Old 03-16-2009, 02:46 PM   #1
arcarle's Avatar
Default Wheelie Capability
Let me start by explaining my normal usage and some spec info.
I almost always bash (dirt, grass, concrete, asphalt) My Slash is stock except for aluminum rear stub axle housings, sidewinder 4600k esc and brushless motor, and an rpm rear shock tower. The gearing is the standard 18/86. As of now I run 3300mah nimh 6 cell packs. I have ordered 2x Zippy Flightmax 2s1p 20c 5000 mah lipos.
Set up as is with the batteries I have now I gps at 29 mph and mainly spin wheels on the take off from a dead stop. The front end lifts a little and the rear end squats but no lift off of the front wheels. Do you think when my ;ipos come in they will give sufficient punch to pull the front end up or will I have to change gearing?
Thanks alot ahead of time! I would especially like to hear from someone with a similar set up that does pull wheelies.
arcarle is offline   Reply With Quote
Old 03-16-2009, 02:58 PM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
Since you metioon that you're spinning the rear wheels when you punch it, you are not likely to see wheelies by changing to LiPO. The two things that produce wheelies are having enough power and rear grip. Since you are spinning the rear wheels now, you need more rear grip. If you get to the point where you have enough rear grip to NOT be able to spin the rears when you punch it, you'll either be doing wheelies, or then you'll need more power.
MARSHAL!!
Trips is offline   Reply With Quote
Old 03-16-2009, 03:05 PM   #3
MikeXray's Avatar
Trader Rating: 73 (100%+)
Chances are your very under geared for your motor as well, I'm not sure how big of a pinion you can fit, but I'd start going up in gearing and you should see more overall speed and acceleration. As far as wheelies go, tape your 6 cell pack to the rear bumper when your lipo comes in and you'll wheelie the whole block
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-16-2009, 04:33 PM   #4
arcarle's Avatar
Good point. DUH me lol. I am spinning quite a bit. I guess some new tires are in order. Or maybe warmer days comin soon will warm the surface up a bit and traction will be better. I guess we will see. Thanks for your help today Mr. Trips.
I have been thinking about trying the 23 tooth pinion. Just havent done it yet.
But since Im spinning wheels as is I think I'll work on my traction trouble before trying gearing.
Thanks guys.
Old 03-16-2009, 11:46 PM   #5
Drifting101's Avatar
The stock slash tires suck, get some 1/8th buggy tires with little knobs. Go over to the slash thread in the elec offroad section and ask what gearing is and what rims/hubs would be best
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 03-17-2009, 01:54 PM   #6
arcarle's Avatar
I was lookin into gettin a set of switch tires with some epic bead locks.
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 09:40 PM
1/18 Scale - BRP, HPI Micro ozone Singapore R/C Racers 4034 09-03-2009 02:02 PM
Wheelie truck! ordinaryzam Malaysian R/C Racers 137 03-11-2009 05:58 PM
Cheapest decent monster truck tedb43o2o3 Monster Trucks 16 02-16-2009 10:11 PM
