Old 12-16-2003, 02:43 PM   #91
yodace's Avatar
R/C Tech Charter Subscriber
use the spring combo that comes with motor?
yodace is offline   Reply With Quote
Old 12-16-2003, 03:22 PM   #92
Skip109's Avatar
Hey guys any time you think our sport is costly go to http://www.slotcarcity.com/ and check out the group27 6mag motor 259.00$ HOLY S__T
Skip109 is offline   Reply With Quote
Old 12-16-2003, 05:50 PM   #93
Super Moderator
Grizzbob's Avatar
Originally posted by fast-ho-cars
in pro type 1/24 slot car racing Quads were used in the early 80's. now in some (but not the stock type classes) classes they are up to 6-10 magnet segments on each side. they run on high power tracks.
www.slotcarcity.com
www.radtrax.com
www.oldweirdherald.com (slot car forum)
the huge wood tracks they run on, are usually 12v-16v powered with up to 4+ industrial Caterpillar type batteries with a trickle charger on them. they supply haneous and strong amperage thru out the race.
in 1/24 slot we want strong matched magnets. to the point their is no cog / thump as you turn the arm. this results in higher rpm and less vibration.
don't think slotcars are not prevelant to RC.....the endbells you enjoy today were used about ten+ years prior to the RC car industry using them. Prior to 1980, RC motor brushes were on copper levered endbelled Igarashi/Mabuchi type motors. i use to look at my Mura motors and wonder why these endbells weren't used on my RC motors back in 1978.....
also not to mention Armature technology ideas borrowed from 1/24 racing and the GOLD Dust brushes 1/24 guys have run for years now
don't know if the magnet technology will apply to stock RC motors as it does to Mod motors. maybe if istock was changed to a 19T type motor. i think the 27t is limited on being able to utilize this technology......as it is with the 16D class motors used in basic 1/24 racing
You're absolutely right, Trinity is actually one of those companies that got its start making products for slot cars, & that's where they've gotten their ideas for some time. But as we've seen, some ideas will work better than others....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 12-17-2003, 07:57 AM   #94
CypressMidWest's Avatar
Default legality
It always slays me when ROAR takes a stand on motor development. A stock motor is like $28. A competitive 6-cell pack on the other hand is like $70+, but new batteries are approved all the time.
In the Dark Days before rebuildables you only got about three good runs out of a stocker, then the comm was shot. Then the stock lathes came out and ROAR banned their use, stating that not everyone had access to a lathe. Finally we got rebuildables, which made it even more important for the average racer to have a lathe. Quad mag motors are just an evolutionary step, whether or not they offer any performance gain is still up in the air, but why ban them? There are people on here who swear that Monsters are faster than the Binary anyway. I personally think those folks haven't figured the Binary out yet, but whatever. I also feel it's more the arm than the can though. Interested in seeing what the binary arm, monster can combo yeilds. I can say however that the stockers I ran at Cleveland were THE FASTEST stock motors I've ever strapped in my cars.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-17-2003, 08:14 AM   #95
For what it's worth...
I'm not sure the value that slot cars see with multi magnets will directly translate to the RC electric motors. A couple things come to mind... we do not run anywhere near the same voltage or amperage that slot car motors will see. We also don't have anwhere near the same kind of RPM that a slot car motor will see (largely because we don't have the same voltage and amperage)...
In other words... just because slot car motors work better with multi magnets, doesn't mean RC motors must also work better with multi magnets.
DynoMoHum is offline   Reply With Quote
Old 12-17-2003, 08:32 AM   #96
birdy233's Avatar
Trader Rating: 78 (100%+)
Ok, question about motor dyno sheets, what do these numbers mean?? I know each category, but what numbers mean a good motor?
