Question about Spektrum DX3R
Spektrum DX3R
Does anyone know how to slow down the speed of the steering servo in this radio.... or if it even has that option ?
I am thumbing through the manual and dont see that option... whereas i know other people that have different radios with that option
thanks in advance for any help
you can increase the exponential to decreases the steering sensitivity around neutral the higher the number the slower it reacts.
Ok.. I thought that I could do that... but doesnt that make it super sensitive on the other side of the steering spektrum. meaning slow when i barely turn the wheel, but when i get past a certain point.. it will be super sensitive?
Nope, can not slow down servo speed. Only expo.
Personally I don't adjust servo speed...speed doesn't make a car steer faster or slower, it makes it more or less accurate and responsive to your inputs. The brain gets used to the delay between when you make an input and when the car does it so it takes some getting used to when that time is shortened.
Anyway from what I read in the manual it doesn't have a servo speed adjustment per say...but you can change the frame rate to slow down the response.
bluephi1914- It sounds like you may have a setup issue rather than a servo that's too fast. Most top drivers do not tune their radio to de-sensitize steering; they change setup on the car. You may want to consider car adjustments to cure your steering problem.
I don't think slowing down response time will do it. The servo will still turn as fast as it does, it just slows down the response time from when you turn the wheel, to when the car turns.... Or more like.... there will be more of a delay. If you want that delay... just play with expo. But once again, you can not adjust servo speed.
What effect are you trying to get?
For me as a Newer driver... I was just wanting to slow it down until i was able to master the art or steering and driving the car a little better. dont get me wrong I can get around the track.. but at times its a struggle for me to consistantly do it and i was thinking if i were able to slow the servo down it would be a little easier to control... going into the turns.
Using a little bit of expo, say 10% with numb turn in a bit but not loose overal steering, it's not enough to make the car feel weird, I found that it took over 20% on my radio to have noticeable "shift" in steering response with expo, it's a 3pk though so the curves might be slightly different.
You can buy servo speed reducers that go between the receiver and servo. A good hobby shop will have one or know where to get one.
I find the BEST way to slow down the servo is to move your hand slower on the steering wheel. Works with ANY radio and it'll make you a better driver.
OF course, if you STILL feel that 100$ digital servo is too fast, I'd be happy to trade you a $18 one that will be nice and slow...
Somewhat, but if you turn suddenly in the opposite direction, when the servo gets the signal, it will respond very fast in the opposite direction rather than slowly turning in the opposite direction. So, yes, there may be a "delayed" initial turning response, the servo will still have a weird "fast" steering effect on opposite lock. I guess it will feel like expo setting with slow initial turn with fast turn at max throw.
