Old 03-13-2009, 08:27 AM   #1
Default How do i use Shims?
My TT-01 has an extreme amount of play on the front wheels. And I was advised to use shims. How do i use them?
grategenin is offline   Reply With Quote
Old 03-13-2009, 08:54 AM   #2
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
in this application, 'shims' are nothing more than washers. when washers are referred to as shims, it usually implies that they are very thin/precise.
procedure: identify the axis that needs additional material to take up the 'play', and add washers (shims) in the appropriate location, being careful not to add more shims than the gap will allow for.
done.
note: 'play' can come from more than just an unshimmed front end. old/worn ball cups, bearings, and poor part tollerances will all add up to a very sloppy car.
note 2: some slop is advisable as it allows for the racing surface imperfections to be absorbed rather than than transmitted to the chassis. how much depends on your ability and application.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-13-2009, 09:33 AM   #3
Regional Moderator
CarbonJoe's Avatar
Note 3: Also make sure that the inner and outer diameters of the shims (or washers) are the correct dimensions so that they don't interfere with bearing seals, plastic parts, etc. You don't want to add unnecessary friction/wear if at all possible.
Note 4: The shims can be used to take slop out, or they can also be used to make the track wider (to a point), depending on which side of the "drive pin" or wheel hex they are placed on the axle.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-13-2009, 10:53 AM   #4
Everything on my TT-01 is new. I have only ran it 4times.
Old 03-13-2009, 10:58 AM   #5
RC_Dan's Avatar
Send a message via MSN to RC_Dan Send a message via Yahoo to RC_Dan
typically you'll need to add shims to the suspension arms hinge pins. Look at where the hub carriers meet the arms and see if there is any play for/aft. You may also need shims on the axles between the bearing and drive hub. Hope this helps.
AE TC6 B4 & 18T, Kyosho Lazer ZX-5
CRC Gen XL & Battle Axe, Hot Bodies Ve8
460whp CRX on E85
RC_Dan is offline   Reply With Quote
Old 03-13-2009, 10:59 AM   #6
Trader Rating: 38 (100%+)
new cars need to be shimmed too.
or8ital is offline   Reply With Quote
Old 03-13-2009, 12:38 PM   #7
The wobble is coming form the drive cups with the dog bones in the front.
The one that wobbles is the one connected to the wheel.
So how would I put a shim there.
Old 03-14-2009, 01:32 AM   #8
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
If i am understanding what you posted, then you would need to buy new bearings to replace the bushings in the hubs.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 03-14-2009, 07:36 AM   #9
I have ball bearings
Team Associated TC4 Kenshin Electric On-Road 15368 12-15-2017 09:23 AM
RC10B4/T4 Forum DerekL Electric Off-Road 14339 12-13-2017 11:20 PM
TC3 Forum Lowrider Electric On-Road 12196 10-13-2017 09:47 PM
Topeka Racing porter Kansas/Missouri Racing 6570 07-23-2016 09:34 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Jammin X1 - so close yet so far beetlebz Nitro Off-Road 4524 03-25-2012 02:54 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
