Old 06-16-2009, 11:24 PM   #331
Originally Posted by BlueBird View Post
.........and your problem is? Who made you the cyber cop wannabe?
I dont give a rats ass if you do or do not have supply issues.
and i dont give a rats arse if you do have parts issues
stop clogging good topics with carp comments
i'm sure if you have issues with a tamiya supply then take it up with Mr tamiya
he will listen !!!
if not keep it to PM's !!!!
sidecarphil1 is offline   Reply With Quote
Old 06-16-2009, 11:34 PM   #332
he will listen !!!
Did I asked anyone if they are having issues with parts? it is you , smarty pants , giving you opinion of part availability.
This crap (not carp, get it in your head) would not start if you kept your crap comment to yourself no go play by the canal and leave this topic alone
BlueBird is offline   Reply With Quote
Old 06-17-2009, 05:41 AM   #333
jonest's Avatar
guys, please keep on track with the thread topic please.
jonest is offline   Reply With Quote
Old 06-17-2009, 11:45 PM   #334
doriftu's Avatar
Jilles,
what bearings do you use?
How do you maintain or clean those TRF fluorine sealed bearings? Some of my bearings the fluorine seal is interfering the balls causing it not to be smooth.
Thanks.
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 06-19-2009, 06:38 AM   #335
Tbone13's Avatar
Default Luxembourg setup
Hy Jilles,
congrats for your dominaton on the Eurotrack in Luxembourg
I was having a lot of problems with my tires and also a little badluck in the B final
can you post your setup from that day with the new tires ? this yould be really nice ..
see you next week on the warm up.
regards Tom
Tbone13 is offline   Reply With Quote
Old 06-19-2009, 10:25 AM   #336
JayL's Avatar
yes! A step by step from when you first get your handout tires would be nice
JayL is offline   Reply With Quote
Old 06-20-2009, 11:49 AM   #337
Hi
In your opinion what susp. mounts is the best for Pro Stock class? In Apeldoorn I drive 1XB/1A front and 1XA/1E rear. I have to little corner speed. What should i change? Pls think about Andernach track beacous i set up car for this ETS Event.
And what do you think about use one way in front in Andernach?
Thank's
orzel24 is offline   Reply With Quote
Old 06-20-2009, 07:58 PM   #338
DRAG_ON's Avatar
Jilles have you ever try to drive 415 Msx or MSXX??? will your setting setup works on 415 msx car? i know it's different car.I look at your basic rubber set up i wonder will that setting works on 415 MSX? and i also would like to ask if you have set up for 1 way transmission for stock race (23 turns) ? thanks in advance
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 06-20-2009, 10:57 PM   #339
auzzy_mate's Avatar
Default Weather Setup Changes
Im asking for some setup help in relation to the car over the changing conditions of a full day. In the morning we start on a track with temps around 20 degrees celcius and finish the day at about 35-40 degrees celcius. What would you reccommend I do? Thinner oil / tyre change (rubber 28-32-36) etc etc?
Ben
auzzy_mate is offline   Reply With Quote
Old 06-23-2009, 07:12 AM   #340
3.141592's Avatar
Hi Jilles...busy testing??
Got a question...in your opinion when would you choose to use the 2-piece upper deck and when to use the one-piece deck (WE)...
Are you still using these two upper-decks as one of the setup changes in your recent races?
Thx!!
3.141592 is offline   Reply With Quote
Old 06-23-2009, 08:53 AM   #341
IQ0
IQ0's Avatar
Jills, whats the importance & the main reason of true-ing tires (foam) when race on-road & carpet?
IQ0 is offline   Reply With Quote
Old 06-23-2009, 09:22 AM   #342
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hi Jills
i copy your world set up and I like to know if you could tell me how can I get more mid turn off power into the corner and more corner speed....
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 06-23-2009, 02:14 PM   #343
JGH
Kschu,
If you want to built the shock without rebound you can't use a sponge.
I never use a sponge.
Home13oy75,
I never ran the 415 but basic set-up like rollcenter, track width, wheelbase will also work for the 415.
Doriftu,
I don't use oil or clean the TRF ball bearings, I run them out of the box.
Most of the bearings I use for longtime.
Tom,
My set-up of the warm-up race is very simlair to the basic set-up.
I raised the rear rollcenter using 1mm under the arms.
Shock oil 500W front and rear. Front blocks C/C with 0.5 anti-dive
Speak to you upcoming weekend in Luxembourg!
Orzal24,
For pro stock you should use C/C with little anti-dive (0.5mm)
I think a spool is always faster then a one-way, especially a track like Andernach where you really have to brake also with stock.
Drag_On,
I never used the 415. I think when you want to use a one-way, make the car little wider in the front.
Ben,
When you run in cooler condition you should use thinner oil with softer tyres.
When the track temp gets hotter go to thicker oil, same springs or softer amd go to harder tyres.
3.1415926
I think I had this question before.
Most of the time I use the WE topdeck outdoors, sometimes I use indoors the double topdeck with the rear brace. The rear brace makes the car more stiff in the rear for better rotation in the corner, less grip.
IQ0,
Well, with foam racing, especially on carpet you want to use a small tyre.
A smaller tyre will drive better and more easy then a big tyre. Big tyre makes the car roll more and more chance to traction roll. On carpet we cut the tyre down to 57mm.
Goingfast,
For more cornerspeed try a harder spring. Also raise the rollcenter will help.
Mid turn off power, make the rear more stiff, lay in the shock.
Jilles
JGH is offline   Reply With Quote
Old 06-23-2009, 02:28 PM   #344
Francis M.'s Avatar
Congrats on taking TQ at turkey...
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 06-23-2009, 03:43 PM   #345
Just to say thanks to Jilles to support us and thanks to you all to keep this thread on topic.
My TRF 416WE is now out of the box, ready to run and give me a lot of fun.
lynx75 is offline   Reply With Quote
