the two (first is upper link, second is lower link):
Old 08-18-2009, 03:41 PM   #524
Johnny Wishbone's Avatar
You could plug the numbers into the advanced rc calculator on tryhards site to see the differences.
Old 08-18-2009, 04:35 PM   #525
veecee's Avatar
Jilles,
I never touch my bearings or brush them off, etc. The coating of dirt/dust on the outside actually provides a protective barrier. I only replaced my bearings recently after owning the car for 18 months and running at least fortnightly. And that was only because 2 bearings felt gritty - these were the outside rear axle bearings - all the others were totally grit free despite having dirt on the outside.
