Old 06-17-2011, 11:58 AM   #1621
TryHard's Avatar
Originally Posted by TryHard View Post
Hi Jilles,
Finally got to use my Sanwa handset today (it's been how many months since TITC!!), anyway, I have a question for you on how you set yours up.
I'm having to run 115% D/R (with EPA's at 100%R, 95%L) to get my desired amount of lock... does this sound right to you?
Regardless, have to say, feels so smooth to drive, and much lighter in the hands too, a BIG improvement
Cheers
Ed
Originally Posted by JGH View Post
Hi Ed, good to hear you finally changed! I run my D-Rate at max.150% and EPA about 95% to get full lock.
Jilles
Thanks Jilles, I'll be turning it up the D/R next time then. A fair few locals say my cars always look like they understeer.. wonder if that's part the reason...
I always use max steering lock, some corners you need it.
Jilles
Posts from back on page 99 and 100.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 06-17-2011, 12:24 PM   #1622
HiH
Ed
Thanks, is the aluminum steering suppose to rub against the CF battery holder?
MDRTales is offline   Reply With Quote
Old 06-17-2011, 12:26 PM   #1623
On the 417
Old 06-17-2011, 12:40 PM   #1624
Nevermind put the shims in the wrong place.
Old 06-17-2011, 04:18 PM   #1625
Nick Groves's Avatar
I have a question for you about the suspension blocks. I have read threw this thread and have learned a lot. One thing I have read is that the front rear suspension block is upside down. I know that's how thekit tells you to build it. Do you ever run it the other way? If so why?
When people run 0.0mm under FF and 0.5mm under FR that's with the suspension block upside down?
Nick Groves is offline   Reply With Quote
Old 06-17-2011, 04:45 PM   #1626
Trader Rating: 69 (100%+)
The front rear block is upside down to clear the front drive belt. You cannot install it the normal way, it's going to touch and drag the belt. The only other option is to run the split blocks.
eComet is offline   Reply With Quote
Old 06-17-2011, 10:16 PM   #1627
TryHard's Avatar
I know you answered your own question, but in all honesty I wouldn't know anyway, as I have a pet hate of the battery 'hooks'. Look ugly, add weight I'm the wrong place, and there are better a simpler methods out there (like a little carbon piece stuck to the bottom of the cells to sit in the holes).
Rant over, lol
Ed
Last edited by TryHard; 06-18-2011 at 05:34 AM. Reason: Bloody iPhone keyboard and my big thumbs
Old 06-17-2011, 10:18 PM   #1628
Thank you, it's a second hand car so I didn't build it myself.
Old 06-18-2011, 05:17 AM   #1629
I know you answered your own question, but in all honesty I wouldn't know anyway, as I have a pet hate of the battery 'hooks'. Look ugly, add wait I'm the wrong place, and there are better a simpler methods out there (like a little carbon piece stuck to the bottom of the cells to sit in the holes).
Rant over, lol
Ed
+1 - I actually bought new batteries (with bumps to fit the holes in the chassis) just to get rid of those damn ugly hooks.
But when I did use the hooks (1 race!), I did notice that the steering was very close to the hook, and I can see how a misplaced shim can create problems.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 06-18-2011, 05:58 AM   #1630
barts71m's Avatar
Trader Rating: 34 (100%+)
Those damn hooks, got rid of mine off my 416X one went straight thru my lipo in a crash.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 06-18-2011, 09:56 AM   #1631
CHICO1977's Avatar
What Oil to run for Front Gear diff?
CHICO1977 is offline   Reply With Quote
Old 06-18-2011, 11:49 AM   #1632
kedal's Avatar
500 000 is quite good.
TRF201 - Tekin RS Pro - PRT HS 10.5T
F103 - Hobbywing 1S - Hobbywing 13.5T
rctouch.over-blog.com
kedal is offline   Reply With Quote
Old 06-18-2011, 12:08 PM   #1633
Trader Rating: 27 (100%+)
On a 416X, what is the best gearing for a BL17.5 Duo? What spur/pinion should be the best for the 416? People just tell me to run a certian ratio for the motor but they don't know what spur to tell me for a start.
Thanks~
JoeyE is offline   Reply With Quote
Old 06-18-2011, 01:01 PM   #1634
speedyfowler's Avatar
Thanks~
What speed control are you using? How big is the track? Is the class you're running it in boosted?
speedyfowler is offline   Reply With Quote
Old 06-19-2011, 12:30 AM   #1635
esc: Tekin RS, no boost
track: Parking lot size with a 75' straight
Thanks~
