Old 07-22-2009, 12:46 PM   #451
Senna Racing's Avatar
Jilles
when you talk about using the 2.5mm chassi is this the 416, or is there a 416we 2.5mm chassi
best of look with the nitro
thanks wayne
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 07-22-2009, 09:49 PM   #452
quantum's Avatar
Originally Posted by quantum View Post
hello,
on outdoor pavement, i am finding the car slows down too much mid-corner and i have to wait too long to get back on the throttle. what settings should be adjusted?
thnx!
Originally Posted by JGH View Post
Quantum,
Raise the rollcenters in the front and rear by 0.5mm this increase cornerspeed.
Harder spring in front might help as well.
Jilles
jilles, do you mean lower the inside camber links by 0.5mm ?
thanks!
quantum is offline   Reply With Quote
Old 07-22-2009, 09:57 PM   #453
thanks!
He has said before that he rarely changes the upper links, and will only add the extra 0.5 to the lower arm mounts.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 07-23-2009, 12:28 AM   #454
ab1105's Avatar
Trader Rating: 20 (100%+)
Have you ever used the new separate TA05 suspension arm mounts? Is it possible to use this on the 416WE? The 416 and 416WE have 2 additional holes that appear to allow this to be mounted up. Perhaps with the closer 2 holes the suspension mount would bend less in a collision? Let me know if you think this is a good idea...
ab1105 is offline   Reply With Quote
Old 07-23-2009, 12:49 PM   #455
TryHard's Avatar
I don't know if Jilles was running them, but a few of the team were at the last ETS.
you can just see them mounted on the rear of the car here, in the bottom right
http://ets.redrc.net/wp-content/gall...amiyatable.jpg
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-23-2009, 02:09 PM   #456
Originally Posted by 3.141592 View Post
Hi Jilles,
Got a question on this comment from you.....
"Most of the time I use the old 416 chassis, sometimes the WE chassis. WE is easier to drive but less steering then the old chassis. In general 90% we use the old 2.25 chassis."
I thought for the WE chassis, the battery position sits more to the front and should be more steering compared to the old chassis...at least i think that most tamiya guys around here is marketing the 416WE that way...
When I received my 416 WE in January I compared the main chassis plate stiffness to a 416 plate and i found that my WE plate was about 10 -20 % softer, that is according to my non-scientific lab test
moonman is offline   Reply With Quote
Old 07-23-2009, 03:53 PM   #457
sonic31's Avatar
hello jilles, i built a slipper spool using the tamiya parts and slipper pads from assoc. and was wondering if you have seen or heard this done before and what type of results it gave? thanks
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 07-25-2009, 12:39 AM   #458
Default HELP
HELP NEED STEERING?????
I have 416 WE with jillies set up & sorex 36s the car pushes med & exit,running ltcr body felt better,but what made the most difference was running hole 1 on the steering knuckle.
any help would be good
thanks
ghost rider is offline   Reply With Quote
Old 07-25-2009, 01:04 AM   #459
Stein Tumert's Avatar
thanks
You could try a bit sweep on the front running D (FF) and C (FR) blocks + add a 0.5 mm shim under the C block.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 07-26-2009, 07:04 PM   #460
ab1105's Avatar
Jilles....what servo brand/model are you using in the 416?
Also, do you run your steering lock to lock from left to right? If not, how do you determine if your steering is even from left to right?
Old 07-28-2009, 12:02 PM   #461
thank you for the latest video Jilles
+ YouTube Video
sidecarphil1 is offline   Reply With Quote
Old 07-29-2009, 11:57 AM   #462
bigz's Avatar
is it possible to adjust the timing on sp ultrasportsman series motors?
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 07-29-2009, 12:37 PM   #463
jonest's Avatar
Heya Jilles,
Best of luck at EC and bring back the silverware for Tamiya would ya...
Btw, are u guys allowed to keep the silverware or has to be brought back to Japan for showcase? Just out of curiosity hope u don't mind...
jonest is offline   Reply With Quote
Old 07-29-2009, 01:05 PM   #464
jonest's Avatar
Apparently, there are 2 types, one can while the other can't. We can't adjust on those bought off the shelf (we're using 11.5t & 10.5t) but you can on some hand out motors (TITC & KLGP).
Hope this helps.
Old 08-02-2009, 11:41 AM   #465
gefeliciteerd Jilles on your ETS championship and the Euros
