Old 09-17-2012, 06:49 AM   #1921
Hi Jilles,
I am using Orion R10 Pro (2S-3S) Spedo & Orion Vst 4.5T motor on my 1/10 TC & I don't know how to set-up ?!
Couse I tryed with ratio 8:20 on my TC car on carpet track & it's not enough fast !!!
I saw your serup sheet for ETS Rnd 5 & Realized that you use your spedo & motor woth Stock program. But in Team Orion web site says Stock motor software is only for stock motors! Low wind motors will be damaged with this software. !!!!
Can you or anybody give me setup advice for 4.5T Vst motor & R10 Pro esc for carpet Tc track.
Team Xray T4 '16
Team Xray X1 16
Team Xray XB2
Team Xray XB4 16
Team Associated T5M
ringa is offline   Reply With Quote
Old 09-17-2012, 01:05 PM   #1922
Default Your 1/12 car
Hi Jilles
Is it possible to put a picture of your 1/12 worlds car on this tread ?.
Michael
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 09-18-2012, 01:14 PM   #1923
peter.'s Avatar
hello jilles
how many lipo orion's you use per season
and whit how many amp you load the lipo's
greetings peter
peter. is offline   Reply With Quote
Old 09-18-2012, 02:31 PM   #1924
Robert_K's Avatar
Originally Posted by johnsen-dk View Post
Hi Jilles
Michael
Look at REDRC:
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 09-20-2012, 01:18 AM   #1925
Grassy's Avatar
Hi Jilles,
I have a question about your R10 Pro ESC settings,
On your Mod Setting sheets from ETS Round 5 and IFMAR W/C you are running the stock software.
is this because these are large tracks and they needed higher RPM?
also the Timing you are running on the ESC is quite high. do you have problems with temperature on a 4.5T or 4.0T motor?
Kind regards,
Chris
-ACE HOBBY DISTRIBUTORS AUSTRALIA-
Grassy is offline   Reply With Quote
Old 09-20-2012, 04:54 AM   #1926
narcotiks's Avatar
Hi Jilles,
When you swap the tyres around to even out the wear, which tyres do you put on each end of the car from the other?
like front right to rear left etc..
narcotiks is offline   Reply With Quote
Old 09-23-2012, 02:37 PM   #1927
Hi, Jilles
What tire additive do you use for the fresh Sorex tire and used Sorex tire? Thanks.
srw_g is offline   Reply With Quote
Old 09-23-2012, 10:07 PM   #1928
Jilles,
Will you be around Bangkok rc addict track during 21-29th October 2012? That will be the time I'm visiting bangkok's ep touring car track. Hope to see ya around ya.
Regards
Lim
Rooks is offline   Reply With Quote
Old 09-23-2012, 10:18 PM   #1929
Trader Rating: 27 (100%+)
I have to fly back to my house in BKK soon. I hope my house doesn't flood again with all this rain~!
Hope to meet you at the track soon Jilles~!
JoeyE is offline   Reply With Quote
Old 09-24-2012, 05:06 PM   #1930
Hi Jilles, I was informed at the RROC 2012 about a different way the tamiya Gear diff II was being shimmed as opposed to how you do it in your well know video series. could you explain in detail how this is done?
cheers.
Obsidian is offline   Reply With Quote
Old 09-24-2012, 08:12 PM   #1931
JGH
Originally Posted by Nuno Gancho View Post
Were may we find some settings for 417x high grip track for 13.5 class.
thanks.
You can find many set-ups at petitrc.com
When high grip I usually change to softer oil and spring so the car will drive easier. Laydown the shocks will also help.
Originally Posted by CraigM View Post
Hi Jilles,
Congrats on your win at the ride cup, I'm looking forward to the release of the new car and running it at TITC 2013! Did you use a similar setup to worlds or a wider setup for the grippy track and traction compound?
Also can you explain the effect of different front and rear wheelbase settings. I know you have said previously that 0.5mm front 3.5mm rear is good for steering, but at RROC Viktor used 1mm/3.5mm and at worlds you used 0.5mm/3mm. I would have thought on a big track you would use a longer wheelbase?
