Old 06-16-2009, 04:36 AM   #76
Benzaah's Avatar
Trader Rating: 21 (96%+)
I would pull the car apart and get something flat and make sure all your bulk heads and chassis are straight. Check all your pins and arms for bent bits and holes that are too big and make steering loose. If there are lots of problems here then there is only so much you can do. I heated my front left bulk head up a touch by boiling it in water and then put it in a vice between 2 sheets of steel to straighten it up a bit. Not exactly straight but close enough. Just make sure everything is tight when you rebuild and make sure that when you tighten up the chassis to the bulk heads they aren't inducing tweak. Then follow the steps as shown earlier in this thread to adjust the tweak that is left in the car. I don't think you can make these old girls perfect anymore unless you've got a heap of cash to throw at NIP parts or can pick up a heap with a roller in a deal on the forums.
Adelaide RC - XRAY Xb2’16de & Xb4’16
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 06-17-2009, 01:38 AM   #77
Originally Posted by Benzaah View Post
I would pull the car apart and get something flat and make sure all your bulk heads and chassis are straight....
Oh bother, hadnt even thought to check bulk heads, I'm still too getting over (angry) the amount of damage on the front of the carbon chassis ("in good condition , no damage to chassis").
Are bent bulk-heads common, they look pretty damn strong.
1101 is offline   Reply With Quote
Old 06-17-2009, 02:55 AM   #78
Benzaah's Avatar
A little bit of smashed chassis at the front is no biggie as long as it is not warped at all and effects the way the front bulk heads attach to the chassis.
NEW XRAY T2 ddesros2 Electric On-Road 5873 02-12-2012 06:56 PM
Xray T1FK05 Mdoc Electric On-Road 5433 01-31-2010 06:42 AM
Xray T1 FK05 FK-05 - OVERKILL OR NOT? paul73rc Electric On-Road 56 12-20-2007 08:32 PM
Xray T1FK'05 & Much More!! Jake S R/C Items: For Sale/Trade 18 05-30-2007 10:50 PM
Xray T1FK'05 Jake S R/C Items: For Sale/Trade 9 05-30-2007 10:48 PM
i want a xray FK 05' BiggAlz R/C Items: Wanted to Buy 17 12-04-2005 01:02 PM
