Old 01-09-2012, 05:23 AM   #1801
JGH
Some pics of my FF03
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors-ff03-rear-view.jpg
JGH is offline   Reply With Quote
Old 01-09-2012, 05:27 AM   #1802
JGH
Front view
Old 01-09-2012, 05:30 AM   #1803
JGH
up view
Old 01-09-2012, 05:33 AM   #1804
JGH
Calvin,
I haven't tried the Ride control tyres yet. My car with this set-up has been very good with any tyre and track so try this first.
I found the harder spring in the rear gives more stability for the FF.
Will let you know when I have my test at RC Addict with the controlled tyres.
Jilles
Old 01-09-2012, 05:58 AM   #1805
caltek1's Avatar
Trader Rating: 36 (100%+)
Thanks Jilles for the pictures and information on your FF03. Do you use the stiffer carbon impregnated chassis on your FF03?
I look forward to your comments regarding the new control tyres and any other recommended setup change to the FWD.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 01-09-2012, 06:27 AM   #1806
Benzaah's Avatar
Trader Rating: 21 (96%+)
Jilles, Thanks for taking the time to answer all the racers questions. Very insightful even though i don't run a blue car. I have a couple of questions.
Do you use Sanwa servos in your cars? I know you use the Exzes radio. Wanting to know your thoughts on the latest hi speed servos. Do you see them as being a necessity?
Another query regarding the latest Orion motors. I have bought the R10 pro/ 17.5 pro stock combo. What sort of temps should i be looking for after my 6 minute run? I have heard that this motor can handle a fair bit of heat which is good for the Hot conditions we have here in Australia.
Best regards Benzaah
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 01-09-2012, 01:33 PM   #1807
columbia-mk2's Avatar
Hello Jilles,
First time posting in this forum; This year our club is going to hold stock class races with 10.5 motor.
I have only raced modified class and my question is, if there is something special to do to the setup, or if the mod setup will fit 100% aswell for stock.
Thanks in advance, and happy New Year!!
Awesomatix A700EX
Hobbywing Justock / LRP SXX V2 TC
Hobbywing Xerun 10.5 / LRP X12 5.0 Octa Wind
columbia-mk2 is offline   Reply With Quote
Old 01-09-2012, 08:22 PM   #1808
The editable setup sheet was updated to correct some points and add some field.
Also, Jilles setup is available in pdf.
Arn0 is offline   Reply With Quote
Old 01-11-2012, 11:20 PM   #1809
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
I may have missed it, but is there a baseline setup for the 417X on outdoor asphalt?
Cheers,
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 01-12-2012, 07:27 PM   #1810
Redko's Avatar
hi Jilles,
Was wandering if you tried your 417X on Rc Addict with the TITC controlled tires?
do you have the set up that you are using for that track?
as i will only arrive on wed. Hope to have the base setup before i reach there in order to get more track time instead of using the limited time to find the setup.
Thank You.
--TAMIYA--TB Evo 7, TRF 419X, TRF 419, TRF 418, TRF 417V5, TRF 201, M-05Ver.2, FF-03R, TRF 101, F104WGP, F103RM, RM01
-- Infinity -- MUGEN -- SANWA -- HOBBYWING -- ProSpec -- ORION -- OS -- Muchmore -- Wild Turbo Fan -- Axon -- MTB
Redko is offline   Reply With Quote
Old 01-14-2012, 06:01 PM   #1811
Koldoi77's Avatar
Originally Posted by columbia-mk2 View Post
Hello Jilles,
Hello Jilles
Is my firts time here to, i am collegue of Columbia and what is de perfet gearing for just stock hobbywing 45A with 10,5T?this year we have race of Spain championship in our circuit, we are expecting to use around 4,5 or 5 gear ratio, we test with diferent spur and pinion, 111-42, 104-39 ... But what is the best relation for 417 big spur whith big pinion or small spurs and small pinions???afect this to the punch or no? Our circuit straigth distance is around 60 meters and the order part of circuit is whith a Lot of curves and is quite low, outdoor and asphalt with medium low traction.
Thanks for your request and regards from Spain
Koldoi77 is offline   Reply With Quote
Old 01-18-2012, 09:38 AM   #1812
gcooper's Avatar
Hi Jilles,
Do you have a good FF03 setup for med/high traction carpet using either Tamiya type A or C tires?
Also what body or bodies do you suggest for that car?
Thanks in advance.
Coop
I`ve had lines on my face since I was twenty. Wind and sun put them there.
If you asked me if I`m the luckiest guy in the world, all I can say is `yup`.
Tamiya 41something - Ko Propo - Tekin RS Pro/BL check!
gcooper is offline   Reply With Quote
Old 01-18-2012, 09:16 PM   #1813
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by JGH View Post
Some additional info about the set-up
Droop: 5mm front and 4mm rear measure under the susp. arm
Rear Carbon optional shocktower, shock pos nr.3 from inside
All plastic parts I use from TRF417 which uses harder plastic
hi jilles, just a question on your ff03 setup...
for the spacers under the suspension blocks, you mentioned 3mm in front and 4mm in the rear. i noticed that the rear suspension blocks are installed "upside down" (based on the photo). if i installed them rightside up or as indicated in the manual, i would be using a 1mm spacer instead?
For the front blocks, are they installed upside down as well? 3mm (upsidedown) or no spacer (right side up)? or is the front roll center really higher than the front?
Thanks!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-19-2012, 02:47 AM   #1814
Hi Jilles,
Do you know how much timing is on the vortex VST pro motor at default end bell position? and how much added timing on every notch?
and what FDR to use for boosted 11.5t? I'm running on medium size track.
Wilson Picaldy is offline   Reply With Quote
Old 01-22-2012, 03:09 PM   #1815
ATLASCOPCO's Avatar
Default 417 setup
Hi Guys,
I have just got a 417 and i am looking for a link to some setups for carpet with rubber tyres
Many thanks
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
ATLASCOPCO is offline   Reply With Quote
