Old 03-25-2009, 07:54 PM   #1
Cristian Silva's Avatar
Default rotating tires
Hey guys, just a quick question with rotating rubber tires.
Ive heard some driver rotate their tires, left to right others front to back,
I can see the advantage of getting longer use out of them by doing this but which way is best or is it best not to rotate at all?
Ive tried both ways myself and am undecided by the results.
Team Xray Australia - HEI International ~ www.hobbyexpress.com.au - www.smaracing.org
Cristian Silva is offline   Reply With Quote
Old 03-25-2009, 09:52 PM   #2
The way I was told was to rotate from left to right and right to left, every 3 runs. And then you only ever bring your rears to the front, and never the front to the rears(due to the way the front tires wear).
RC-DriftNewb is offline   Reply With Quote
Old 03-25-2009, 10:48 PM   #3
Yeh I though the other way front to back doe to its camber wear.
Old 03-25-2009, 10:59 PM   #4
I'll ask again to be sure. But I could have sworn it was rear to front and not front to rear.
Someone else should chime in
Old 03-25-2009, 11:10 PM   #5
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
The way I see it, even if you have the same camber setting front and rear, your tyres will wear differently because of things like toe in and out and akerman. If you then swap tyres front to rear your tyres contact patch will be a bit different. It would take some running to change this.
Having said all that I have change tyres front to rear before and didn't notice a big difference.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 03-25-2009, 11:12 PM   #6
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
I've heard both...don't swap fronts with rears and rears with fronts, but I've always gone corner to corner, but I do it *every* run and haven't noticed any bad handling tendencies.
-rocky b
flatspunout is offline   Reply With Quote
Old 03-26-2009, 12:00 AM   #7
-rocky b
Corner to corner is that front left to rear right etc....actually if done every run, I can see the tires lasting much longer.
Old 03-26-2009, 12:04 AM   #8
pcar951's Avatar
Trader Rating: 19 (100%+)
Yup, corner to corner , every run. More consistent that way.
pcar951 is offline   Reply With Quote
1/10th pan car Taz_S Oval, Larger Scales and More 16145 12-21-2017 12:57 PM
TRF414M, 404x, 414, 414X TRF-Powered Electric On-Road 3600 11-01-2017 07:19 AM
TC3 Forum Lowrider Electric On-Road 12196 10-13-2017 09:47 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 08:59 PM
what would be the best hop up for a tc3? rctc3 Electric On-Road 24 03-18-2002 07:05 PM
tires rubber or foam carpet_killa Nitro On-Road 14 02-07-2002 09:33 PM
