"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors
#1591
Congrats on your ETS result.I would like to ask u what is the Biggest Spur Gear we can install on the 417? Pls give some tips on building the New Gear Diff n what oil to use for Front & Back. Thanks
#1592
Really nice driving at ETS Jilles.
I saw the split blocks on Marc car, could you explain the benefit and why they used it specially at ETS?
Did you guys runned with cutted motor mount?
You might also come to Andernach?
Thanks!
Thanks!
#1593
Will there be an inboard front shocks design TRF41X kit coming soon?
#1595
Congratulation
Congratulation Jilles on the recent ETS result...
#1596
Jilles,
Did you remove the 0.5 mm spacer under 1c block when you use the 1c plit bloc with it ?
#1597
Anyone know what Ride body Jilles used at the ETS?
#1598
LTCR? from protoform..
#1599
Gear Diff Unit II
Hello guys,
Just came back from ETS race. All Tamiya's were really competitive and I was really happy with my car and the performance of the Orion power.
Little bit dissapointed about the result as I had shimmed my geardiff wrong which cost me the victory in final 3.
Will post my set-up including my motor/speedo set-up soon.
Jilles
Jilles
I'll be getting the new gear diff from Tamiya soon. What are the things to look out for when building it?
Thank you.
#1600
Attached my set-up of the ETS race in The Netherlands.
Jilles
Jilles
#1601
Yep!
2. Depends on the track, if not much hairpins a one-way can be faster.
Bad luck Jilles. Looks like you had the package to beat over the weekend. Be grrateful to see your setup when you have time to post it. All the TRF guys seemed to have great pace. By the looks of Marcs car split blocks are the go now.
What are the benefits of removing the carbon brace from the steering on the 417.
Orion R10
We all ran cutted motor mount, I can advise this to everyone.
I will attend Andernach!
Thanks!
I ran the Protoform LTC-R body, will bring the Ride to Andernach for smaller, technical track!
I already posted some comment about the geardiff in the 417 thread but will post it soon on my thread!
Jilles
#1602
Hello everyone,
For those who will get the Tamiya geardiff soon, here some tips how to build it.
At the ETS we were not informed how to shim the geardiffs as we just got them for the race. After the race I have checked all diffs and tried to find the best solution.
First use sandpaper ( 500 ) for all gears and sand them down till it touch the whole surface. Then use 3 x 0.1 shim each side.
When close the diff, don't tight the screws too much.
At first the diff feels little bit tight but just run it in, inside the car, same as a ball diff.
Let me know how things are working out,
Thank you,
Jilles
Thank you,
Jilles
#1603
Hello everyone,
Thank you,
Jilles
Thank you,
Jilles
I'm just about to build the diff over the weekend and ur advice on it comes at the right time. Good luck at Andernach! Have fun...
Thanks.
