Old 03-17-2009, 01:25 AM   #1
Default I need some plastic tube... where can I find it?
Hey all
I scored the yeah racing suspension kit for $15 with a few of the plastic bushes missing so I'm trying to find some plastic tubing so I can make some to fit but I'm having trouble finding even one place that sells plastic tube :/
Measurements are 4mm OD and 3mm ID
5/32 won't work as that is 3.9mm and I end up with slop in the arms
If you look at this pic you'll see the clear plastic bushes in the arms
Any ideas on what I can do here
EDIT: After too long of searching I finally found the parts, so I'm posting for future searchers
http://us.rcmart.com/rc-nitro-3evoss...th=595_737_587
suprra_girl is offline   Reply With Quote
Old 03-17-2009, 01:39 AM   #2
Hyde's Avatar
i might be 100% wronge but what about some fuel tubing? I've used it for susp' arm shims.
maybe it will work?
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 03-17-2009, 01:46 AM   #3
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
MCmaster carr...
They have a wide selection of nearly anything you can imagine. If you use the searchfunction there, you will easily find what you may need in a variety of measurements and materials.
http://www.mcmaster.com/
Good luck!
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 03-17-2009, 01:47 AM   #4
Thanks for the suggestion, I'm thinking that fuel tube might be a bit squishy tho? Unless theres a different grade? Maybe, hope so hehe
Old 03-17-2009, 01:50 AM   #5
As i said, with mcmaster you can find anything, nylon, ABS, steel, you name it. I wouldn't use fuel tubing as it would allow the arms to "wonder" while on the hinge pins.
Old 03-17-2009, 01:56 AM   #6
^ heh, I was typing my reply as you sent yours
Didn't see it till I posted, great site, thanks alot
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 09:40 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
Neon/ Underglow Kit Tutorial! Blazin~ Painting, Designs, Graphics and Photography 10 04-25-2009 03:08 AM
Need help with micro setup microdude Electric On-Road 12 02-29-2004 08:25 PM
