Old 02-22-2013, 12:29 AM   #1966
Hi Jilles,
I got a 417 the chassis broke at the rear screw sus mount. then i got a 417x chasis 2.5mm. agin my 417x chassis broke at the same place ......
do you advice i should just get the v5 lower deck USD85 n Servo mount USD30. or stick to the x chassis.
If get the v5 chassis should i also go up grade with upper deck USD20, Front damper USD13.20 Rear damper stay USD15.40....would it be worth it?
grauco is offline   Reply With Quote
Old 02-22-2013, 03:39 AM   #1967
sir what esc and motor you are using for open modified class? or what do you recomend?
canon is offline   Reply With Quote
Old 03-01-2013, 07:12 AM   #1968
Hi Jilles,
May i have some photos of your car in TITC 2013?
It looks like a special 417......
mos-leung is offline   Reply With Quote
Old 03-26-2013, 08:07 PM   #1969
TRG
TRG's Avatar
Thanks Jilles for a great thread.
I love hearing your insight into RC racing.
Now I've heard that that Orion program box is a re-labeled Hobbywing box.
If this is true can I use a HB program box to program an Orion R10 Pro esc.
If anyone can answer this it would be greatly appreciated.
TrevorG
OnRoad - TRF417V5; TRF417X; F104V2; M05 Pro;
OffRoad - TRF201
Drift - TRF415MS; TB Evolution III (Surikarn Limited)
TRG is offline   Reply With Quote
Old 03-27-2013, 01:32 PM   #1970
Default Orion R10 pro
Hi Jilles
Finally I bought a R10 pro to use i my modified TC. Have been looking on the setups on Orion homepage , and for modified I have noticed that you use the stock firmware , but what one of the 2 stock firmware? Have been looking back many pages , but cant find it mentioned anywhere. Have just switched from LRP flow to the R10 pro , big difference , much smoother speedo.
Thanks for your time to answer my question.
Michael
Denmark
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 03-28-2013, 04:40 AM   #1971
Robert_K's Avatar
Originally Posted by johnsen-dk View Post
Hi Jilles
Michael
Denmark
Shoot me a PM with your e-mail and I'll have a look if I have the software for you :-)
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 03-29-2013, 04:26 AM   #1972
Hi Guys,
Please help!
I have just bought a new 417V5 my dad has also just bought one, the new Double Cardan shafts which are supplied with the kit, see pretty awful to be frank the clips that are designed to hold the pins in, are too weak and ping off far too easily. The older design of the drive shafs without the double joint, were much better as the clips were thicker metal and stayed in place.
So my question is what do you people do with these drive shafts as they are fairly unusable the way they are?
Thank you very much Chris
cs8sz is offline   Reply With Quote
Old 03-29-2013, 04:26 AM   #1973
Hi Guys,
Please help!
Old 03-29-2013, 08:33 AM   #1974
SS LS1's Avatar
Trader Rating: 23 (100%+)
Honestly I do not have any problems with the double cardan clips at all. I'm confused why you are having problems with them. I even have the same Tamiya DCJs on the front of both of my 417x cars and neither of them give me any problems racing each week.
Are the clips rubbing inside the steering knuckles popping them off?
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 04-29-2013, 11:32 PM   #1975
sportssedanman's Avatar
Send a message via Skype™ to sportssedanman
Default VST Pro end bell timing marks
Hi All,
I have a 13.5T VST Pro. There are 9 timing marks, but what amount of timing is each mark and where is zero?
Where should I start my timing?
Hope someone can help.
sportssedanman is offline   Reply With Quote
Old 05-08-2013, 08:54 PM   #1976
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Jilles,
Do you ever run a center or front one way? I personally run on compound soaked carpet and I am running the smokem chassis on a 417x.
What reccomendation do you sugguest on a very high traction medium sized track?
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 05-08-2013, 08:55 PM   #1977
Repost
Old 05-10-2013, 09:46 AM   #1978
The best way for me so far:
- Take the big gear and sand it down till 3.57mm, standard is 3.65mm
- sand down the small gear just till they are smooth
- Use 0.1mm shim on both sides on the outside between the outdrive and gearbox
- use 0.3mm shim under the big gear.
This should give a smooth gear with long life!
Hi JG
Looks like I may well have a new TRF V5 by next Wednesday , my order has just arrived!
I was wondering on how to go about the diff build. I have been reading this forum thread and build guides on petitrc by kentech. Is the V5 diff the same internally as the 417x and if so should i follow your instructions above? If not, what do you recommend for building a strong, reliable and long-lasting diff?
The other question in my mind is regarding the suspension mount setups for the front and rear. The kit comes with separate front and 1 piece rear. I will be starting off running indoor medium-high grip tracks. Will this be okay as I have heard some say to use 1 piece front and separate back for more flex?
Many thanks for any help you can provide on this.
Scott
TheHoofmeister is offline   Reply With Quote
Old 05-10-2013, 01:15 PM   #1979
SuperFastSnail's Avatar
Trader Rating: 79 (100%+)
Default Thank you from USA
Jilles Groskamp,
I just want to say THANK YOU for sharing your experience and the wealth of knowledge that you have given us all. Anyone who has been in this hobby for a time knows that understanding the basic concept of these little cars can really bring out the aesthetic appreciation and the meaning to the enjoyment of this hobby.
A great THANK YOU again for taking your important time to educate us. I hope that you continue to be with us and give us guidance.
May the Creator of the Heavens and Earth bless you and keep you and may he shine His countenance upon you.
JU KE
Sponsor by Makita Li-Ion Brushless Power Tools. Eat the power!
Selling something but no pictures, goodbye.
SuperFastSnail is offline   Reply With Quote
Old 05-11-2013, 07:50 AM   #1980
peter.'s Avatar
hello jilles
do you use the new orion 8000mah lipo
peter. is offline   Reply With Quote
