Old 07-27-2011, 05:15 AM   #1681
barts71m's Avatar
Trader Rating: 34 (100%+)
Originally Posted by TA.man View Post
Hello Jilles,
I would like to know about life of TRF417, because I would like to change a new TRF chassis as soon.
- about new chassis, when ?
i think TRF417 is 1 year ago.
regards,
Tamiya 417 was released to public in December 2010.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 07-28-2011, 02:44 AM   #1682
roger999's Avatar
Hi Jilles
can you tell me how do you practise? How often and how long? Only on the track or on VRC as well? Hard to be on the track often... Mayby you have some special advice for that?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 07-28-2011, 05:18 AM   #1683
Hi Jilles.
Really nice to read your coments and tips. Go on with that.
I see, that you nearly allways use 1C/1C blocks with spacers at the wheels in the front. Have you tried 1D/1D or even 1E/1E blocks and then no spacers instead? Allmost the same wide...
Look forward to see you at the Euros in Austria.
Bjarne - Denmark
BCDK is offline   Reply With Quote
Old 08-08-2011, 11:29 PM   #1684
Dragging the thread back from PAGE 5 OUCH
With the Team Orion speedies hitting the shelves, are there any suggested setups from your recent travels.
I see that the software has a new version number, any significant changes from the older software?
The ESC itself looks AWESOME, but whoever thought up the new switch and capacitor shrouds needs a good hard look in the mirror. They are HUGE
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-13-2011, 07:30 AM   #1685
Starteur's Avatar
I raced my TRF416X last night (or tried!)
I did about 4 turns and melted one of the front outdrives!
Then a friend lent me his complete spool set-up, and within 5 turns I melted BOTH outdrives!!!!!!!
What did I do wrong??????
I ran that car before without any problems, the only thing I did was adjust the front belt (to loosen it up).
Thanks for your help.
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer -Tamiya F-104X1 Formula 1 Racer.
Starteur is offline   Reply With Quote
Old 08-13-2011, 12:42 PM   #1686
CHICO1977's Avatar
Smile
Hi i was wondering what Servo saver were u n Marc using?
CHICO1977 is offline   Reply With Quote
Old 08-13-2011, 01:47 PM   #1687
TryHard's Avatar
Is the spool cup sleave (blue aluminium piece) damaged? if you have the adjustment insert in the wrong way up, it will touch the upper bulkhead cap, and this can melt the outdrives... pretty easy to get one or both the wrong way up when adjusting belt tension (been there, done that )
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 08-15-2011, 09:13 AM   #1688
Starteur's Avatar
HiH
Ed
You are right on it, I put them upside down (), and the alu coupler
are junk!!!
Old 08-18-2011, 03:11 AM   #1689
johnny-g's Avatar
i too would like to know if new/2012 kit comming with some of the seen proto parts, cheers and thanx for going the extra mile jilles with this forum,u r a credit to youre sponsors
johnny-g is offline   Reply With Quote
Old 08-18-2011, 04:50 AM   #1690
are junk!!!
The spool outdrives are fine! they wear instead of you wearing out your drive shafts etc when you hit something! mine last a fair few meetings and only cost around $3 to replace. 3racing or someone also does them with the alu sleeve included for about the same price.
Smartypants is offline   Reply With Quote
Old 08-18-2011, 06:50 AM   #1691
TryHard's Avatar
He's already mentioned what happened. If you put the spool in upside down in the 416, the blue outdrives touch the bottom of the bulkhead cap, which knackers the alloy, and heats the plastic outdrives up so they literally melt into a pile of goo.... (trust me, done this! )
On the 417, doesn't happen, as the bulkhead caps had some material removed from underneath for clearance
HiH
Ed
Old 08-18-2011, 10:55 AM   #1692
Hi Jilles,
Do you use shims between the upper and lower bulkheads on the 417, or was that only with the old car?
Best regards,
Niklas
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 08-19-2011, 07:27 PM   #1693
Hi Jillies,
Knowing that the electronics' side are alittle heavier than the battery side,do you put lead or weights on the battery side to balance the car?
Champagne showers
theoneandonly is offline   Reply With Quote
Old 08-22-2011, 09:09 PM   #1694
Jilles, running your snowbirds setup on high grip carpet. What changes would you make to avoid traction roll? thanks!
franc furter is offline   Reply With Quote
Old 08-23-2011, 03:38 AM   #1695
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Hi Jille's,
I am just wondering which way the shock shaft guide goes in after you put the oring in in the TRF dampers? There is a face that has a groove cut into it and a face that is flat.
I seem to have misplaced my instructions
Josh
dontfeelcold is offline   Reply With Quote
