Old 06-16-2011, 01:56 PM   #1606
Pro10noob's Avatar
Originally Posted by jonest View Post
Yup. Just downloaded the setup.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-16-2011, 02:11 PM   #1607
RL.2002's Avatar
hi jilles,
what the difference between spec r and the tamiya gear diff??
the passion of the slide when taking the corner....
http://www.penabai-rcdrifter.blogspot.com/
Kyosho TF-5 drift spec powered by Ezrun 35A + 9t
Tamiya TRF-416X, Tamiya TRF-417
Hobbywing Xerun 120A, Xerun 3.5t, Team Orion 11.5t, Xerun 5.5t
RL.2002 is offline   Reply With Quote
Old 06-16-2011, 03:01 PM   #1608
over gear's Avatar
Trader Rating: 15 (100%+)
Originally Posted by JGH View Post
Attached my set-up of the ETS race in The Netherlands.
Jilles
Jilles, question about your setup.
Why did you put o-rings in the shock when you can limit the shock length with the droop screw?
and what is the difference of running the camber link at #1 instead of #3 on the bulkhead? most setup i see use the #3 spot.
thanks
over gear is offline   Reply With Quote
Old 06-16-2011, 04:48 PM   #1609
barts71m's Avatar
Trader Rating: 34 (100%+)
Jilles
Thank You JGH
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 06-16-2011, 07:29 PM   #1610
TryHard's Avatar
Firstly, thanks for the setup Jilles, looks pretty standard fare! I am loving my 417 at the moment, and the Sanwa handset is soooooo just brilliant Followed your advise for setting it up in terms of dual-rates etc, and it's just awesome in it's response. And no glitching either
thanks
I think when Jilles put 2-Oring's, he means in the bottom of the shock. Instead of having a single o-ring and the plastic spacer, he replaces the spacer with a second O-ring. I may be wrong (and JGH will be able to explain better ) but I recall it gives a bit more traction, and less likely to leak.
I can answer the camber link question too. Longer (hole 3) makes the car more stable, and react slower, also gives less camber change. Hole 1 seems to give more corner speed, and a quicker reaction. I've moved from 3 to 1 on my setup recently, car is just plain faster with it like that!
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 06-16-2011, 08:03 PM   #1611
Hello Jillies,
Mind posting a picture of how the cutted motor mount will look like?
Champagne showers
theoneandonly is offline   Reply With Quote
Old 06-16-2011, 09:04 PM   #1612
barts71m's Avatar
Originally Posted by theoneandonly View Post
Hello Jillies,
Pics on this forum
http://www.rctech.net/forum/9239661-post1575.html
Old 06-16-2011, 09:20 PM   #1613
TryHard's Avatar
Originally Posted by barts71m View Post
Yup, and pics of it mounted... http://www.rctech.net/forum/8717512-post830.html
It's been on my car since the the TITC, and I've not looked back!
Old 06-17-2011, 03:03 AM   #1614
Thank you guys!
Champagne showers
Old 06-17-2011, 05:48 AM   #1615
Vicko's Avatar
Trader Rating: 14 (100%+)
so cutting the mount, well it give u more steering? or just plant the rear end better? is it only needed for Mod??
Vicko is offline   Reply With Quote
Old 06-17-2011, 07:34 AM   #1616
Its good for low/mid grip tracks. High grip you want to keep it solid.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-17-2011, 07:49 AM   #1617
cuboi's Avatar
Originally Posted by RL.2002 View Post
hi jilles,
Spec r black, tamiya white
cuboi is offline   Reply With Quote
Old 06-17-2011, 07:52 AM   #1618
Default what fluid comes with the Tamiya Gear Diff II
Wondering if the fluid that comes with the new gear diff is useful?
Any idea what weight fluid? and does the new gear diff leak with 1000w in it?
Electro-MAX RC is offline   Reply With Quote
Old 06-17-2011, 09:33 AM   #1619
Default What engine ets andernach germany
Hi jilles
Can you say might. What engine modified (Turns)are you doing in ETS R6 Andernach install the race .I´ve never driven there. And wanted to buy a new engine( Turns) for the race.
Thanks Reggie
need not be
stefan Köhler is offline   Reply With Quote
Old 06-17-2011, 09:54 AM   #1620
HiH
Ed
What page is Jilles Sanwa Handset set up on?
MDRTales is offline   Reply With Quote
