Old 05-11-2013, 07:50 AM   #1981
peter.'s Avatar
hello jilles
do you use the new orion 8000mah lipo
greetings peter
peter. is offline   Reply With Quote
Old 05-15-2013, 09:41 AM   #1982
Originally Posted by TheHoofmeister View Post
The best way for me so far:
- Take the big gear and sand it down till 3.57mm, standard is 3.65mm
- sand down the small gear just till they are smooth
- Use 0.1mm shim on both sides on the outside between the outdrive and gearbox
- use 0.3mm shim under the big gear.
This should give a smooth gear with long life!
Hi JG
Looks like I may well have a new TRF V5 by next Wednesday , my order has just arrived!
I was wondering on how to go about the diff build. I have been reading this forum thread and build guides on petitrc by kentech. Is the V5 diff the same internally as the 417x and if so should i follow your instructions above? If not, what do you recommend for building a strong, reliable and long-lasting diff?
The other question in my mind is regarding the suspension mount setups for the front and rear. The kit comes with separate front and 1 piece rear. I will be starting off running indoor medium-high grip tracks. Will this be okay as I have heard some say to use 1 piece front and separate back for more flex?
Many thanks for any help you can provide on this.
Scott
It's arrived!
Hi Jilles,
Know you're probably busy but any help with the above would be greatly received. I have been looking at setup sheets and it seems that some drivers are using separate front and rear inner suspension mounts so not really sure if to use 1 piece or separate now, all a bit confusing as to what will give what results.
Q for anyone - anyone have or know where i can get the part numbers for the titanium turnbuckles?
Thanks to all
TheHoofmeister is offline   Reply With Quote
Old 05-15-2013, 04:51 PM   #1983
hi i am new on rc tech forum .. i need help with tweak of the trf 417 chassis , i have seen the jg video part 4 of tweak but i dont understand the process of tighteen screws , i mounted like manual and first tight the downbulkheadas put the upperbulkhead then subchasis and towers , can somebody tell how i have to do it ,please the chasis with all mounted is not flat viewing the car towards to me (facing the driver) its litle up in the front right side and litle up in the rear left side i dont understant, i have repeated the mounting pocess lot of times and the problem continues.
thank you very much
Javier Bas is offline   Reply With Quote
Old 05-30-2013, 06:23 AM   #1984
Hi Jilles, is there a base droop setting front and back that would be suitable for carpet on the 417 v5?
Also do you recommend using drag brake?
rayrush is offline   Reply With Quote
Old 07-09-2013, 06:26 AM   #1985
Default ETS Final Race in Slovakia
Hi Jilles,
Congrats. for your last title
I am usually race in carpet track & I have absolutely zero experience for asphalt tracks.
What will be my Team Orion R10 Esc & VST 4.5T motor adjustments for Hudy Arena Track !? Can you suggest me start up setup & changes I'll make ?!?
Thanks...
Team Xray T4 '16
Team Xray X1 16
Team Xray XB2
Team Xray XB4 16
Team Associated T5M
ringa is offline   Reply With Quote
Old 08-15-2013, 08:32 AM   #1986
G-rem's Avatar
Hi all,
does anybody knows if there will be a new Orion speedo becoming available in the next few months to replace the "ageing" Vortex R10 Pro?
Thanks for reply,
G-rem
G-rem is offline   Reply With Quote
Old 10-03-2013, 01:44 PM   #1987
Default Vst2 motors
Hi
When you get the motor from factory , its timed in the middle . But what do the different marks means? Is center 0 degrees or is it 20 degress. And what is the jump in degress between the marks ? Hope my questions make sence
Thanks Andy
HB-forever is offline   Reply With Quote
Old 10-05-2013, 07:37 AM   #1988
Hi JG,
Can I know what servo you are using in your car?
faifaisalfal is offline   Reply With Quote
Old 10-23-2013, 03:30 PM   #1989
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
anyone know if the 417/417x/417/v5 chassis will bolt on to a 416?
JQ THE Car YE teknoV4/xerun150/t81400/savox1256tg
Tamiya TRF-416/s6040/vipervtx10R/ killshot 17.5
kyosho scr-sp/sanwa94770/hobbwing 90a/atomik 13.5
futaba 4pl
84 GT 5.0 is offline   Reply With Quote
Old 10-23-2013, 05:06 PM   #1990
Tron's Avatar
Trader Rating: 17 (100%+)
No it will not.
Brett H
"D-Main Specialist"
Tron is offline   Reply With Quote
Old 10-23-2013, 11:07 PM   #1991
84 GT 5.0's Avatar
is the 416 a good beginner car?
are all the 3 racing parts for the 416 any good?
futaba 4pl
Old 10-24-2013, 01:03 PM   #1992
chasingthepack's Avatar
jilles hasnt posted on this thread since february,good luck getting a responce
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-24-2013, 01:54 PM   #1993
TENCHO's Avatar
So, I have a first gen TRF416, I have the Exotek Lipo chassis upgrade, but honestly I don't think it was needed. anyway, last night I tried to race the car on carpet, and it was a mess. my setup was close to box stock, 5mm ride hi, rubber tires...my car sucked. I have new tires, new body...etc...car is fast, I have the speed, but no handling. I think 1 reason is that I am still running a front one way, and the other reason why I think it sucked so bad was that the Exotek chassis is was too stiff. i'm gonna switch back to original chassis and put in a front spool. if that don't work, i'm gonna retire the whole chassis....I'm ready to throw it against a wall!
Jesus Sierra-
Stock Touring 17.5-TamiyaTRF416/Exotek/SpecR mix
VTA-SpecR R1/Novak Ballistic 25.5
F1-VBC LightningF
TENCHO is offline   Reply With Quote
Old 10-24-2013, 01:56 PM   #1994
TENCHO's Avatar
3racing parts good for 416?....it's not really needed, unless replacement
is the 416 a good beginner car?.....NO!
Jesus Sierra-
F1-VBC LightningF
Old 10-25-2013, 06:17 AM   #1995
Hello,
I have a TRF hard black coated damper set, is there a real difference between hard black and HL cylinder? thanks
Rally-game proto Clo-products - Toro 150a - HW 2250kv - Turnigy a-spec - Futaba 3PKS
Tamiya M03S mini cooper - Novak 410M1C - Orion Core 27x1
Kyosho Mini-Z MR03 and MA015
Xray T4-2014 - Hobbywing V3.1 - LRP X20 spec 10.5 - Turnigy ultimate
Xray X12-2014 - Reedy Mach2 6.0
christophed83 is offline   Reply With Quote
