Old 03-18-2009, 02:29 AM   #1
BudD's Avatar
Exclamation Duo Timing........
Alright guys, is it really 0, 10, 20? Or is it 10, 20, 30?
I have conflicting data from 2 sources and I need it verified.
I know the 12th guys are running 0 degrees with max boost on
Tekin Speedo so it must be 0 degrees? Right?
Thanks..............
BSR/Muddslide Motorsports/ORC/Hyperdrive/SMC/Thunder Power
BudD is offline   Reply With Quote
Old 03-18-2009, 03:47 AM   #2
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey BudD,
Yes With Full Timing Boost on the Speedcontroller and zero Degrees on the Duo that's the hot ticket for the Tekin
Hope This helps
Mike
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 06-04-2009, 02:24 AM   #3
s13evo's Avatar
sweet
s13evo is offline   Reply With Quote
Old 06-04-2009, 03:04 AM   #4
Trader Rating: 16 (94%+)
Timing is 0, 10, 20.
kn7671 is offline   Reply With Quote
Old 06-04-2009, 05:55 AM   #5
Trader Rating: 38 (100%+)
My understanding is that it varies a bit from Duo to Duo. It's probably 0-10, 10-20, 20-30.
or8ital is offline   Reply With Quote
Old 06-04-2009, 06:42 AM   #6
Not really. This is my understanding.
Due to assembly variances, and manufacturer design, we are hearing that almost all brushless motors actual 'true' base "0" degree timing mark/setting can be between 0-40 degrees within the motor. An RC Sensored Brushless motors timing is not defined by ROAR.
Asking what the "actual" motor timing is at each timing setting cannot be determined from the outside of the motor, only the manufacturer could tell you that, but most choose not to. The assembly variances in the stack could cause it to be slightly twisted in the can, solder joints slightly to the sensor ring can be slightly off center for more built in advancement, etc... All assembly variation and/or motor design.
This FACT remains on the DUO, the timing holes are 0, 10, and 20 degrees timing advancement. Brushless motors external timing adjustments are simply an adjustment to the motors stock timing. This is the same for the DUO, the timing adjustment holes are not relational to the motors stock timing, but how much timing you're adding on top of the motors stock "built-in" timing.
For example, if the DUO's stock timing is 25-deg, and you put the timing adjustment at full clockwise, you now have a total of 45-deg advanced timing, likewise full counter clockwise would be 25-deg, and middle hole 35-deg. *** This is an example, as I don't know what the "built-in" timing is for the DUO motor.
DUO Timing Holes:
Full Counter Clockwise = 0-deg additional timing
Middle Hole = 10-deg additional timing
Full Clockwise = 20-deg additional timing
Old 06-20-2009, 01:03 AM   #7
i am looking at gettin a new motor and the duo by team epic look good. has anyone got some feedback for me about their 13.5 and 10.5. i know that this would be their duo two versions but how are people liking these
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 07-18-2009, 12:25 AM   #8
bkspeedo's Avatar
So does anybody truly know the average Stock\built in timing for duo motors?
As pointed out earlier the 0 deg hole on the motor is not really 0 deg timing in the motor. There some default timing built in that needs to be accounted for when using a timing adjustable ESC.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-18-2009, 06:31 PM   #9
TheCoolCanFanMan's Avatar
+1
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 07-18-2009, 06:44 PM   #10
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I don't know if this helps, but the Duo's with the three timing holes are nothing more than SpeedPassion motors with adjustable timing. So Duo in 0* timing = SpeedPassion. You might have more luck asking what the std timing built in for a SP motor is over in their thread . . .
Old 07-18-2009, 06:49 PM   #11
Why do you need to know the "built-in" timing?
I don't think having this info will help with setup much, as it will probably vary across motor to motor so much, that it won't be a consistent enough number to base anything on. Just know that almost all brushless motors have factory advance timing built-in, between 20-40deg.
On the LRP X-11 Stock Spec for example, I was told by Reto at LRP that the stock base timing is 40-deg! The adjustment on the LRP X-11 motor allows an additional 0-deg to 19-deg timing for a max mechanical timing of 59-deg!! Now I don't know about you, but knowing that base 40-deg timing doesn't help me figure much out.
There are also so many people running this motor that we have DUO setup tips galore. Follow the tips from others with the DUO, and enjoy going fast.
Old 07-18-2009, 07:10 PM   #12
bkspeedo's Avatar
I'm using a Tekin RS ESC so it would be nice to know the real total timing.
Thanks for the input.
Brent Klingforth
5280 Raceway
Old 07-18-2009, 07:31 PM   #13
What are you running it in?
Old 07-18-2009, 08:53 PM   #14
hello everybody im new to r/c so i still have a brushed motor its a speed gem extreme 10t motor will advancing my timing give me more power just like advancing timing in a real car does
mospeed is offline   Reply With Quote
Old 07-18-2009, 09:42 PM   #15
Timing advance BL or brushed just moves the power band around. It doesn't create any power that wasn't already there, although it may make the power more useful.
Seattle RC Racers/Hangar 30 PutAwayWet Northwest Racers 18803 Yesterday 08:34 PM
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Ko BMC Speedo Green Speed Electric On-Road 1289 11-05-2015 07:06 PM
Trinity Pulse motor Drift Demon Electric On-Road 240 05-17-2012 02:45 PM
