Old 06-05-2012, 08:10 AM   #1846
KWT-NITRO's Avatar
Hey buddy
Congrats on the ETS Podium
Askin for a friend here, he just got the new gear diff for his 417 and the diff seems to leak!! Do you have a tip on how to put it together!! Should he use all shims or what?
Cheers
Cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 06-05-2012, 08:16 AM   #1847
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Originally Posted by KWT-NITRO View Post
Hey buddy
Cheers
Cheers
Ali
+ YouTube Video
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 06-06-2012, 05:13 PM   #1848
jp_666's Avatar
Jilles Congrats on the ETS Podium
regards
jp_666 is offline   Reply With Quote
Old 06-08-2012, 12:41 AM   #1849
Hey buddy
Cheers
Cheers
Ali
Green slim on the o-ring helps alot on the leak.
also some 5*0,2 or 0,3 sims on the outdrive to limit the play.
Cp Grafix is offline   Reply With Quote
Old 06-08-2012, 08:14 AM   #1850
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
How is everyone building their TRF shocks with 1 o-ring or 2 o-rings? Regardless of how I have been building mine they still leak after 2-3 runs. I am using new blue Tamiya o-rings and associated green slime. I have tried building them with the white plastic spacer and 1 o-ring, as well as removing the spacer and building with 2 o-rings. Does not seem to make a difference. The shock shaft is in good condition and not worn.
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 06-08-2012, 09:03 AM   #1851
regards
Lovely avatar jp
bosfan is offline   Reply With Quote
Old 06-14-2012, 09:06 AM   #1852
John.C's Avatar
Trader Rating: 36 (100%+)
Jilles - Can you post you setup (including the R10 Pro ESC setup sheet) from the Reedy race?
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 06-16-2012, 09:02 AM   #1853
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
I am curious, The 417x comes with a 2.5mm upper deck, 2.25 lower deck and the "stiffer set is 2.25 upper and 2.5 lower without changing any of the cutouts.
I run on a VERY high grip track that I experience traction roll on the regular. Would you reccomended keeping the kit 2.5mm upper deck and just getting the option part from tamiya (2.5mm lower deck)
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 06-23-2012, 12:19 PM   #1854
Pretty please especially the R 10 pro setup
Old 06-25-2012, 05:37 AM   #1855
Starteur's Avatar
I just bought a used 416 (first version)
will my 416X lipo chassis fit?
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer -Tamiya F-104X1 Formula 1 Racer.
Starteur is offline   Reply With Quote
Old 06-28-2012, 12:57 AM   #1856
Nuno Gancho's Avatar
do anyone have the table for reference regarding the HINGE BLOCKS, SPLIT FOR TRF 417, and they may be assembled in both side how do I know which side is correct.
Thanks.
Nuno Gancho is offline   Reply With Quote
Old 06-28-2012, 03:41 AM   #1857
sandsurfer's Avatar
Trader Rating: 20 (100%+)
Send a message via Skype™ to sandsurfer
Thanks.
This link should help, http://www.petitrc.com/reglages/tami...ckSettings.pdf
AE SC10 4x4 / Kyosho Ultima SC-R / AE TC-6 / AE RC18R / Tamiya 416X
Leisure Hours Hobbies
sandsurfer is offline   Reply With Quote
Old 06-28-2012, 05:21 PM   #1858
CL
CL's Avatar
Trader Rating: 32 (100%+)
Yes it will fit, but where can you find the Tamiya 416X lipo chassis?
More racing and less typing!
CL is offline   Reply With Quote
Old 06-28-2012, 06:26 PM   #1859
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
http://www.exotekracing.com/416xs-extra-soft-chassis/
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 06-28-2012, 08:34 PM   #1860
Can the 417 upper deck be used on a 416?
Tks.
danfoss is offline   Reply With Quote
