Old 04-17-2009, 12:59 PM   #166
mutley001's Avatar
Originally Posted by JGH View Post
Paul,
You can try to stood up the rear shock one more. Or go little softer oil in rear, maybe 400. Try 1.4mm rear swaybar. I think Viktor used this swaybar at the LRP in the rear and he said it felt more stable.
Thanks Jilles, will give it a try this weekend at practice.
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 04-18-2009, 11:37 AM   #167
mutley001's Avatar
Hi Jilles
Ok testing today went well, car was much more stable with the wheel base changed that i didn't need to try the stiffer rear roll bar.
My next issue is transition through chicanes, its far too lazy nowand need to get it to change direction quicker, i thought the rear roll bar change would help this too, but is there something better to try ?
Cheers for your help so far
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 04-18-2009, 01:29 PM   #168
JGH
Hello Paul,
Good to hear!
For better reaction you can try softer oil or little harder springs.
Let me know how these changes helped?
Jilles
JGH is offline   Reply With Quote
Old 04-18-2009, 11:30 PM   #169
HI_808's Avatar
Jilles,
Thank you for starting this thread. I haven't posted any questions to ask you, but the information you have provided has greatly helped me to tune both my TRF416 and my TA05MS.
Ken
HI_808 is offline   Reply With Quote
Old 04-19-2009, 02:38 AM   #170
mutley001's Avatar
Hello Paul,
Good to hear!
Jilles
Will do, my next race in Thursday evening so will post an update after that including anything else I've tried!
Cheers again
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 04-19-2009, 12:33 PM   #171
hi Jilles
Wow this thread has really taken off!
Another few questions for you if you would be so kind!
How do you normally set your diff tension? how do you check for slip and how much do you aim for?
My local club is pretty small on low-medium bite carpet, the tires are normally vtec 27s(control tire) and tend to squeal alot! do you have a set up you would recomend starting on? my car did not feel very direct and was a bit loose corner exit?
I have also noticed you tend to run a 3mm shim on the outside of the camber link and 4mm on the inside is this to make more camber change?
Thanks in advance
Green Speed is offline   Reply With Quote
Old 04-19-2009, 02:50 PM   #172
Hi Jilles,
what is the trick to perfectly rebuild the diff? How do you do it? would be nice if you could describe the single steps
do you always sand the diff plates?
How often do you change diff plates / balls ( x runs, x mm diameters?)
thanks!!
Felix
Benn0 is offline   Reply With Quote
Old 04-19-2009, 07:18 PM   #173
ammaramira's Avatar
Originally Posted by Azman Azam View Post
Alamakk... Kawan dah cakap orang putih dah...
ammaramira is offline   Reply With Quote
Old 04-20-2009, 03:45 AM   #174
auzzy_mate's Avatar
Default 2nded
Originally Posted by Benn0 View Post
Hi Jilles,
thanks!!
Felix
2nd'ed. Now that was a good question.
Ben
auzzy_mate is offline   Reply With Quote
Old 04-20-2009, 04:04 AM   #175
tomracing's Avatar
Jilles,
thanks for a great thread with lots of nice tips!
as i am running lipo now with modified i am getting a bit lost in looking up data for FDR ratios. at your club in heemstede at what FDR are people successfully running modified with lipo now with what motors?
would like to hear it to get a more complete picture of running dutch big tracks.
how would you compare Bangkok to dutch tracks? as most data I was able to collect was from this track.
regards,
Tom
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 04-20-2009, 01:42 PM   #176
C van der Hagen's Avatar
Hi Jilles,
A little off-topic (TRF 511): Do you use two o-rings in the TRF off-road dampers or the low friction set with just one o-ring?
How did the car go yesterday?
Chris
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 04-21-2009, 01:41 PM   #177
hi Jilles, i know you dont run 10.5t but im in the market for a new brushless
speedo for 10.5 racing, i know you use the sxx i wondered if this would be the choice for 10.5 or should i go with the spx? ive also considered the speeed passion gt pro2, i just wondered if you could suggest the best esc for my racing in 10.5t.
many thanks
mark
mark williams is offline   Reply With Quote
Old 04-21-2009, 02:23 PM   #178
JGH
Green Speed,
A normal diff in a touring car should be tight enough that it can't slip when accelerate. However, when the traction is very high I would like to let it slip a fraction so not all the power come on the wheel so hard.
For low-med grip track you can try little softer spring and softer oil. The 3mm and 4mm camber link shim in the rear give perfect camber change and we always use this combo on most tracks.
Felix,
When I build a diff I first sandpaper the plates on both sides. Normally around 500-1000 sandpaper. I use Tamiya Grease hard to put between the outdrive and the plate. Ofcourse make the outdrive and plate clean with motorspray. Then I use Schumacher silicone diff lube for the plate and the ball. I use a lot of diff lube. Then for the thrust bearing I use Associated black grease.
Before I race, I run the diff in for 30 sec.
Normally I can run my diff for at least 15 runs indoor and 10 outdoors, depends on how dusty it is.
I never change my ceramic ball, use them for 1 year already, I only change the plates every rebuild and thrust bearing.
Tom,
Because EFRA has decided not to use Lipo yet I haven't run Lipo at the Heemstede track yet. I saw some guys running Lipo and they use 4.0 or 4.5 turn motors, gearing around 7.5 Dutch tracks like Heemstede/Rucphen/ Groningen are 1/3 bigger then RCS.
Lipo topspeeds are over 100km/h.
Chris,
I build my shocks just like the manual, it's with 2 o-ring.
The car on sunday was really good and they said I was running same laptimes as the fast 1/8 Nitro buggy!
The track was still little bumpy so on the straight you had to be careful not flying of the track!
Mark,
I have seen some guys running a "normal" LRP/Nosram speedo and they really lack speed against the new SPX speedo's. Don't know the performance of the SP speedo with a 10.5T
Just check on your home track who has the most power with 10.5 and go for that combination.
Jilles
Old 04-21-2009, 09:19 PM   #179
CHRIS CHAVEZ's Avatar
Hello Jilles,
Thanks for the cool pics of your car.
by the way, which brand of ceramic diff balls are you using? Also, I noticed the diff pulley looks slightly different from one side to the other. Is the diff pulley supposed to be assembled in a certain direction? Is there anything special you do with the diff spring to make sure it runs flat?
Furthermore, I just purchased all the parts to build a complete second set of shocks for more testing on the track. However, this is the first time I'm going to be building shocks with the blue O-rings. Do you automatically install a shim next to the O-ring in order to prevent leaking or do you just use green slime or both?
Thanks again, Chris
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 04-21-2009, 09:35 PM   #180
Fastforward's Avatar
Would the 3mm and 4mm rear camber link shims also work on a TA05 IFS-R? I am having trouble with the rear of the car being loose and wanting to come around on off power corner entry.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
