Old 11-25-2003, 07:03 PM   #1
Send a message via AIM to mrredrsx02
Default charging 3300 battery?
i have a couple battery pak that are 3300 and my charger only can charge at 4amp. is that an ok charge or do i need to get a charger that charge more than 4 amp? beacuse most 3300 battery are charge at 5 amp rigth. if i charge at 4 amp does that meant the voltage will not be that strong?
mrredrsx02 is offline   Reply With Quote
Old 11-25-2003, 07:09 PM   #2
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
I charge my GP3300's at 6.5 w/ a .05 peak detect. 4 amps should work OK, but it's the peak detect you want to make sure you have. I wouldn't go over .05.
Speedo is offline   Reply With Quote
Old 11-25-2003, 07:35 PM   #3
KevanB's Avatar
Is that 5mv?
KevanB is offline   Reply With Quote
Old 11-25-2003, 07:56 PM   #4
JoshR 85's Avatar
HeY!!!
It should be ok but i'd get a better charger just to be safe and won't stand any chance of ruining the packs ya know....
JoshR 85 is offline   Reply With Quote
Old 11-25-2003, 07:58 PM   #5
KevanB's Avatar
I have a 969 pro so its fine. I just need to know the right amps and right delta peak.
Old 11-25-2003, 08:38 PM   #6
Speedie's Avatar
Default Re: charging 3300 battery?
What type of battery charger yo you have? Charging at lower amps will give you longer run time and be easier on your cells but it will be at a loss of voltage. It depends on if you race or not and how serious you are.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 11-25-2003, 09:04 PM   #7
Moderator
Speedo's Avatar
Originally posted by KevanB
Is that 5mv?
That's 50mv
Old 11-25-2003, 09:35 PM   #8
KevanB's Avatar
Oh then no problem charging it. What exactly does MV decide? More punch or power?
Old 11-25-2003, 10:14 PM   #9
Joel Lagace's Avatar
MV is the value the charger looks for to determine a fully charged pack. ITs looking for 50MV voltage drop after peak voltage starts to drop.
For example:
charged pack is at:
8.90Charging
8.99
9.10
9.11
9.12
9.13
9.15**peak volts
9.14
9.13
9.12
9.11
9.10STOP charger stops
From peak to charger stop the voltage will bounce alitlle once the charger detects the set voltage drop the charge will be done. Basically the charger sees the peak but waits for the voltage to drop indicating a charged pack.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-26-2003, 08:33 AM   #10
ooops wrong thread. sorry
mandy is offline   Reply With Quote
Old 11-26-2003, 09:25 AM   #11
I charge my 3300's at only 3 amps and am able to keep up with even the fastest drivers at my track. How does that actually work?
My runtime is actually longer than some that charge at a greater rate.
sook is offline   Reply With Quote
Old 11-26-2003, 09:34 AM   #12
ChrisP's Avatar
50mV is still over 8mV per cell. Just how hot do your batteries get?
You're not heating them to the point where they vent are you?????
ChrisP is offline   Reply With Quote
Old 11-26-2003, 01:32 PM   #13
PitCrew's Avatar
I charge at 10 amps on my Tekin BC112c. I usually charge my packs untill fluid is being excreted from all the cells, and the shrink wrap iw tearing because the cells are swelling up.
That usually give me the best voltage. That isn't bad is it?
PitCrew is offline   Reply With Quote
Old 11-26-2003, 01:40 PM   #14
That is funny!
Don't you have a legitamate answer for those of us that do not actually know.
Old 11-26-2003, 01:53 PM   #15
Moderator
Speedo's Avatar
Windsorguy - they get hot, but no they do not vent. This is the charge Fukuyama recommends and it has worked well for me.
Step Charging GP 3700 and GP 3300 rcnewb2004 Electric On-Road 3 07-20-2006 12:31 AM
Charging 3300 with Duratrax ICE speed6 Electric On-Road 5 09-29-2005 06:52 PM
3300 charging LancerEvoV Rookie Zone 8 07-24-2004 08:05 AM
Charging Sanyo 3300 fai Electric On-Road 2 12-18-2002 07:24 AM
