What gear grease to use?
What grease is the best to use? I've done a lot of searching and can't find a good answer. There has to be a better option than the tiny tube for 5 to 10 bucks. Thanks
Okay, I'll play along...
I've never used gear grease on any electric car. Why do you feel the need to put grease on the gears? |
Diff lube? Team Associated works good and is cheap...
you could use hair grease. then when you're done you could style your hair when your done lube'ing
note: you'll spend months to get it off the gear and casing....and it will drain you're cell faster (:-S) |
