Old 04-28-2011, 01:13 PM   #1486
Trader Rating: 69 (100%+)
Originally Posted by entitymugenmtx View Post
What spings are people using for the 417
HPI Silver front and back outdoor.
Tamiya White front and Blue back indoor carpet.
eComet is offline   Reply With Quote
Old 04-28-2011, 01:24 PM   #1487
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
Do you have a part number
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 04-28-2011, 04:59 PM   #1488
CHICO1977's Avatar
Originally Posted by TryHard View Post
Hi Jilles,
Finally got to use my Sanwa handset today (it's been how many months since TITC!!), anyway, I have a question for you on how you set yours up.
I'm having to run 115% D/R (with EPA's at 100%R, 95%L) to get my desired amount of lock... does this sound right to you?
Regardless, have to say, feels so smooth to drive, and much lighter in the hands too, a BIG improvement
Cheers
Ed
hi how would do these kind of setting for Ko propo Eurus?
CHICO1977 is offline   Reply With Quote
Old 05-01-2011, 07:23 AM   #1489
JGH
Originally Posted by geeunit1014 View Post
Jilles,
What was the main advantage of shimming up the bulkheads 0.5mm on the 416? Did you also put an extra 0.5mm under the arm mounts when doing this?
We came with this idea at the worlds 2010. We raised the bulkhead 0.5mm, this gave more traction for some reason, also the distance between lower and upperdeck was little more so easier to install the 25mm Lipo pack.
We didn't changed the rollcenter, we only lowered the upper camberlink shims by 0.5mm.
Thanks Jilles, I'll be turning it up the D/R next time then. A fair few locals say my cars always look like they understeer.. wonder if that's part the reason...
I always use max steering lock, some corners you need it.
Originally Posted by Manu_05' View Post
Hi Jilles,
How are you ?
I would like to know what can we do if the tires are overheating ?
Harder shock oil ? Softer spring ?
Regards,
Manu
Exactly! Thicker oil and soft spring always helps to avoid overheating tyres.
And ofcourse try to find the right tyre additive, mostly used is thick additive when the tyre overheat, such as MR or Tyre Tweak kind.
Originally Posted by Me_MrTyson View Post
JGH,
Recently found a CRC setup for the worlds you used a Orion 3.5 but no rollout information..
Are you willing to share?
Actually at the Worlds 1/12 I ran a 4.5T Orion motor.
I used 36mm roll out, with 3mm timing on motor.
Originally Posted by shikakae123 View Post
Hello Jilles.
I want to ask,how does rebound on the shocks effect the car?Should there be alot of rebound or only a little?
I found most of the time I have more traction with zero rebound. Only on bumpy track or really high grip you can try rebound.
Is there a length you set your front and rear sway bar links ?
Not really, I always check when I have the car on the drop blocks, the swaybar should be level, (horizontal).
I tried to find my old KO radio to check it out, I found it but without battery.
For full lock, the steering blocks is 1mm away from the casterblock.
Jilles
JGH is offline   Reply With Quote
Old 05-01-2011, 07:59 AM   #1490
shikakae123's Avatar
Thanks jilles for the reply!
But how do you make shocks with zero rebound?
Will you also be thinking of making a new tips video with Redrc?
shikakae123 is offline   Reply With Quote
Old 05-01-2011, 08:29 AM   #1491
JGH
No problem! Zero rebound you can make by pushing the shock rod/piston all the way up and close the shock cap, and even better drill a small hole in the shock cap.
Next month I will be heading home and probably gonna do the ETS race in Holland. At that race I will catch up with the Redrc guys and maybe we can do something similair again with some video.
Question for all racers on this thread, what would you like to see in the video?
What kind of stuff should I explain in the video about the 417 or something about motors, speedo, batteries, radio set-up or charging?
Let me know and I will work on something.
Jilles
Old 05-01-2011, 09:50 AM   #1492
Send a message via MSN to WinDarK83
Thanks Jill for your help and answer all our questions.
In my opinion it would be nice to do a revison of the videos for the new 417. There are not many differences but I think we could really see the new car.
As for the motors and ESC would be great to comment on the new Orion motors/esc and new batteries.
Thanks again and greetings.
Andrés Glez.
www.agonl83.blogspot.com
WinDarK83 is offline   Reply With Quote
Old 05-01-2011, 10:28 AM   #1493
Hello Jilles, thanks for you suggest, today i tested with thick additive and mixes, with not bad results in old tyres.
I think, some explanation about diferents threatments of tyres are interesting, too.
See you in Holland, thanks.
Regards, Luis C.
PD: Saludos, Andres ;P .
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 05-01-2011, 11:06 AM   #1494
Jilles
I would like to see how you build your gear-diffs for the best result (and minimum leak?).
A detailed explanation of tire additive (when to use what, for how long and such).
It would also be nice to learn what to check for in the car, after each heat (bend blocks and such).
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 05-01-2011, 03:39 PM   #1495
Hi Jilles,
When using same shock oil weight, do you completely empty the shock and add new oil or just top it off from time to time?
Have you tested the Hara rear wing (low height, but with the curved rear?) Do you like it?
Thanks in advance.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 05-01-2011, 05:02 PM   #1496
CraigM's Avatar
Trader Rating: 34 (100%+)
My vote is for interpretive dance
But seriously, it'd be great to see anything special you do with your motors, speedo and batteries
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 05-02-2011, 01:01 AM   #1497
Thanks for your reply!
Perhaps how you set up your car like what you add to the shocks example how much o' rings it's effect and tyre choice addictives like tricks to improve set up etc.
Also is shock cap the rubber oil seal?perhaps a video for this can also help.
Old 05-02-2011, 02:01 AM   #1498
I like this video. Thanks for share.
[URL="http://www.muhasebeprogramiindir.com"]Muhasebe Programları[/URL]
hede1f20111 is offline   Reply With Quote
Old 05-02-2011, 07:34 AM   #1499
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Jilles
I would love to see setup advice, like how to tune your car for each race...roll center changes, shock angles, shock oil...etc. Also I would like to see how to set up your radio/steering.
Thanks for asking!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 05-02-2011, 07:55 AM   #1500
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
I would love to get information on driving, lines, styles (carpet vs asphalt) etc.
Also, how to practice properly to get better.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
