Old 11-03-2011, 04:53 PM   #1756
Default carpet racing
Hi Jilles
Please share some information for carpet racing. The 417 is easy to drive but i cant get rid over the last bit of understeer, which costs time. Compared to other cars there is a little bit of agression on the front missing. I know this was also an issue on last ETS for your team, but I guess there are SOME ideas.
My setup is quite your basic setup, I even went the front arms back a little to gain weight on the front axle but no final success.
Secondly please post the partnumber for the ball studs you use with the dampers(seen in the videos), I think they have a hex inside so you dont have to pop the shocks of and create all the play there right?
Thanks a lot, your recent posts have always been very helpfull and kept the trf fast.
axs1990 is offline   Reply With Quote
Old 11-03-2011, 04:54 PM   #1757
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Minami View Post
any chance of tamiya releasing their own DCJ for the 417?
RedRC reported that Victor was testing some at the latest ETS round
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-03-2011, 04:55 PM   #1758
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Marc and Victor both had them in their cars at the IIC.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 11-03-2011, 07:56 PM   #1759
TryHard's Avatar
I've spoken to Max Ma at Roche, and he mentioned that the DCJ/ECS shafts will be ready for production soon...
| THard.co.uk | Xray | MuchMore |
Old 11-03-2011, 08:35 PM   #1760
miccal's Avatar
More videos:
http://www.redrc.net/2011/11/video-p...lles-groskamp/
Thanks Jilles!
miccal is offline   Reply With Quote
Old 11-03-2011, 08:55 PM   #1761
nice. thanks for the info. i'm quite surprised that DCJs didn't quite make a lot of buzz, are they not as effective as others say they should?
Minami is offline   Reply With Quote
Old 11-03-2011, 09:20 PM   #1762
TryHard's Avatar
On another topic entirely...
Jilles, having seen the large level of flooding in the Bangkok recently, hope you haven't been badly affected. The pictures of RC City are quite saddening having been there earlier this year, and I know your living in Bangkok now, not so far from there, so hope you haven't been badly affected. Sad to see to such problems regardless for the Thai people.
Ed
Old 11-05-2011, 03:45 PM   #1763
caltek1's Avatar
Trader Rating: 36 (100%+)
Hello Jilles,
I am after some advice regarding the setup changes that were made to your mini at this years TITC race.
Did you have to make large changes to the oils used in the shocks and springs? What about ride height.
I did troll through this thread and read different things you do for the shocks on your mini.
Do you use the TRF mini shocks and if so are you using internal spacers to limit droop.
I am in the process of building/setting up a car for TITC next year and was just after some direction for my mini. I will be running a MWB car and use either a Swift or Subaru body.
BTW,
I hope things are getting better in Bangkok, from the news the place is still inundated with water.
Thank you,
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 11-07-2011, 06:20 AM   #1764
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Jilles,
Do you consider cutting the motor mount and the top deck a necessary thing to do for running modified?
Do you have a base setup for the 417?
dontfeelcold is offline   Reply With Quote
Old 11-07-2011, 06:02 PM   #1765
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Originally Posted by axs1990 View Post
Hi Jilles
I am not running the 417 but I have the 416X with lipo chassis. I run at a small carpet track. A few things I have found that seems to settle down the rear end on carpet is . I layed the rear shocks down to next to last lower shock tower hole. I also run the stiffest front sway bar with no sway bar in rear. I also run 3 mm drop in front with 2mm droop in rear. I also run 28 tires. The car is still a bit to aggressive and want to make the car a bit softer. For a small tight carpet track the car is very managable.
I hope this helps some.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 11-07-2011, 11:51 PM   #1766
Pro10noob's Avatar
Try to make the rear of the car a bit narrower.
I also drive the 416X with lipo chassis and run a 185MM rear end.
Also use the 1XB and 1C rear suspension mounts.
Shocks are almost straight up at the rear and got good traction.
Front they are on the 3th hole from the outside.
Run med front swaybar and soft in the rear.
Works like a charm
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-08-2011, 11:44 AM   #1767
Mugen10's Avatar
Hmmm, I will look into that setup. With the rear 1XB and 1C what is the toe deg.? I thought the more narrow the rear is the less grip.
I copied this info from the Hudy setup manual.
EFFECTS OF TRACK-WIDTH ADJUSTMENT
Front trackwidth
Wider • Decreases front grip.
• Increases understeer.
• Slower steering response.
• Use to avoid traction rolling.
Narrower • Increases front grip.
• Decreases understeer.
• Faster steering response.
Rear trackwidth
Wider • Increases rear grip.
• Use if car is traction rolling.
Xray T4
Old 11-14-2011, 05:48 PM   #1768
jill
thank you very much for this treat
i will like to know a set up for the tamiya 417 wearing foam nitro tires or some advice for faom tires in asphalt i know the car works better with rubber tires but in my country they are so expensive so we use foam tires because they are cheap i will apreciated any advice
hagen is offline   Reply With Quote
Old 11-14-2011, 08:14 PM   #1769
subaru73's Avatar
Trader Rating: 41 (100%+)
Default bearings
Hello Jilles just purchased some abec35 ceramic hybrid bearing set for my 416x what do you you use for bearing oil?
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 11-27-2011, 04:46 PM   #1770
Mugen10's Avatar
Works like a charm
regards Roy
Thanks Pro10noob for your info.
I did try the rear block and I do like the results. The car has improved so much now that I am learning more about the car. Tamiya fan for many more years.
Xray T4
