Old 03-27-2009, 01:16 PM   #1
Foxxrocket's Avatar
Default Body color and motor temperatures
It's common knowladge that dark colors absorb heat from light rays, and light colors repel it. But I've never given it any thought to how much, or little it effects to motor temperature under the body. Has anyone ever tried doing this to see how much the temps vary from shell to sell with the same car? And is they a change, no matter how small?
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 03-27-2009, 01:24 PM   #2
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
i think the effective heat transfer from conduction and convection will be magnitudes above what heat energy is removed by radiation. that said, i don't believe you could hold enough of the variables constant to ever determine an answer here. for instance, the ability of humid air to pull heat away versus dry air is probably much more detectable than that which you speak of. especially if you are using a fan.
in short, i don't think it can be done reliably by anyone reading this message board.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-27-2009, 01:52 PM   #3
sportpak's Avatar
Trader Rating: 26 (100%+)
What on Earth would lead you to that conclusion??
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 03-27-2009, 02:28 PM   #4
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
+1
Worth even considering? nope, i wouldn't think so.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 03-27-2009, 02:56 PM   #5
TimV's Avatar
Trader Rating: 49 (100%+)
Shouldn't make a difference. Colors affect heat absorption from light rays, not from radiant heat. Since the motor emits radient heat, not light rays, the body color should have no effect on the temperature.
But all in all, there are way too many variables to effectively test this. I know I won't be losing any sleep over it.
- - - Express Motorsports - - - MW Designs - - - Mimi Wong Clan - - - Final Thoughts Racing - - -
- - - Team AKA - - - RDsquared - - -
It's the year 2010. Shouldn't vacuum cleaners be quieter by now?
TimV is offline   Reply With Quote
Old 03-27-2009, 03:08 PM   #6
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Heh, wait til SystemTheory gets ahold of this thread
-rocky b
flatspunout is offline   Reply With Quote
Old 03-27-2009, 05:18 PM   #7
reenmachine's Avatar
Pshaw. Back when I worked at JPL I was involved in a LOT of testing like this. I ran tests in tightly-controlled environments in thermal-vac chambers up to full-size spacecraft level. Send me about $500k and I can have the answer for you.
Either that, or you will never see or hear from me again.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 03-27-2009, 05:35 PM   #8
Trips's Avatar
Trader Rating: 16 (100%+)
Doesn't anyone gear for lap times anymore? On race day i want to put in the most laps, not come off as close as possible to some magic number on a temp gun.
To answer the original question here... I doubt body color would matter... while it will be a little warmer under a dark body than a light one with the car at rest, our cars have so much airflow under the bodies that it would make little or no difference over the course of a race. Once the car is moving, body color should be irrelevant.
MARSHAL!!
Trips is offline   Reply With Quote
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 01:18 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 02:13 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
Losi Constant Velocity Drive (LCD) vs MIP CVD John Stranahan Electric On-Road 263 01-24-2010 12:51 PM
Fall Garage Sale...all quality gear FS! rcjunky10 R/C Items: For Sale/Trade 20 11-12-2008 07:42 AM
Need help with micro setup microdude Electric On-Road 12 02-29-2004 08:25 PM
