Old 04-04-2009, 07:52 PM   #16
sounds like something for me to do in my spare time
out of interest what kind of sensors were you using for suspension position? I've used them on full size cars (and they are expensive) but trying to think up a way to make them RC sized and RC priced seems like a big challenge.
gameover is offline   Reply With Quote
Old 04-05-2009, 04:40 AM   #17
i used pots and servo horns. No real need for linear sensors.
Fred_B is offline   Reply With Quote
Old 04-05-2009, 05:49 PM   #18
i have a couple of 8051 dev boards here, i need to find a suitable serial eeprom and some time to fail twice then succeed the on the third..
Old 04-06-2009, 04:58 PM   #19
arj
Is there any way to modify it ( or by interpreting the data) to get lap times out if it? For me that is the real test of performance and when I'm at the track (other than race nights) I get no data on this.
If Novak added some low cost way to add lap times then I'd buy it in an instant.
arj is offline   Reply With Quote
Old 01-19-2010, 08:00 AM   #20
Trader Rating: 16 (94%+)
Novak - Is the Novak Sentry Data Logger discontinued? And, is it being replaced with a new model?
Seems we have found a good need for them with the latest generation of Speedo/ESC software. It will be ashame if these are discontinued.
kn7671 is offline   Reply With Quote
Old 01-19-2010, 08:24 AM   #21
Trader Rating: 38 (100%+)
From what I've seen the non-Pro model has been discontinued. Not sure about the Pro model. It's still available on their site.
or8ital is offline   Reply With Quote
Old 01-19-2010, 09:08 AM   #22
Company Representative
We are no longer distributing the Sentry Data Logger Pro, but we still offer them in our store. We have had so many orders lately that we had to put the product on pre-order status. We are building more, so we will have them in inventory in @10days.
NovakTwo is offline   Reply With Quote
Old 01-19-2010, 09:13 AM   #23
theisgroup's Avatar
was the spike in the last 5 days? sorry, your instant spike may have been due to kelly and myself. we purchase a couple and the data that your loggers provide is priceless with the new speedos and software. we have been able to shave .2-.3 a lap just using the info and re-tuning our speedos. just check out the tekin thread since this past weekend
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-19-2010, 09:26 AM   #24
I actually solved the "mystery" Sunday---by Googling around until I located the comments on this forum in the Tekin thread.
Old 01-19-2010, 12:58 PM   #25
Grenade10's Avatar
Trader Rating: 37 (100%+)
Some "Old Guy" started the purchasing several weeks ago around here and was running it prior to having V203 / 1 cell Mamba's in hand.
Everyone around was interested in the info for both onroad and really interested for OVAL!!!
Great little product Novak!!!!
Thanks!!!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 01-19-2010, 04:19 PM   #26
HB Moose's Avatar
I bought one from their website 2 weeks ago. And its still listed there today. It wasn't one of their biggest seller but now its only $50 I had to pick one up.
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 01-21-2010, 02:12 AM   #27
I threw together a log viewer to give me higher fidelity and a little easier browsing of log data. Teaser shots attached.
It shows the min/max for each graph line in the upper left. The white cursor shows the time in white, and current values for each line next to the cursor. Right Click + drag scrolls left and right. Mouse wheel zooms. So it's WAY easier to navigate than the sentry software.
-Mike
Novak Sentry Data Logger-wholelog.png   Novak Sentry Data Logger-threelaps.png
Old 01-21-2010, 07:23 AM   #28
mjc168's Avatar
Trader Rating: 25 (100%+)
-Mike
Where did you get the log viewer from? thanks
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline   Reply With Quote
Old 01-21-2010, 11:24 AM   #29
I wrote it last night. It's all straight C#, no funky requirements. It needs a bit more work before I want to share it with anyone (the path to the file to load is hard-coded), but send me an email through the board if you're interested.
There's a few tweaks I want to do with the drawing. Right now, for each graph line, the min value is mapped to the bottom of the window, and the max value is mapped to the top of the window. Unfortunately, that puts 0 in a different, non-labelled place for each graph line. I think I want to try drawing a 0 line, and mapping all data so that 0 is at the same place. For things like the accellerometer data, throttle (if you use brakes), and delta speed/RPM, I think that would make it more readable.
Also, if anyone has any interesting ideas for ways to analyze data, I'd like to hear it. The first obvious one I want to do is allow a range selection, where it'll show you the elapsed time for the selection, and the data values for each end of it. But being able to calculate some more information off the selection, like average RPMs, average throttle, time spent at full throttle, that sort of thing... Could be useful.
I also want some configurabable data adjustments, and calculated fields. Throwing out bad values that skew the min/max range makes the graph more readable. Calculating speed based off FDR and tire diameter, or rollout, is an obvious one. Some parameters for calibrating the throttle input would be nice. The accellerometers also tend to be a bit off on their 0 points, due to having the Sentry mounted a little crooked. Delta RPM hasn't looked very useful so far, but delta speed with some smoothing might be more useful..
For motor tuning, the most useful view I can think of would be to make a table where each row is like 10% of the range of throttle values, and each column is 1mph or something. Then for each data sample that falls with a given cell, add that sample to an average for that cell. This would be calculated for a whole log, or a portion of it. Then when you make gearing / timing changes, you could take another table, and then compare to previous runs. You could see if you're accellerating harder in some parts, and less in others, or whether it's better / worse everywhere.
Oh well, I've probably said too much now, since it'll take a while to write all that stuff.
-Mike
Old 02-25-2010, 01:00 AM   #30
Rouge711's Avatar
Hi guys, i have a problem with my new Novak senty Pro.
I think it's a software problem, I'll explain.
Carry out the procedure to load data from the sentry to the PC. The data is saved correctly on the PC, but when I go to open it tells me "Unable to load files".
I do not understand why and I have not found anyone with my problem.
My PC is a notebook with windows 7.
Any suggestions?
Team Associated
Team Trinity
Thunder Tiger Europe
Rouge711 is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 01:18 PM
NOVAK SENTRY DATA LOGGER....????? freestyles Radio and Electronics 16 02-09-2009 02:44 PM
