T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 12-09-2010, 12:53 PM
  #6526
hanzo3's Avatar
Trader Rating: 55 (100%+)
Nice ordering site. Just like Amain. Is that case for the car the actual box?
hanzo3 is offline
Old 12-11-2010, 05:41 AM
  #6527
Luppi Stefano's Avatar
Hi Guys, I'm go back to Photon.
soon order new option to prepare for the 2011 season
Luppi Stefano is offline
Old 12-11-2010, 03:34 PM
  #6528
OVA
OVA's Avatar
Trader Rating: 87 (100%+)
Where is EJ??
Does anybody know where can I find EJ setup for TZII high grip carpet...?
OVA is offline
Old 12-11-2010, 03:55 PM
  #6529
haywood's Avatar
Trader Rating: 49 (100%+)
Default New Site
Great new site! Just like A-Main!
haywood is offline
Old 12-11-2010, 06:42 PM
  #6530
haywood's Avatar
Default Foam Photon
I am running the foam car and was wondering if the Xray 6 degree caster blocks would work on the Photon?
XRAY Composite Hard Foam-Spec C-Hub (Left 6) (T2 008)
[XRA302376]
****Low*Price:*$7.79*
haywood is offline
Old 12-11-2010, 06:48 PM
  #6531
Work very Well! but use front Knuckle arm XRAY, for perfect assembly
Old 12-11-2010, 07:20 PM
  #6532
stiltskin's Avatar
Trader Rating: 103 (100%+)
[XRA302376]
The are very snug in the arm and need to be sanded to work properly. If you plan on using the photon steering block, you will need to put a shim between the block and the top of the c-hub. Don't forget to pick up the Xray bushings also. At $18 for the set, I think they're made of Platinum.
stiltskin is offline
Old 12-11-2010, 08:18 PM
  #6533
TeamWTF's Avatar
Hey guys
Can someone give e an explanation on the effects of moving the ackerman arm forward/back? I can see if would effect travel so lets assume i set the endpoints back to full lock...
Cheers
Phill
TeamWTF is offline
Old 12-11-2010, 08:39 PM
  #6534
pakk's Avatar
Trader Rating: 80 (100%+)
I don't have a technical answer for you, but I can tell you what I noticed today when I play'd with it.
The further forward you go, the more steering you get. But it does become more difficult to drive. I was lacking some mid corner steering. EJ suggested I go up one(I had it all the way back). But I had a hard time getting used to it. I had to learn to be a lot more smooth with the wheel or else the back end would come out.
pakk is offline
Old 12-11-2010, 09:51 PM
  #6535
TeamWTF's Avatar
Ok thats good... I need more steering and have it all the way back...
TeamWTF is offline
Old 12-12-2010, 03:09 AM
  #6536
sosidge's Avatar
I think the build manual suggests building it short - I can't imagine that you would get any steering on that setting! Run it on the middle setting with the 10 insert as a starting point, go smaller on the insert or longer on the crank if you need more aggressive steering than that.
sosidge is offline
Old 12-12-2010, 05:15 AM
  #6537
Middle crank: Standard
Rearward crank: increase steering in first part of Corner, more agility in Chicane
Forward crank: increase steering in fast Corner and out of curve, but is much less reactive in the chicane.
Insert:
10: standard position
9: reduces steering in input, steering increases in output corner
11: increase steering input corner
12: I have not tried it yet
Old 12-13-2010, 06:21 AM
  #6538
MikeXray's Avatar
Trader Rating: 73 (100%+)
Anyone figure out a way to rig up a 5th body post up front?
MikeXray is offline
Old 12-13-2010, 06:40 AM
  #6539
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
I have seen them mounted on top of the steering bellcrank with a long set screw.
Jamison R is offline
Old 12-13-2010, 05:30 PM
  #6540
gruman28's Avatar
Trader Rating: 18 (100%+)
Getting a photon from the wife for xmas. Getting rid of some of my xray parts. Wondering will xray shock springs fit on photon shocks? I have a ton of them and wondering if I should keep them.
Chris
gruman28 is offline
