Old 07-18-2009, 11:51 PM   #16
bkspeedo's Avatar
I'm using a DUO 13.5 in an X-ray 007.
Tracks:
rough pavement 100'x70'
carpet 60'x70'.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-20-2009, 03:08 PM   #17
TheCoolCanFanMan's Avatar
I have one of these motors and am very impressed with it, so have bought another one, but what I would like to know is, what would I benefit from moving the timing from factory to the furthest hole round, does it give me more revs, or more grunt, in other words, if on a large flowing track do I leave it stock, or would I benefit moving the end bell to the next mark and so on?
Cheers Malc TCCCFM
Originally Posted by kn7671 View Post
Why do you need to know the "built-in" timing?
I don't think having this info will help with setup much, as it will probably vary across motor to motor so much, that it won't be a consistent enough number to base anything on. Just know that almost all brushless motors have factory advance timing built-in, between 20-40deg.
On the LRP X-11 Stock Spec for example, I was told by Reto at LRP that the stock base timing is 40-deg! The adjustment on the LRP X-11 motor allows an additional 0-deg to 19-deg timing for a max mechanical timing of 59-deg!! Now I don't know about you, but knowing that base 40-deg timing doesn't help me figure much out.
There are also so many people running this motor that we have DUO setup tips galore. Follow the tips from others with the DUO, and enjoy going fast.
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 07-20-2009, 03:15 PM   #18
fla racer57's Avatar
Trader Rating: 1 (67%+)
http://www.teamepiconline.com/shop/i...p?item=TEP1001
fla racer57 is offline   Reply With Quote
Old 07-20-2009, 03:30 PM   #19
Johnny Wishbone's Avatar
Cheers Malc TCCCFM
Hi Malc, here is what I have found. If you where to advance the timing to the third hole (or 20* advance timing if we assume that the first hole is 0*, 2nd hole is 10* and 3rd hole is 20*), now this does not mean 20* total timing but a additional 20* added to a unknown built in setting. In any matter going to the third hole will give you more RPMs. From what I've seen on the dyno this is still a safe advance, although the motors I have played with seem to show that at about 18* and up is when the efficency starts to drop off on the motors.
Old 07-20-2009, 04:34 PM   #20
Hi JW
So if I leave the gearing wear it is, and turn it by 1 hole (say 10 degrees) then would rev more, so why don't I gear it up by 1 pinion, what would the difference be? Hope this makes sense
Cheers Malc TCCFM
ps
Have you tried the Duo 2?
Seattle RC Racers/Hangar 30 PutAwayWet Northwest Racers 18806 Today 05:56 PM
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Ko BMC Speedo Green Speed Electric On-Road 1289 11-05-2015 07:06 PM
Trinity Pulse motor Drift Demon Electric On-Road 240 05-17-2012 02:45 PM
