Old 03-25-2009, 09:23 AM   #1
Default CRC GenX10: Allen key sizes and nut drivers for Imperial size!!
Hello from France,
I recently buy a CRC Genx 10, and have some problems to understand the size.
Screws in the kit:
2-56
4-40
8-32
Nuts:
2-56
4-40
What are the size tools for screws and nuts I need?
I know I need allen key 0.035 and 0.050 and I don't know other tools!!!
Thanks a lot.
Romuald
romuald31 is offline   Reply With Quote
Old 03-25-2009, 09:45 AM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
In addition to the .035 and .050 allen wrencehs, you'll need a 1/16" allen, and a 3/32 allen. The bolt on the left rear hub takes either a 5/64 allen, OR a 2mm allen.
You'll need a 3/16 nutdriver for the 4-40 nuts. I don't recall using any 2-56 nuts in my GenX...
MARSHAL!!
Trips is offline   Reply With Quote
Old 03-25-2009, 01:23 PM   #3
Thanks a lot,
the 2-56 nut driver is for the nut that prevent the play of the ball of the front end, and also for the ballstud.
Do you know that tool?
Au revoir.
Romuald
Old 03-25-2009, 01:59 PM   #4
Trips's Avatar
Sorry, I fogot about that nut in the front arm... I used a small needle-nose plier to hold that nut, but I just measured it and it is 5/32". The hex on the 2-56 ballstud is 3/16", same as the 4-40 nuts.
MARSHAL!!
