Old 11-28-2003, 11:07 AM   #1
Send a message via AIM to zachzachz
Default Soldering help???
I'm looking to get a soldering iron and am clueless as to what to get. First of all what wattage iron should I get? I've heard that it should be above a certain wattage, but is too much wattage bad? Also what is the difference between solder and flux? Or are they the same thing? Also what size should I get if I'm going to be soldering batteries and motor leads?
Lastly, is there a good place online to look or buy irons?
TIA,
Zach
zachzachz is offline   Reply With Quote
Old 11-28-2003, 11:13 AM   #2
pro3racer's Avatar
most irons you can just get at menards, or hardware stores. The mininum should really be 60 watts, but that really isn't good for batteries. I wouls say 80 and up, it's a good allaround iron. It's fun when you can just heat it up, touch, touch, and your motors off. Solder ESC's is alittle tricky, unless you get a point tip, which i need to get.
pro3racer is offline   Reply With Quote
Old 11-28-2003, 11:31 AM   #3
There's this 80 watt weller soldering iron at home deopt for 20 bucks, is this a good iron?
Old 11-28-2003, 11:38 AM   #4
Send a message via AIM to Gped0124 Send a message via Yahoo to Gped0124
I am using the 60 watt hobico iron. It is probaly the best iron I have ever used, the tips are perfect. I just finished assembling my third pack with it, and its also great for hardwiring.
Gped0124 is offline   Reply With Quote
Old 11-28-2003, 12:27 PM   #5
akrcracer's Avatar
Go to www.bomir.com!!! Go and read the other soldering thread here.. Trust me and you will be happy if you get a Goot iron Or gun!!
akrcracer is offline   Reply With Quote
new to soldering windsurf17 Rookie Zone 32 04-30-2008 05:05 PM
Soldering ESC - need help jgroenhof Electric Off-Road 9 01-18-2007 11:38 AM
Soldering AZNracerx1989 Rookie Zone 22 08-05-2005 09:51 PM
soldering? SPC Racer Electric On-Road 13 10-02-2004 05:46 PM
Soldering Help RubbyT Electric On-Road 15 02-22-2002 09:46 PM