Constant Volt 6.50
25479 0.9 18 21 12.9
22502 4.0 67 59 17.1
19675 7.1 103 70 22.5
18034 9.0 121 69 26.7
16348 11.0 133 63 31.8
14563 13.2 142 58 37.4
birdy233 is offline   Reply With Quote
Old 12-17-2003, 08:32 AM   #97
rayhuang's Avatar
I am going with Ian on this one-they are fast-very fast-but so far they are temperamental for me. MIne stay fast for one run-then are so slow like they blew a cap. But after a full rebuild are fast again.
IN fact-one motor quit 2-minutes into a practice at Champs-just quit, but servo worked, batteries discharged fine. Again-cut it-new brushes-it was fine again and in fact became my best motor.
For sure they run hot and are not efficient as well. But we will learn them as well as any other motor and this whole discussion will seem trivial in two months.
Old 12-17-2003, 08:42 AM   #98
Birdy,
Your question is one that could be debated for days, weeks, or even years...
My personaly opion... get the highest Power you can at and around 30 amps... or even as high as 36 amps... The more power the better... The lower amp loads are not of that much value I don' think... not as a modern racer with 3300 mAh batteries.
I'm used to seeing 28 amp numbers at 7 volts constant from CD TD users... so I can't really comment on your specific numbers.
Old 12-17-2003, 08:49 AM   #99
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
BS gearing question
I continue to read that racers are dropping teeth (2 to 3)having switched to the new BS. That being said what does dropping 2 equate to?
Asumming I run my Monsters at a 7.1 to 7.3 final drive in TC...should I move toward a 7.8 to a 8.0 final?
thanks for your help.
madjack is offline   Reply With Quote
Old 12-17-2003, 08:52 AM   #100
Opps... I shouldn't have said that the numbers at lower amp steps don't matter... That is not true... it's just that I wouldn't look at it in relation to amp input... This is a area where things get really tricky, and I'm not prepared to go into my theroy on it at this time.
Old 12-17-2003, 08:54 AM   #101
birdy233's Avatar
The "dyno" sheet is what comes with the "Factory" tuned motors you can buy, what the heck is a good motor when looking at those supplied sheets? Are those things worth a crap?
Thanks!
Old 12-17-2003, 09:02 AM   #102
Who's factory?
Trinity/EPIC uses a Fantom Dyno these days, and those are not Fantom numbers. So you must have got the motor from someone other then Trinity/EPIC
What value your data is, depends on many things, the first of which and most important is... were the brushes fully seated when the test was done? You will never really know for sure unless you watched them run the test and had looked at the burshes before hand... If you look at them when you first get the motor, you could assume they are in the same condtion they were in when the motor was tested... and if your motor tuner is honest, then that is a good assumption...
Old 12-17-2003, 09:13 AM   #103
birdy233's Avatar
The motor is a Birdman, which I believe uses P2K cans?? What dyno is used is unknown?
Old 12-17-2003, 09:17 AM   #104
Is your sheet printed on something that resembles a old cash register receipt? if so, then it's from a Competition Electronics TurboDumo 45. Based on the numbers you've given, that is likely what it's from.
P2K? I was expecting a EPIC Binary 2 'outlaw stock' motor, since that is what this thread was/is about...
Hmmm.
Old 12-17-2003, 09:20 AM   #105
birdy233's Avatar
Yep, looks like a cash register receipt. (I didn't want to start a whole new thread) So what is a way to look at those a determine which motor has better #'s? Thanks for the info!!
12 used fantom monster & fantom binary balanced stock motors 2 epic roar stock brand jason cheng R/C Items: For Sale/Trade 11 06-06-2005 08:23 AM
wtb epic binary stock motor crACkeD ChaSsiS R/C Items: Wanted to Buy 1 06-16-2004 10:28 AM
Stock Motors - Monster and Binary Stock Nexus R/C Items: For Sale/Trade 3 04-25-2004 03:47 PM
EPIC Binary 2 Stock Motor nutfluff R/C Items: For Sale/Trade 8 02-23-2004 08:58 PM
EPIC Binary Stock motor rayhuang Electric On-Road 31 10-16-2003 01:12 PM
