Old 03-12-2009, 10:19 AM   #1
Toh WL's Avatar
Default Question on DSM Pro & DSM2 compatibility on electric car as well operation issues
Dear experts, I had a question on DSM modules need your kind assistance & advice. I am using Sanwa M11 with SM1001 Pro transmitter module. As for the receiver it is SR3001 DSM 3 channel Pro.
I had a problem which when I press the bind button on the Rx. The LED does not blink on the receiver end. But when I press the Tx bind button the LED blinks. It seem to binds the Tx & Rx only that the Rx has no LED blinking.
Another thing is glitches, it happens intermittently. I already oriented the receiver & antenna as far from ESC possible. What happens when I steer the car wheels to left & right. The motor starts to jerk/kick in for seconds, stops & then resume when I steer the front wheels.
When I swap with FM Tx & Rx module. It no longer happens.
On the other hand, I was thinking if Tx with SM1001 Pro binds with SR3100 DSM2 3-Channel Race Receiver. Will it work actually, anyone tried? Do I get the 3ms respond likewise when Tx & Rx are of the Pro modules?
SM1001 Pro Tx
SR3100 DSM2 Rx
= will it work?
Toh WL is offline   Reply With Quote
Old 03-12-2009, 10:24 AM   #2
DARKSIDE's Avatar
must be in the water...lol..i just had this problem...the newer dsm rx's will not work with any of the older module or radios....i bought the sr3520 dsm2 rx and it WILL NOT WORK with my pro on my m11...the only current radio to use the newest dsm is the 3 by Spectrum
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 03-12-2009, 10:42 AM   #3
Toh WL's Avatar
Never at all I play after rain using DSM. Last time I remember playing after rain with FM module before switching DSM I did killed my ESC. Expensive lesson learned.
You mean this: ...
How about this with the DSM Pro below? Will it work?
Old 03-12-2009, 10:47 AM   #4
Little_Mike's Avatar
Any DSM 1 receiver will work, the DSM 2's will not, they transmit a different signal. You would need to have a DSM 2 transmitter to use a DSM 2 receiver.
Upgrading to the DX3R is well worth the money though, I havnt had a single glitch the whole year ive had it now, NOT ONE!!!
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 03-12-2009, 12:35 PM   #5
Yeti35's Avatar
You mean this: ...
The bottom pic is of the 3500 from the DSM 1 systems, so yeah it will work fine. I run those with my Pro module in my Helios. They are Pro as well, just a smaller format/footprint.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 03-12-2009, 01:15 PM   #6
DARKSIDE's Avatar
ditto
Old 03-12-2009, 01:38 PM   #7
avs
avs's Avatar
i have noticed that when holding the transmitter very close to the receiver, like when trying to bind or setup end points etc, i would get something like 'glitching'.
when this happens again, try taking a couple steps away from the car and see if it goes away.
avs is offline   Reply With Quote
Old 03-12-2009, 10:33 PM   #8
Toh WL's Avatar
Little_Mike,
Thanks for the clarification. What if my transmitter is DSM2 & my receiver is DSM? As for DX3R people also having issues. Not forgetting DX3S they have to sent the equiptment twice to Horizon hobby. More details on the discussion forum below:
http://www.rctech.net/forum/malaysia...3r-dx3s-6.html
Yeti35,
Since it's working well as tested. Thanks man... By the way are you getting quicker respond in comparision with the orignal Pro Rx.
Old 03-12-2009, 10:41 PM   #9
Toh WL's Avatar
Yes man I got the exact same problem & u hit the nail.
1st case:
What happen when I stop the car at pitstop & lift it up on left hand. My Tx is with my right hand around 40cm away. When I press a bit throttle to sound check which spur got hit by small stones. That I notice the steering wheels did glitch.
2nd case:
When I put my car on setup board to measure the steer EPA. When I twist the steering wheel. The motor glitches & the car wants to take off. My transmitter is just 15cm from the vehicle.
So do you all think this is normal? Appreciate the feedbacks....
Old 03-12-2009, 11:04 PM   #10
Yeti35's Avatar
Yeti35,
They are both the same as far as response, but I can't comment on the standard sized Pro RX. I have never owned one. I actually bought my Pro module first and was using it with the non Pro RX's. I gradually swapped all those out for the small 3500's.
22 3.0SR
Old 03-13-2009, 12:49 AM   #11
Toh WL's Avatar
But anyhow the manufacturer claims. The respond is better than the original pro module...
Key Features
Only one third the size of the SR3000 receiver
Pro programming lowers latency by 1.3ms (2.6ms when used with Pro Module)
Lower operating voltage
Integrated voltage protector
Forward and backward compatible with all surface systems (except HRS)
Fuel and motor-spray resistant plastic
Old 03-13-2009, 07:34 PM   #12
Toh WL's Avatar
By the way anyone exprerience similarity as this? Thanks and appreciate the feedback.
