Old 12-21-2003, 08:00 PM   #151
hierog's Avatar
cool, thanks for the info. I put a 32 pinion on it this weekend and ran it, but it ran really hot (216 degrees). I then changed back to a 35 to run my monster stock, got sidetracked and forgot to change the motor out and fried it! i literally smoked it on the track during heat 1! Good thing it's only $30! So, I'll run it with a 30 or 31.
vic
hierog is offline   Reply With Quote
Old 12-30-2003, 02:40 PM   #152
fast-ho-cars's Avatar
Default NEWS FLASH.....Binary Stock bites my FARHVEGNUGEN!!!!
i have had no luck with it in Touring cars
went down 2, then 3 teeth, on 48P gears
went to dual red springs then red + & green -
tried 2 other types of brushes
tried a Monster arm in the Binary can (they appear alike at first...the BS arm is shorter and has 4 less laminations on the stacks)
NO Luck....it's still a dog
mine was the EPIC factory tuned version and had heavy trinity purple springs on both sides. after two 5 min qual heats the arm had wear on the comm equivilent to a Monster with 9 heats on it.
now the offroad guys are gearing them with 15T 48P pinions and they like everything but claim the motor lacks brakes / braking power. brakes worked fine for me in TC?
fast-ho-cars is offline   Reply With Quote
Old 12-30-2003, 04:04 PM   #153
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Try going to a Reedy 767 with Purple (+)/Red(-) springs. Also, if you can, zap the magnets, improves the motor significantly.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-30-2003, 10:17 PM   #154
Zapping the magnets is a must, even on Pro motors. The BS motor I bought was a Pro and the magents were nearly dead out of the box. I suspect that the magnet were never zapped, and magnets need to be zapped anytime they are removed, cut, and reinstalled in the can (which is exactly what happens with the BS). Anyway, mine ran much better after a zap. It was 10 watts stronger at every AMP step from 20-45 according to my Robi. It was still not as strong as my best MS motors on the dyno or track (stock TC), but it was much better than it was out of the box.
Shiloh is offline   Reply With Quote
Old 12-30-2003, 11:05 PM   #155
RCGaryK's Avatar
Ok, with this talk of magnet zapping, how are you sure you are zapping the magnets correctly? with quad magnets, wouldn't you need a quad pole zapper? I'm really curious because my Binary puked on me after being overheated.
John, did you try the setup I sent you?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-31-2003, 12:40 AM   #156
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by Brian McGreevy
Ok well all I know is many people who run here have been dropping 4 teeth running 64P, but thanks for the info...should've thought of that myself.
Yeah... no crap.. haha...
I was told to drop two teeth, and run it like it was. Ended up coming off the track at 230*.
Worst thing is, I had better times when I was overgeared. Probably fried the mags, along with the com and anything else. Hopefully it will pick back up after I get a few cuts on the com.
Gary - Doesn't someone at trackside have a zapper? They had one upstairs during the novak race last year, but they wouldnt let me use it. If you know anything, let me know, I wouldnt mind zapping the BS & a monster i heated up...
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-31-2003, 12:55 AM   #157
Neil Rabara's Avatar
There isn't a whole lot of people out here that have zappers either. Not at the track anyways.
Neil Rabara is offline   Reply With Quote
Old 12-31-2003, 07:38 AM   #158
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
May be a stupid question, but can you Zap a quad magnet motor with a regular 2 pole zapper ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-31-2003, 07:49 AM   #159
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
from what i am told, yes, you can zap it with a reg zapper
Matt M. is offline   Reply With Quote
Old 12-31-2003, 07:49 AM   #160
From what I've heard you just zap them like any other motor.
DynoMoHum is offline   Reply With Quote
Old 12-31-2003, 07:57 AM   #161
TimPotter's Avatar
So I guess they are the same polarity on each side, just split ?
Old 12-31-2003, 08:26 AM   #162
I personaly do not know for sure how the polarity is oreninted in the Binary motors... Orignialy I was lead to beleive that the Reedy Quads were oriented differntly then the EPIC motors, and that the Reedys you would just zap like a regular motor but the EPICs might need some other tecnique that might not even exsist for the masses... but then Recently I've heard that you zap the EPIC's just like a regular motor too...
I do not have a zapper and I have no first hand knowlge of what is the proper thing to do. Mostly I am going by commentst that Todd Putnam has made when I say... 'from what I've heard, you just zap them like any other motor'... I trust Todd about as much as anyone when it comes to motors... so take my comments for what they are worth on this matter... (second had from a good source)
Old 12-31-2003, 08:52 AM   #163
RCGaryK's Avatar
Troy, Brad's going to have his there at the Novak race and he offered to zap my motor for me. Just talking with Russ, plus my own thoughts on it before I talked to him, left serious doubts in my mind whether or not a regular 2 pole zapper would work with a BS. I still gotta think a quad pole zapper would do a better job then a 2 pole zapper.
HorizonHobby.Com
Old 12-31-2003, 11:00 AM   #164
TimPotter's Avatar
Thanks for the input guys
Old 12-31-2003, 11:06 AM   #165
RCTech Member #2
TSR6's Avatar
I'm posting on *gasp* Trinity Tech Talk in hopes that Jim Dieter sees the thread, see if we can get a positive answer on the zapping.
Troy
RCTech Member #2
12 used fantom monster & fantom binary balanced stock motors 2 epic roar stock brand jason cheng R/C Items: For Sale/Trade 11 06-06-2005 08:23 AM
wtb epic binary stock motor crACkeD ChaSsiS R/C Items: Wanted to Buy 1 06-16-2004 10:28 AM
Stock Motors - Monster and Binary Stock Nexus R/C Items: For Sale/Trade 3 04-25-2004 03:47 PM
EPIC Binary 2 Stock Motor nutfluff R/C Items: For Sale/Trade 8 02-23-2004 08:58 PM
EPIC Binary Stock motor rayhuang Electric On-Road 31 10-16-2003 01:12 PM
