Old 04-14-2009, 04:11 PM   #46
chris moore's Avatar
Trader Rating: 88 (99%+)
I forgot, what surface are you runing on and what tires?
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 04-14-2009, 07:48 PM   #47
rockstar81's Avatar
medium asphalt (not cheese grater or super smooth), jaco greens
Dee & Mee Hobbies, Team Academy SBV2, Xray 009, Xray 007, Castle Creations, Spektrum DX3R, Ricky Racer Customz, Tekin, Thunder Power, Duratrax Onyx,
rockstar81 is offline   Reply With Quote
Old 04-22-2009, 12:18 PM   #48
rockstar81's Avatar
I was wondering if a balance issue will show on a tweak board? Still chasing this ghost a little. On a more upbeat note I took 2nd in Expert 13.5 this past weekend.
Old 04-22-2009, 12:20 PM   #49
rockstar81's Avatar
Also how do you go about getting a little more rear traction out of this car? Thanks.
Old 04-22-2009, 08:12 PM   #50
rockstar81's Avatar
ttt
Old 04-24-2009, 08:22 AM   #51
rockstar81's Avatar
bump
Old 04-24-2009, 10:12 AM   #52
I've never tried the greens so I'm not sure how those are affecting your traction, I run rp30 or rp36's depending on the temps and track. Also using the 2mm chassis will alow for more flex and more grip. Where are you lacking grip, entry mid or exit?
Sponsered by:
Old 04-24-2009, 10:14 AM   #53
rockstar81's Avatar
I am lacking rear traction/ maybe too much front? on exit.
Old 04-24-2009, 09:30 PM   #54
GasGod's Avatar
Try taking out 2 of the rear bulkhead mounting screws,the forward ones- it lets the rear have more torsional flex.Orings between the top plate and standoffs also give more flex.Seems to plant the whole chassis more-- but be carefull and try not to hit things too hard when ya do this.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 04-25-2009, 08:13 AM   #55
rockstar81's Avatar
I have tried that with 2 and 4 of the screws, tried removing 2 screws completely and I really didn't notice much if any difference.
Old 04-27-2009, 11:18 AM   #56
rockstar81's Avatar
bump for a rainy monday
Old 04-29-2009, 06:49 AM   #57
rockstar81's Avatar
I am open to any further suggestions... Thanks Phil
Old 04-29-2009, 03:47 PM   #58
Ok please post your complete setup as it is right now. I could'nt find a previous post with your complete setup and you've tried alot of changes so lets see you setup as it sits now. Everything front and back that would be on a setup sheet and other things like which traction addititive your using, my car is strapped and I run on an unprepped p-lot so we have to get you up to speed. One last thing, I have no way of knowing your skill level so do you feel that your rolling on and off the throttle? If your fast on the throttle in low traction conditions you'll struggle to find good traction at corner exit.
Chris
Sponsered by:
Old 04-29-2009, 05:12 PM   #59
rockstar81's Avatar
Thumbs up
Front Rear Chassis 2.5
caster 3 Top deck wide
camber 1.5 1.5 Rear hubs aluminum
Toe 0 3 per side No standoffs
springs white yellow
0il 35 35
pistons 2 open 3 open
diff med-tight med-loose
Inner camber mount location rear hubs w/ 1mm shim under mount
1mm shim under front camber links
rear arms shimmed center, upper front hole and middle rear for rear anti squat
middle front hole and upper rear for front anti dive
jaco greens all the way around
outer hole for front steering on knuckle
That should be about everything lmk if you need to know anything else, I feel I roll on and off throttle well w/ a slight tendency to jump the gun on throttle sometimes (usually when I feel I am falling back). I took 2nd out of seven at our first race this year (dang rain) in our expert stock 13.5 class.
Thanks Phil
Old 04-30-2009, 09:49 AM   #60
rockstar81's Avatar
5mm ride height front
5.5 mm ride height rear
NEW XRAY T2 ddesros2 Electric On-Road 5873 02-12-2012 06:56 PM
Xray T1FK05 Mdoc Electric On-Road 5433 01-31-2010 06:42 AM
Xray T1 FK05 FK-05 - OVERKILL OR NOT? paul73rc Electric On-Road 56 12-20-2007 08:32 PM
Xray T1FK'05 & Much More!! Jake S R/C Items: For Sale/Trade 18 05-30-2007 10:50 PM
Xray T1FK'05 Jake S R/C Items: For Sale/Trade 9 05-30-2007 10:48 PM
i want a xray FK 05' BiggAlz R/C Items: Wanted to Buy 17 12-04-2005 01:02 PM