Thanks!
Thanks! The Ride Cup was actually really good, and the gap with Hara and the others was a lot! Changes I made on the car from the worlds setup:
1C-1B front and 1X-1C rear ( we ran 13.5T boost so little less toe-in ). Car height was 4.5mm/5mm so droop I ran 6.5mm/5.5mm under the arm.
The rest of the setup really similar.
The Wheelbase is something I usually not change much, the only thing I always use now is 0.5mm in the front as it gives the best steering. 3 or 3.5mm in the rear is hard to feel the difference.
Originally Posted by ringa View Post
Hi Jilles,
For carpet I recommend to use the "208Mod" software. Gearing about 7.8
You can use boost and turbo also on carpet such as 10 boost and 10 turbo.
Outdoors I usually use Stock Software as you simply can use more boost and turbo. Mod software goes till 16 boost and 20 turbo but some tracks you need more boost.
Originally Posted by peter. View Post
hello jilles
greetings peter
Looking to this year I have used about 6 lipo's.
I charge them around 12 Amp!
Hi Jilles
Michael
Thanks Robert for the pics!
Originally Posted by Grassy View Post
Hi Jilles,
Kind regards,
Chris
With the stock software you can go higher with boost. At the Worlds I ran more then 25 boost / turbo so in the Mod software you can go till 16 boost and 20 turbo, this is not enough for a big track. With a 4.5T you can go really high with the boost without burning the motor. I good temp gun is recommend always!
Originally Posted by narcotiks View Post
Hi Jilles,
At the worlds I swapped the left and right tyres but never swap from front to rear!
Originally Posted by srw_g View Post
Hi, Jilles
It all depends on the track.
Here in Thailand I usually use a thin additive such as LRP carpet2 or CS yellow, in Europe Marc Rheinard additive seems to work good on sorex tyres.
It also depends if the track is treated with sugar water or not.
Originally Posted by Rooks View Post
Jilles,
Regards
Lim
Actually I think I will be not around as the track will be closed for all drivers till the Worlds Nitro starts.
Much rain fall again in BKK, hopefully we will keep it dry this year!!
See you around!
cheers.
The best way for me so far:
- Take the big gear and sand it down till 3.57mm, standard is 3.65mm
- sand down the small gear just till they are smooth
- Use 0.1mm shim on both sides on the outside between the outdrive and gearbox
- use 0.3mm shim under the big gear.
This should give a smooth gear with long life!
JGH is offline   Reply With Quote
Old 09-25-2012, 09:38 AM   #1932
Trader Rating: 23 (100%+)
Jilles,
Congrats again in all ur winnings. Refreshing to see a world champ online to give extra pointers. The Q and As are helpful
By the way, how's the other sport? Nothing like driving a Tamiya is it. It's still driving tho so u should have no trouble there .
I received the 7x kit with the Reedy decks, excited to built it. Silly question, but what's ur favorite or best setup? I know u adjust for optimizing the car to the track but do u have a default setup? Online I hope?
R_T_L is offline   Reply With Quote
Old 10-03-2012, 11:16 AM   #1933
hi Jilles,I need your help team orion r10 pro (2S-3S)I started using.but I use 5.5T engine is a 4.5 t He receives me slow mode sofwere I would like to install the software in stock but team orion site has a little note..
Stock motor firmware is only for stock motors! Low wind motors will be damaged with this firmware.Given this note can not do anything..could you help me.and the mode sofwere setup and stock setup sofwere you give me please..mideum size track.
gtfour is offline   Reply With Quote
Old 10-03-2012, 12:00 PM   #1934
B00t13g's Avatar
How important do you find balancing your sedan to be? Left to right balance specifically.
B00t13g is offline   Reply With Quote
Old 10-12-2012, 12:10 AM   #1935
over gear's Avatar
Trader Rating: 15 (100%+)
Jilles, how do you build the new 417 aeration dampers?
over gear is offline   Reply With Quote
