Old 12-24-2011, 11:14 AM   #1786
Can someone tell me the difference between the 1XD and 1D mounts?
Pinionizer is offline   Reply With Quote
Old 12-24-2011, 11:33 AM   #1787
KHoff7's Avatar
The 1XD is much smaller, smallest I believe (or narrowest).
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 12-24-2011, 07:39 PM   #1788
Trader Rating: 30 (97%+)
i read in the tread that there is a carbon steering brace for the 417 where do i get one thanks
zaraz is offline   Reply With Quote
Old 12-25-2011, 02:26 AM   #1789
banquer's Avatar
From smokem
[URL]http://www.smokem-racing.com/THB_SB.html[URL]
Or from Exotek
http://www.exotekracing.com/416-tcx-carbon-steer-brace/
Cheers.
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 12-25-2011, 02:44 AM   #1790
jake95's Avatar
Trader Rating: 27 (100%+)
Hi,
Jilles i was having problem with the car pushing and lacking in mid corner steering what are the first things you try, to stop the car from pushing and to provide the car with more turn in and mid corner.
thanks,
jake
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 12-25-2011, 04:18 AM   #1791
banquer's Avatar
Dear Jilles.
First of all, thank you for this work you do with tamiya owners, sharing your knowledgments with us and also Merry Christmast.
Past days, i received my new 417X and I hope you share asphalt setups with start to work or proben setups that works in low to medium grip asphalt.
Do you try ride soft springs?
Thank you very much another time!
Tamiya 419
Tamiya TRF 101
Sanwa M12 - RX-471
Old 12-25-2011, 07:30 AM   #1792
Potoczak's Avatar
Trader Rating: 112 (100%+)
Hi Jilles, have you run the 417x on carpet yet?? If so what are some of the changes you are doing?? I am running on a high bite carpet track. Thank you for any input.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-06-2012, 09:04 PM   #1793
JGH
First of all I wish all of you a Happy New Year!!
Originally Posted by TryHard View Post
Hi Jilles,
Totally agree with what your saying about high bite and the split blocks. Recently I've been running pretty high traction tracks, and seem to find the single piece better, and make the car more consistent.
Shame you couldn't make it out to the ATS, really fun event, although carpet was a real struggle, hopefully Marc had some good running there on the monday after. Did manage to get the car working ok by the end of the weekend, basically raising the front roll-centre and widening the front to kill the excess of steering. Also going (like your 'birds) setup, with long links and softer oil.... all a bit alien to me after the last time I ran on rug!
Still, looking forward to TITC, very interested to see what setup you come up with before the event
Cheers
Ed
Thanks for sharing your thoughts at ATS race. Will have some basic set-up soon for TITC!
Originally Posted by caltek1 View Post
Hello Jilles,
Thank you for the info reagrding your MO5 from TITC this year. I have another question. Since the Ride Inch up Rims are offset by 2mm did you change the spacers on the front and rear hubs or did you use 4mm hexes instead.
On another note, I have been testing my FWD car, with the new TITC control tyre for next year and I am finding the car letting go at the rear very easily. I have tried softening the rear and running the front wider. What do you suggest. I struggled tonight on a high grip track and the car was tailly all the time. The rear wanted to swap with the front. I removed the front and rear swaybars, laid the rear shocks over, altered the roll centres and adjusted droop. The only thing I haven't tried yet is making the front shocks stiffer by using heavier oil.
Any advice appreciated.
Regards,
Calvin.
For the hex I use 5mm front + 1mm shim in the rear I use 4mm hex because wider will touch the inside of the body when cornering. Also wider front drives much easier with the ride tyres.
For the FF03 I will post a set-up soon as I will look for set-up sheet for FF. My FF03 has been very good and stable. I use harder spring in the rear and seems to be more stable with this. HPI blue front and HPI pink in the rear.
Originally Posted by eded1 View Post
Hi, Jilles.
Sorry to hear that the flooding has affected your life and home.
I hope your wife and son are OK and healthy aswell.
Merry Christmas and Happy New Year and get back in shape.
Good luck on the upcoming TITC.
Ed en Robin
Everything back to normal again Ed! Also to you and family Happy New Year!
Originally Posted by jontang001 View Post
Master Jilles
Nice to see you here again!
If it is ok for you please try to post the new 417X tips for us who try to improve their RC skills. And please also if us advise on FF. Thanks!
Thanks, no problem! FF03 advise coming soon! Need to find editable set-up sheet for FF03.
1XD is the most narrow suspension block. Here all blocks from short to most long. 1XD - 1XC - 1XB - 1XA - 1X - 1A - 1B - 1C - 1D - 1E - 1F
Every step is 0.5 degree different. Hope this helps.
Originally Posted by jake95 View Post
Hi,
thanks,
jake
You can try to use inboard toe out in the front by using 1B-1D for example.
This gives more caster while cornering result in more steering mid corner.
Also try anti dive in front.
Originally Posted by banquer View Post
Dear Jilles.
Thanks, no problem. For the set-up you can use the basic set-up and try to use softer spring for low traction. For low traction I recommend using double suspension mounts and use split motormount in any condition.
I did run the ride spring, feel similar to HPI but HPI feels little more traction.
My Snowbird set-up from last year was really good, you can try that as starting point.
Jilles
JGH is offline   Reply With Quote
Old 01-06-2012, 09:29 PM   #1794
caltek1's Avatar
Trader Rating: 36 (100%+)
Thumbs up
Jilles,
Thank you for taking the time to rspond to my enquiry. I look forward to seeing your FWD setup sheet.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 01-06-2012, 09:53 PM   #1795
jake95's Avatar
Thanks for your advice jilles
XRAY✯NOSRAM✯SANWA
Old 01-07-2012, 02:58 AM   #1796
kentech's Avatar
http://www.petitrc.com/reglages/tami...SetupSheet.pdf
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 01-07-2012, 07:24 PM   #1797
over gear's Avatar
Trader Rating: 15 (100%+)
Jilles, which gear diff do you use in you M05? the stock one or Spice?
if you use the stock one, how do you keep the cleaning gum from leaking?
over gear is offline   Reply With Quote
Old 01-09-2012, 04:27 AM   #1798
JGH
Default FF03 TITC 2011 set-up
Some additional info about the set-up
Droop: 5mm front and 4mm rear measure under the susp. arm
Rear Carbon optional shocktower, shock pos nr.3 from inside
All plastic parts I use from TRF417 which uses harder plastic
Old 01-09-2012, 04:30 AM   #1799
JGH
Originally Posted by kentech View Post
Thanks Kentech!!
I used the stock geardiff, I use glue around the outside to avoid the gum coming out!
Old 01-09-2012, 05:14 AM   #1800
caltek1's Avatar
Hello Jilles,
Have you tried the Ride Control tyre for TITC 2012 on your FWD car yet? I tried some here in Australia on a high grip track and found the car would get very tail happy, due to the soft inserts in the tyres. I found I had to stiffen the front and soften the rear.
Has your setup for this years TITC at RC Addict with these tyres changed much?
Thank you,
Regards,
Calvin.
