Old 03-26-2009, 01:24 AM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default Freeze my brushless motor?? - any advantage??
Ive got this huge home-made motor freezer that the OGs at the track told me they used to use on brushed motors to bring the temps down before a race ( I guess it would buy them a minute or two before the cooked their motor with tall gearing). Would this same principle apply to a brushless motor - how come I dont see people using these on brushless motors?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 03-26-2009, 01:56 AM   #2
This is a good question! I remember the Pan car guys used to do this back in the day.
Jay
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
Old 03-26-2009, 02:31 AM   #3
I used to freeze my brushed motors. I switched to brushless and also used the freezer on my first 6.5. It lasted 4 or 5 runs before it seized up. I think the problem is due to what gets cold. A brushed motor would get cold magnets (on the can) whereas a brushless motor gets cold coils. I suspect the sudden change in temperature of the coils does something with the condensation levels and probably causes shorting out which leads to an overheat. I've heard people suggest the moisture played up with the sensors causing the timing to go funny, but that wouldn't explain my problem because I was running sensorless.
In summary, I wouldn't risk freezing another one of my brushless motors.
THancock is offline   Reply With Quote
Old 03-26-2009, 02:55 AM   #4
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i saw hara freeze his BL motor during TITC in thailand last month....
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-26-2009, 03:02 AM   #5
That's because Hara gets his stuff FREE! LOL
Jay
~ Jason Kennedy ~
~ TQ Wire~Wire~
Old 03-26-2009, 05:17 AM   #6
Jay
NO.... he gets money for using that stuff!!!
il-gufo is offline   Reply With Quote
Old 03-26-2009, 05:55 AM   #7
Well that's even better than free... that's free money!
Jay
~ Jason Kennedy ~
~ TQ Wire~Wire~
Old 03-26-2009, 07:03 AM   #8
Trader Rating: 38 (100%+)
We had a bunch of people doing it at our outdoor track and a bunch of motors failing. We suspected perhaps the freezing was doing it so everyone stopped and the motors stopped failing.
or8ital is offline   Reply With Quote
Old 03-26-2009, 07:20 AM   #9
Suspended
I've seen batts frozen too.
And I have heard about Buffalos jumping off the edge of a cliff.
Lots of things you can do if you plan on throwing it away when the run is over, and a lot of things you shouldn't do if you plan on using said part again.
I think it was Mike Reedy that once said, "If we thought it was a good idea we'd send them packed in dry ice. What you decide to do with it after you get it from us is up to you, just don't send it back to us when you blow it up."
Lightin' is offline   Reply With Quote
Old 03-26-2009, 07:24 AM   #10
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Try a google search on the "Mpemba effect". You would be surprised that warm water can freeze faster than cool water! It's true. If you apply that theory in reverse to motor cooling, it could be that the cooler motor heats up faster?
It's common to hear people talk about motors overheating after cooling them first. I can't see how a little bit of miosture on the surface after cooling could be the cause.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 03-26-2009, 07:37 AM   #11
Suspended
I've heard stories of people using the much more therocooler thingy and it's got the motor down to a point where moisture has built up inside the can and moisture on the sensors.. rendering them useless.
Nick Priest is offline   Reply With Quote
Old 03-26-2009, 08:15 AM   #12
Skiddins's Avatar
Correct, a bit of moisture in a brushed motor will soon evaporate, but in a brushless the moisture is a bit more trapped and of course it contains electronics.
I used the Much More cooler for a while but gave up as if it was left running for more than 5-10 mins before a race I got bad stuttering during the run.
Next run I wouldn't use the cooler and wouldn't get stuttering.
I tried this a few times over a few months.
Just fit a decent motor/fan heatsink to the motor like the Nosram/LRP unit.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-26-2009, 08:31 AM   #13
Haha, yeah heard that one, an old builders trick apparently for warming up their hands :P
Tamiya TL01
Tamiya TA05 (ish)
Associated B4 3.5r
Limerick91 is offline   Reply With Quote
Old 03-26-2009, 10:22 AM   #14
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Nope.. the Mpemba affect doesn't have anythign to do with warming, thawing, or heating up.
Cpt.America is offline   Reply With Quote
Old 03-26-2009, 10:35 AM   #15
RC_Dan's Avatar
Send a message via MSN to RC_Dan Send a message via Yahoo to RC_Dan
In my opinion it helps, I've messed around with a MM cooler, and it appears to help lap times in the first few minutes. However, it is NOT allowed at ROAR sanctioned events.
AE TC6 B4 & 18T, Kyosho Lazer ZX-5
CRC Gen XL & Battle Axe, Hot Bodies Ve8
460whp CRX on E85
RC_Dan is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21259 Yesterday 10:12 PM
