Old 02-29-2012, 07:18 PM   #1831
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Originally Posted by CraigM View Post
Hi Jilles,
It was good to meet you at TITC, and congratulations on your good result, maybe if they had used the same tyre for finals you could have got him! Thanks for your help with the car, next year I'll bring a tamiya to start with instead of building it half way through
For those that don't know, Jilles came 2nd to Meen after qualifying P2, and he won the second final. In the 3rd main it looked like his car might have been a little better but had a half spin coming onto the straight which let Meen get away. Hara was 3rd, Marc 4th.
He needs to practice popping bottles of champagne
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 03-01-2012, 05:13 AM   #1832
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
He should have asked me
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-05-2012, 07:58 PM   #1833
Trader Rating: 37 (100%+)
Jilles,
In many of your 416x setups, as well as other Pros, you run 0.5 shims under the rear bulkheads.
What effect does this have on the car and under what condition do you decide to use the .5 shims to raise the rear bulkheads?
Thanks.
Nexus is offline   Reply With Quote
Old 03-05-2012, 09:35 PM   #1834
Jochim_18's Avatar
It lower your roll center..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Jochim_18 is online now   Reply With Quote
Old 03-11-2012, 04:31 AM   #1835
Suspended
Big Reg's Avatar
Trader Rating: 4 (83%+)
Default Tamiya TRF 416
Hi,
I have bought a TRF 416
It came with a 62t 64p spur gear, i was thinking of replacing it with the standard .04 105t spur.
I have a Novak Ballistic 7.5t paired with a Novak GTb2 speedy.
What pinion should i use with this?
Beers & Fishin
Big Reg is offline   Reply With Quote
Old 03-22-2012, 06:06 AM   #1836
pspong's Avatar
Default setup sheet TRF 417X
Jilles, do you know when the setup sheet for the 417X (PDF) will be available?
pspong is offline   Reply With Quote
Old 03-22-2012, 06:26 AM   #1837
Petit rc is your friend
http://www.petitrc.com/reglages/tami...SetupSheet.pdf
Cp Grafix is offline   Reply With Quote
Old 03-22-2012, 01:49 PM   #1838
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Nope, shims under the suspension blocks raise the roll center.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 05-21-2012, 03:42 PM   #1839
Hi Jilles,
I run my TRF 417 with a R10 pro and orion 5.5.
My track is CRAP, the same track you made TQ in WC 1/10-200 2008 in Portugal, remember?
If you donít mind, I would like you give me a set up for Tamiya and R10pro.
Tanks.
hugo trindade is offline   Reply With Quote
Old 05-28-2012, 01:46 PM   #1840
JGH
Hello guys, sorry for my absent so long time! Will answer all questions soon and will post Reedy Race setup soon as well!
Jilles
JGH is offline   Reply With Quote
Old 05-28-2012, 02:55 PM   #1841
Hi Jilles, congrats on 3rd. Two Tamiya 417x on the podium and 4 in the A-main.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 05-29-2012, 03:18 AM   #1842
CraigM's Avatar
Trader Rating: 34 (100%+)
Jilles
Thanks in advance!
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-29-2012, 04:42 AM   #1843
Hi Jilles,
Im having troble with my 417x, it is way loose in the rear.
I drive on a aspalth medium grip.
Right now i use your andernach setup, any ideas what i can try to improove the rear grip?
The problem is biggest while going on power in the trun exit.
Gratz on your podium finish
Thanks in advance
CP
Old 06-05-2012, 03:36 AM   #1844
Hi Jilles
The Scirroco seemed to be the flavour of choice for FWD at the recent TITC.
How do you find this body compared to the old Civic, integra and any others you have tested?
Cheers
mr lee is offline   Reply With Quote
Old 06-05-2012, 04:48 AM   #1845
CraigM's Avatar
Hi Jilles,
We've noticed in the photos from ETS that Marc had his sway bar mounted further in on the arm. Did you also run this, and what difference does it make? Is it safe to assume the hole is hand drilled?
Cute photo of the Groskamp men on there too
