Old 03-28-2009, 05:24 PM   #31
rockstar81's Avatar
Wow I am amazed how unbalanced my car is, I don't have enough lead here to balance it. About how much did you use down the battery side of your car? Thanks Phil
Dee & Mee Hobbies, Team Academy SBV2, Xray 009, Xray 007, Castle Creations, Spektrum DX3R, Ricky Racer Customz, Tekin, Thunder Power, Duratrax Onyx,
rockstar81 is offline   Reply With Quote
Old 03-28-2009, 10:35 PM   #32
HarryLeach's Avatar
Send a message via AIM to HarryLeach
With 4200 NiMH batteries, it wanted about 2 ounces as far outboard on the battery side as I could get it, basically on top of the battery bars, which I don't like, so I don't run any weight when using NiMH packs, it's close enough to me to get by.
With a Tekin 3400 LiPo, it wants 6 3/4 ounces on the outer edge of the pack. I ended up having to apply it in 2 layers to get all the weight where it needed to be, and that's currently the only weight I have on the car, not even sure if it meets minimum weight because I haven't been able to check it on the track scale to see how much it might differ from the scales I'm using that desperately need to be replaced.
HarryLeach is offline   Reply With Quote
Old 03-30-2009, 07:41 PM   #33
rockstar81's Avatar
Its getting there, little more test & tune and I think it should be good. I'm up to 3.5 ounces of weight so far, still not quite balanced. Any recomendations on shock oil weight for technical 60 x 120 parking lot track? Thanks again for all the help.
Old 03-30-2009, 07:54 PM   #34
chris moore's Avatar
Trader Rating: 88 (99%+)
I like 30 front 25 rear myself.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 03-30-2009, 11:09 PM   #35
Trader Rating: 33 (100%+)
If you are running a LiPo, you can get a LiPo plate from Hyperdrive that wieghs 3.5 ounces then you could add from there to get it balanced, my 007 uses that plate with another 1/2 ounce on the right rear of the chassis to balance with SMC 5000's.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 04-01-2009, 04:55 PM   #36
rockstar81's Avatar
I still just can't seem to completely get rid of my spinout/oversteer issue when turning tight to the right. Diff settings?? Any other ideas/issues to look at? Thanks
Old 04-01-2009, 05:41 PM   #37
HarryLeach's Avatar
Hmmm... it could be.
What are your diff settings? I typically run a very tight diff up front [but not so tight that you have a spool], and just tight enough in the rear to eliminate slip.
Can you take any pictures of the car, maybe there's something I can spot that you're not thinking to mention, or don't know about?
If the issue is only on tight right hand turns, I'm thinking there's a setup or binding issue. If your weight balance was off too much, you'd traction roll rather than spin out.
What droop settings are you running?
Without physically seeing the car and/or seeing it run, I'm starting to be at a loss.
Old 04-01-2009, 08:59 PM   #38
rockstar81's Avatar
I'll see if I can't get pics up in the next day or two, I will try to change the diff settings and see if I can't get better results there. Thanks
Old 04-02-2009, 09:16 AM   #39
Born2Run's Avatar
rockstar81 check your shocks (lengh-rebound-springs) be sure you're using the same shocks hole position left-right ,use harder spings in front and check your droop settings.Have you checked the left-right steering amount on your transmitter?Maybe is to much on right hand turns.
One last thing (or maybe the first) is to check your bearings.
Whatever
Born2Run is offline   Reply With Quote
Old 04-02-2009, 11:12 AM   #40
rockstar81's Avatar
Have pretty much checked everything you mentioned at least twice, snow/ rain here today, maybe nicer tomorrow so I can check diff setting/experiment with them.
Old 04-07-2009, 09:05 AM   #41
HarryLeach's Avatar
Any new developments?
Old 04-07-2009, 11:55 AM   #42
rockstar81's Avatar
Not really, sorry I haven't got pics up yet. I have been busy building my cars (including a new XRAY Fk05) racing for me starts this weekend. I will try to get some pics up tonight after work. I figured I would build the new kit per manual and start to change setup from there.
Old 04-14-2009, 12:47 PM   #43
rockstar81's Avatar
Got the new car together, no rear traction what so ever. Car built per manual tried different variences in ride height and diff adjustents to no avail. Help. Sorry been busy no pics of other ride at the moment. Thanks Phil
Old 04-14-2009, 01:24 PM   #44
Magnet Top's Avatar
try lowering the rear roll center ( lower the position of the LOWER inner pivot pin ), and add some rear toe-in.
Magnet Top is offline   Reply With Quote
Old 04-14-2009, 02:29 PM   #45
rockstar81's Avatar
Already has 2 degrees rear toe, I can try lowering the rear roll center. Thanks
NEW XRAY T2 ddesros2 Electric On-Road 5873 02-12-2012 06:56 PM
Xray T1FK05 Mdoc Electric On-Road 5433 01-31-2010 06:42 AM
Xray T1 FK05 FK-05 - OVERKILL OR NOT? paul73rc Electric On-Road 56 12-20-2007 08:32 PM
Xray T1FK'05 & Much More!! Jake S R/C Items: For Sale/Trade 18 05-30-2007 10:50 PM
Xray T1FK'05 Jake S R/C Items: For Sale/Trade 9 05-30-2007 10:48 PM
i want a xray FK 05' BiggAlz R/C Items: Wanted to Buy 17 12-04-2005 01:02 PM
