Old 11-25-2003, 01:14 PM   #1
Default suspension tuning
iam a bit confused.i understand that
softer suspension will increase grip but need it stiff enough to stop grip roll.
roll bars reduce grip by making it stiffer.
but if you go to soft stiffer springs will increase tractuion.
and vice versa.
but what about top canber links.
is a longer top link better for increase in roll and shorter gives less roll?
also a higher top link will increase roll and a lower top link will decrease roll.
cheers.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 11-25-2003, 01:26 PM   #2
Cole Trickle's Avatar
Here you can read a lot about suspension tuning.
But before confusing things too much, I strongly recommend, you take your car as far as possible, with the basic stuff.
That is:
1) Set all to stock position. Including a pretty neutral body.
2) Then get the right tire/insert combo. Ask the fast guys at the track.
3) Find the proper spring/shock oil combo.
About 3): Keep front rear pretty close, that is, only 1-3 spring rates between front/rear. You might want to start out with a thin oil. This way you know what the springs do without the potential confusing from eventual improper shock oil. Now work with the springs. When the best results is found, experiment with shock oil.
And do only one thing at the time.
You might be quite surprised how well the car can handle by doing it like this. Maybe you dont even consider camber links and sway bars afterwards.... Believe me, I've tried it...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 11-25-2003, 01:32 PM   #3
cheers.
its only this.
someone else actully confused me on another forum.
but i will take no notice of them as i know what works and what doesnt.
cheers.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Looking for a link to suspension tuning Cannondale1974 Nitro Off-Road 8 08-12-2008 03:10 PM
unorthodox suspension tuning help.please look. lifeworthliving Nitro On-Road 3 03-27-2008 06:57 PM
suspension tuning rc10t4oval Rookie Zone 9 12-05-2006 03:04 PM
suspension tuning thread imataquito Electric On-Road 7 11-10-2003 09:43 AM
Help with suspension tuning (TC3) unknown Electric On-Road 9 02-22-2003 09:32 PM
