Old 06-08-2009, 03:13 PM   #316
auzzy_mate's Avatar
Default HB Springs
Gday from Australia,
I read a lot about people using about the HB Silver(#6543) / Blue Springs(#6542). Are they actually the HPI Pro4 Springs?
I have a good range of the normal HPI Touring Springs (27x13.5, #6846 13.8, #6847 14.8, #6849 15.2, #6850 16.9) and was wondering what the major difference is other than length (25mm v 27mm)?
Ben
auzzy_mate is offline   Reply With Quote
Old 06-08-2009, 07:21 PM   #317
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi jilles, may i know what is the effect of adding shim for bump steer?
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-09-2009, 01:05 AM   #318
HI_808's Avatar
Ben
Yup, those are the springs.
HI_808 is offline   Reply With Quote
Old 06-09-2009, 10:04 PM   #319
Hi Jilles,
What will you change from the basic asphalt set up for a small,high traction and lots of conrner track? Add more RC in order to get more respond or reduce RC in order to get more grip at conrners as my car is still a bit push during the double apex? Thank you.
Sunny
sunnymok is offline   Reply With Quote
Old 06-11-2009, 06:31 AM   #320
jonest's Avatar
hi Jilles,
Sorry for the off-thread question, what shock setting would u suggest for 1/10 buggy? Thanks
jonest is offline   Reply With Quote
Old 06-11-2009, 04:45 PM   #321
mutley001's Avatar
Hi Jilles
Just wanted to say thanks for the help and setup advice given on this thread, its helped me go faster with this car than I thought possible (well for my thumbs anyway!) I'm now just down to a few tenths per lap off the leaders at my local club and am very happy with the Tamiya.
Just one question about tyres though, should you run the hardest compound you can get away with or the softest?
Cheers again!
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 06-11-2009, 05:39 PM   #322
Danny-b23's Avatar
Originally Posted by mutley001 View Post
Hi Jilles
Cheers again!
Paul
I'm not Jilles, but I would say hardest to try to keep tire wear down.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 06-12-2009, 10:27 PM   #323
subscribed
Mayor*Philthy is offline   Reply With Quote
Old 06-15-2009, 01:31 PM   #324
JGH
Hello Guys,
Sorry for late reply.
3,1415926
The reason I used 0.5mm and 1mm front is to get better cornerspeed.
I tried first 0mm and 0,5mm but the car didn't kept the speed in the fast corners as good as with 0.5mm and 1mm.
Ed,
I think for tracks like Halifax this will work great.
CraigM,
As I explain to 3,1415 already with the rollcenter in front.
Sudhar93,
For 11,5T I suggest a gearing around 4.5
As far as I know Tamiya has no plans yet for a new TC as the current 416 isn't bad! Haha! Not sure if they make a new batch.
kschu,
I never really played with shims for bumpsteer, the standard 0.5mm works best in my opinion. I will do some tests for this at the Euros track in Luxembourg in a few weeks.
Sunny,
For tracks with a lot of traction the balance of the car is little more pushing.
To improve steering I suggest to narrow the car front and rear, c/c and XB/1E
Also lay in the shocks in the rear. Harder spring also helps.
The new LTC-R body shells has good steering.
Jonest,
I have been in contact with Hupo Honigl about off-road and he says for shock set-up use shock oil between 25-40W, standard piston. But ofcourse depends on surface.
Paul,
Thanks!
I think you should look around and check what the fast guys are using for tyres/wheels and inserts. Inserts and wheels can be also as important as tyres. Sometimes a harder tyre is faster even when the track conditions are cool. Ofcourse with 24R tyres you will be really fast when they are new but they might fail during the run as they wear out very fast.
Jilles
JGH is offline   Reply With Quote
Old 06-15-2009, 06:18 PM   #325
kschu's Avatar
Originally Posted by JGH View Post
Hello Guys,
kschu,
Jilles
i saw your setup that your shock have no rebound. do u still put in the sponge bush on the bladder??
Thanks jilles...
Old 06-15-2009, 11:36 PM   #326
sudhar93's Avatar
Send a message via MSN to sudhar93
Thanks for the reply Jilles...Haha..416 is a great car its just that since they stop producing it,many of my friends are waiting for these car or any new car for tamiya as they see how good is the car......Thanks!
Tamiya-LRP - Team Powers - RIDE -Sorex -Protoform - Sweep -Futaba - GQ
-------------Car Needs Minor Tuning, Driver Needs Major Tuning -------------
sudhar93 is offline   Reply With Quote
Old 06-16-2009, 03:13 AM   #327
It is a shame that parts availability of the 416 is so hard to come by and that is one single reason why I decided to junk Tamiya for another marque, sorry, I want to keep my kit running all the time.
BlueBird is offline   Reply With Quote
Old 06-16-2009, 08:18 AM   #328
I have a 415 MSX and installed the new short arms. Should I be looking at setup sheets for the 415 or following setups in this thread?
home13oy75 is offline   Reply With Quote
Old 06-16-2009, 10:29 AM   #329
whats that got to do with Jilles ???
he doesn't make the parts !!!!
i have no problems with parts supply
sidecarphil1 is offline   Reply With Quote
Old 06-16-2009, 07:50 PM   #330
.........and your problem is? Who made you the cyber cop wannabe?
I dont give a rats ass if you do or do not have supply issues.
